o Linux distro and version Windows 10
o GPU type Geforce 1660ti
o Nvidia driver version 441.22
o CUDA version 10.2
o CUDNN version 7.6.5
o TensorRT version 7.0.0.11
For using createPriorBoxPlugin and createNMSPlugin to get detection boxes, I wrote the code below, but it does not work, I got the wrong result. The code with green color is where I think I may make mistakes. So could you tell me where is wrong and how to use these two function rightly. Expecting for the answer, thank you very much.
#include <NvInferPlugin.h>
nvinfer1::ITensor *Trtnet::getNMS(nvinfer1::INetworkDefinition *network, nvinfer1::ITensor *loc, nvinfer1::ITensor *conf)
nvinfer1::ITensor *output;
nvinfer1::plugin::PriorBoxParameters prior_box_params;
float min_size[6] = { 30.72f, 76.8f, 168.96f, 261.12f, 353.28f, 445.44f };
float max_size[6] = { 76.8f, 168.96f, 261.12f, 353.28f, 445.44f, 537.6f };
float aspect_ratio[2] = { 2.0f, 3.0f };
float variance[4] = { 0.1f, 0.1f, 0.2f, 0.2f };
prior_box_params.minSize = min_size;
prior_box_params.maxSize = max_size;
prior_box_params.numMinSize = 6;
prior_box_params.numMaxSize = 6;
prior_box_params.aspectRatios = aspect_ratio;
prior_box_params.numAspectRatios = 2;
prior_box_params.flip = true;
prior_box_params.clip = true;
prior_box_params.imgH = kINPUT_H;
prior_box_params.imgW = kINPUT_W;
prior_box_params.stepH = 8;
prior_box_params.stepW = 8;
prior_box_params.offset = 0;
for (int i = 0; i < 4; i++)
prior_box_params.variance[i] = variance[i];
nvinfer1::IPluginV2 * prior_boxes = createPriorBoxPlugin(prior_box_params);
nvinfer1::ITensor *prior_boxes_out = network->addPluginV2(NULL, 0, *prior_boxes)->getOutput(0);
nvinfer1::plugin::DetectionOutputParameters decode_output_params;
decode_output_params.shareLocation = true;
decode_output_params.varianceEncodedInTarget = true;
decode_output_params.backgroundLabelId = -1;
decode_output_params.numClasses = 81;
decode_output_params.topK = 300;
decode_output_params.keepTopK = 50;
decode_output_params.confidenceThreshold = 0.2;
decode_output_params.nmsThreshold = 0.45;
decode_output_params.codeType = nvinfer1::plugin::CodeTypeSSD::CENTER_SIZE;
decode_output_params.confSigmoid = false;
for (int i = 0; i < 3; i++)
decode_output_params.inputOrder[i] = i;
decode_output_params.isNormalized = false;
nvinfer1::ITensor *inputs[3];
inputs[0] = loc;
inputs[1] = conf;
inputs[2] = prior_boxes_out;
nvinfer1::IPluginV2 *NMS = createNMSPlugin(decode_output_params);
output = network->addPluginV2(inputs, 3, *NMS)->getOutput(0);
return output;
