I entered an overly large folder in the Dataset folder path, and there are many files in the folder that have not been downloaded from OneDrive (if they are all downloaded, my hard disk capacity is not enough, so I chose to download on demand), but it started Sometimes, a file error will be displayed and Chat cannot be entered, so I must modify the folder path, so can I modify configuration file to change Dataset Folder Path ? What’s the configuration file path ?
try this C:\Users\j4bka\AppData\Local\NVIDIA\ChatWithRTX\RAG\trt-llm-rag-windows-main\config\preferences.json
thanks! I can modify the path!,thansk alot !
You can also delete preferences.json or make it preferences-old.json so it is not used. It should put you back to square 1 in that the file does not exist on initial install.
