Modify the Output of Deepstream Pipeline
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.0.1
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version
Hi, I am using deepstream_imagedata-multistream.py sample application. In this application I can get the frame, perform some operation and save the frame.
My Question is, is there any way that I can show this frame as output using the sink element of the pipeline.
For Example. I want to draw the bounding boxes only on a one class and then show that frame as output using sink.
Currently I can only draw the bounding boxes and save it. I can’t show that as output of the pipeline.
What do you mean as output of the pipeline?
I mean the output video that will be displayed on the screen when I run the pipeline.
You can refer to our demo deepstream_test_1.py. This is how to draw the text. You can just modify that to rect_params.
I don’t want to add the text to the frame. I want to replace the frame with another frame
What do you mean by I want to replace the frame with another frame? Can you describe your needs in detail?
What if instead of using nvdsosd, you create a custom gstreamer element.
Take your image buffer and directly map into gpumat and then draw boxes using cuda kernel?
You can refer dsexample for the custom gstreamer element stuff.
OK. You can consider using the following plugin nvdsvideotemplate. Using this plugin, you can process the image data into any other data you want. We have many demos of using this plugin, like deepstream-emotion-app.
