I tried training it on a large dataset, and it got stuck. I closed it days ago, but when opining it, it gest stuck trying to read the same data over and over. It’s stuck in a loop where I can’t get past the command line.
Don’t know if the answer is still relevant for you, but I’ve just had the exact same issue today. After spying on running process and reading python code, I’ve found that the sources are stored in (replace Pierr by your windows profile)
C:\Users\Pierr\AppData\Local\NVIDIA\ChatWithRTX\RAG\trt-llm-rag-windows-main\config\preferences.json
Just change dataset.path to an empty folder, and you can restart engine and get back interface.
