I tried to load multiple contexts (originated from DLA engine) as many as possible.
From these experiments, I found that it hold maximum 4 dla-contexts at the same time.
I also checked that each context requires 4,178,432 Byte.
(I checked this by calling the API “engine->getDeviceMemorySize()”.)
I want to stop loading dla engines before I load DLA engine too much.
In ‘Xavier Technical Reference Manual’, I found that
DLA memory(CVSRAM) has 4MiB physical memory and 256MiB virtual memory space.
However, Both 4MiB and 256MiB can’t be the threshold between 4,178,432Byte4 and 4,178,432Byte5.
Why “NvMediaDlaLoadLoadable : load loadable failed.)” error occurs?
If the error is caused by the limitation of DLA’s own memory size,
how much amount of memory-size DLA memory can afford for DLA contexts?
Thanks in advance.
yjkim.
