It’s described in the datasheet,but there’s no answer I need.
and also see,
DLA-v2 is slower than DLA-v1 - #8 by AastaLLL
“Orin’s DLA has more int8 dense TOPs but fewer fp16 TOPs.”
I want to know what the actual data of FP16 TOPs should be,
Thank you for your answer.
AI Performance
JAO 64GB: Up to 275 Sparse TOPS (INT8)
JAO 32GB: Up to 200 Sparse TOPs (INT8)Ampere GPU
JAO 64GB: 2 GPC | 8 TPC | 2048 NVIDIA® CUDA® cores | 64 Tensor cores
Ray-Tracing cores | 170 Sparse TOPS | Maximum Operating Frequency:1.3 GHzJAO 32GB: 2 GPC | 7 TPC | | 1792 NVIDIA® CUDA® cores | 56 Tensor
cores Ray-Tracing cores | 108 Sparse TOPS Maximum Operating Frequency: 939 MHzJAO: End-to-end lossless compression | Tiled Caching | OpenGL® 4.6+ |
OpenGL ES 3.2 | Vulkan™ 1.2+◊ | CUDA 10.2+ | Maximum Operating Frequency: 1.3 GHzArm Cortex-A78AE CPU
Arm v8.2 (64-bit) heterogeneous multi-processing (HMP) CPU
architecture |
JAO 64GB: 12x cores | 3 CPU clusters (4 cores/cluster) | 259
SPECint_rate2006
JAO 32GB: 8x cores | 2 CPU clusters (4 cores/cluster) | 177
SPECint_rate2006
JAO: L1 Cache: 64 KB L1 instruction cache (I-cache) + 64 KB L1 data
cache (D-cache) per CPU core | L2 Cache: 256 KB per CPU core | L3
Cache: 2MB per CPU cluster | Maximum Operating Frequency: 2.2 GHzDL Accelerator
JAO: 2x NVDLA 2.0 Engines |
JAO 64GB: Maximum Operating Frequency: 1.6 GHz | 52.5 TOPS
each(Sparse INT8)
JAO 32GB: Maximum Operating Frequency: 1.4 GHz | 46 TOPs each
(Sparse INT8)
