Now, How do I write business logic on top of it by feeding images from the OpenCV? Where is this file that has got the inference code?
In Jetson, I have used Deepstream to deploy. But I couldn’t find a simple implementation that shows how I could deploy the custom model on the Jetson using Python API? I have both .tlt,.etlt,.engine files but the documentation is extremely worse and scattered so it’s hard to understand. And how do I see the output as we would with OpenCV using imshow?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
