Hello, I used the GSTRAEMER call and found that the video screen has a noticeable delay effect, and then I used opencv to read the same delay. However, according to the official prompt, if you input nvgstcapture in the terminal, the video image will not have a delayed effect. Is there any other code that can display a demo of the CSI video that reads the CSI video in real time? Thank you
DaneLLL
2
Certain delay may be from the camera source. Please try this set up to identify where the delay is from:
Jetson Nano FAQ
Q: Is there an example for running UDP streaming?
You can compare nvargucamerasrc or v4l2src with videoteststc.
Related topics
| Gst-launch-1.0 nvarguscamerasrc ! "video/x-raw(memory:NVMM)" ! nvvidconv ! xvimagesink sync=false | 16 | 2394 | April 6, 2022 | |
| Delay problem | 7 | 1171 | February 21, 2022 | |
| CSI camera - snapshot issue | 5 | 874 | October 5, 2021 | |
| Jetson nano.. Wants to reduce the lag while capturing the video from IP cam. | 2 | 2243 | November 12, 2019 | |
| Optimal time delay and jitter performance measure strategy when using gstreamer to stream camera frames | 4 | 1988 | July 22, 2022 | |
| Jetson nano dual camera stop when play too long | 5 | 688 | September 14, 2020 | |
| RTSP stream delay / Pipeline optimization | 1 | 1252 | December 25, 2023 | |
| Delay | 12 | 906 | August 3, 2022 | |
| Delay in video | 4 | 2874 | November 24, 2020 | |
| Problem CSI camera Jetson Nano OpenCV | 2 | 5058 | December 15, 2021 |
