Platform and Versions: using Xavier NX with DeepStream 6.3, TensorRT 8.5.2.2, and CUDA 11.4.
Objective: Run a DeepStream application locally on the Jetson without using a pipeline or probe function.
** Requirements:
The requirement i need is that I would like to run the deepstream app locally in the jetson without using pipeline and without any probe function for the LPD Model. My aim is to load the images from the local folder and to get inference with model’s detection and have to save those inference images into a folder.
I tried to run the by using the LPD tensorRT with the below code but getting error : Failed to deserialize the engine and failing to load tensorRt engine , while I ensured with correct path and correct file format but still facing issue to load the model itself.
def __init__(self, host_mem, device_mem):
self.host = host_mem
self.device = device_mem
def __str__(self):
return f"Host:\n{self.host}\nDevice:\n{self.device}"
def __repr__(self):
return self.__str__()
class TrtModel:
def init(self, engine_path, max_batch_size=1, dtype=np.float32):
self.engine_path = engine_path
self.dtype = dtype
self.logger = trt.Logger(trt.Logger.WARNING)
self.runtime = trt.Runtime(self.logger)
self.engine = self.load_engine(self.runtime, self.engine_path)
if self.engine is None:
raise RuntimeError(“Failed to load the TensorRT engine.”)
self.max_batch_size = max_batch_size
self.inputs, self.outputs, self.bindings, self.stream = self.allocate_buffers()
self.context = self.engine.create_execution_context()
@staticmethod
def load_engine(trt_runtime, engine_path):
if not os.path.exists(engine_path):
raise FileNotFoundError(f"Engine file not found at {engine_path}“)
trt.init_libnvinfer_plugins(None, “”)
with open(engine_path, ‘rb’) as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
if engine is None:
raise RuntimeError(“Failed to deserialize the CUDA engine.”)
return engine
def allocate_buffers(self):
inputs, outputs, bindings = , ,
stream = cuda.Stream()
for binding in self.engine:
size = trt.volume(self.engine.get_binding_shape(binding)) * self.max_batch_size
host_mem = cuda.pagelocked_empty(size, self.dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(device_mem))
if self.engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
return inputs, outputs, bindings, stream
def call(self, x: np.ndarray, batch_size=1):
x = x.astype(self.dtype)
np.copyto(self.inputs[0].host, x.ravel())
for inp in self.inputs:
cuda.memcpy_htod_async(inp.device, inp.host, self.stream)
self.context.execute_async(batch_size=batch_size, bindings=self.bindings, stream_handle=self.stream.handle)
for out in self.outputs:
cuda.memcpy_dtoh_async(out.host, out.device, self.stream)
self.stream.synchronize()
return [out.host.reshape(batch_size, -1) for out in self.outputs]
def area_of(left_top, right_bottom):
hw = np.clip(right_bottom - left_top, 0.0, None)
return hw[…, 0] * hw[…, 1]
def iou_of(boxes0, boxes1, eps=1e-5):
overlap_left_top = np.maximum(boxes0[…, :2], boxes1[…, :2])
overlap_right_bottom = np.minimum(boxes0[…, 2:], boxes1[…, 2:])
overlap_area = area_of(overlap_left_top, overlap_right_bottom)
area0 = area_of(boxes0[…, :2], boxes0[…, 2:])
area1 = area_of(boxes1[…, :2], boxes1[…, 2:])
return overlap_area / (area0 + area1 - overlap_area + eps)
def hard_nms(box_scores, iou_threshold, top_k=-1, candidate_size=200):
scores = box_scores[:, -1]
boxes = box_scores[:, :-1]
picked =
indexes = np.argsort(scores)[-candidate_size:]
while len(indexes) > 0:
current = indexes[-1]
picked.append(current)
if 0 < top_k == len(picked) or len(indexes) == 1:
break
current_box = boxes[current, :]
indexes = indexes[:-1]
rest_boxes = boxes[indexes, :]
iou = iou_of(rest_boxes, np.expand_dims(current_box, axis=0))
indexes = indexes[iou <= iou_threshold]
return box_scores[picked, :]
def predict(width, height, confidences, boxes, prob_threshold, iou_threshold=0.3, top_k=-1):
picked_box_probs =
picked_labels =
for class_index in range(1, confidences.shape[1]):
probs = confidences[:, class_index]
mask = probs > prob_threshold
probs = probs[mask]
if probs.shape[0] == 0:
continue
subset_boxes = boxes[mask, :]
box_probs = np.concatenate([subset_boxes, probs.reshape(-1, 1)], axis=1)
box_probs = hard_nms(box_probs, iou_threshold=iou_threshold, top_k=top_k)
picked_box_probs.append(box_probs)
picked_labels.extend([class_index] * box_probs.shape[0])
if not picked_box_probs:
return np.array(), np.array(), np.array()
picked_box_probs = np.concatenate(picked_box_probs)
picked_box_probs[:, 0] *= width
picked_box_probs[:, 1] *= height
picked_box_probs[:, 2] *= width
picked_box_probs[:, 3] *= height
return picked_box_probs[:, :4].astype(np.int32), np.array(picked_labels), picked_box_probs[:, 4]
batch_size = 1
threshold = 0.2
trt_engine_path = “LPDNet/yolov4_tiny_usa_deployable.etlt_b16_gpu0_fp16.engine”
input_folder = “input_images”
output_folder = “detected_number_plates”
try:
model = TrtModel(trt_engine_path)
shape = model.engine.get_binding_shape(0)
for filename in os.listdir(input_folder):
if filename.endswith(”.jpg") or filename.endswith(“.png”):
image_path = os.path.join(input_folder, filename)
frame = cv2.imread(image_path)
frame = imutils.rotate_bound(frame, 270)
h, w, _ = frame.shape
image = cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)
image1 = cv2.resize(image, (320, 240))
image_mean = np.array([127, 127, 127])
image = (image1 - image_mean) / 128
image = np.transpose(image, [2, 0, 1])
image = np.expand_dims(image, axis=0).astype(np.float32)
confidences, boxes = model(image, batch_size)
boxes, labels, probs = predict(image1.shape[1], image1.shape[0], confidences, boxes, threshold)
for i, box in enumerate(boxes):
x1, y1, x2, y2 = box
plate_image = frame[y1:y2, x1:x2]
output_path = os.path.join(output_folder, f"{filename.split(‘.’)[0]}_{i}.jpg")
cv2.imwrite(output_path, plate_image)
print(“Detection and saving completed.”)
except Exception as e:
print(f"Error: {e}")
