How should I get the frame from libargus?
Hi.
I am using the IMX296 sensor on the jetson Orin board. When I use the following command v4l2-ctl, I receive the frame without any problem. But when I try to use libargus I have problem. How should I get the frame from libargus?
Of course, I use oneShot to capture a frame.
./argus_oneshot
Executing Argus Sample: argus_oneshot
Argus Version: 0.99.3.3 (multi-process)
No camera devices are available.
Camera devices: 0
Error generated. oneShot/main.cpp, 86 Failed to get ICameraProperties int
When I use the “sudo enableCamInfiniteTimeout=1 nvargus-daemon” command:
=== NVIDIA Libargus Camera Service (0.99.33)=== Listening for connections...=== argus_oneshot[11603]: Connection established (FFFF924FC900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 107)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclDriver_V4L2_Focuser_Stub_Close: Invalid NULL input pPclDriver
NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 689)
SCF: Error BadParameter:  (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 453)
SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 333)
SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function getSource(), line 505)
=== argus_oneshot[11603]: CameraProvider initialized (0xffff8c6ae5c0)=== argus_oneshot[11603]: CameraProvider destroyed (0xffff8c6ae5c0)=== argus_oneshot[11603]: Connection closed (FFFF924FC900)=== argus_oneshot[11603]: Connection cleaned up (FFFF924FC900)
when use gstreamer:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1440, height=1088, framerate=30/1, format=NV12' ! nvjpegenc quality=100 ! filesink location=frame.jpg
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:751 No cameras available
Got EOS from element "pipeline0".
Execution ended after 0:00:00.005060086
Setting pipeline to NULL ...
Freeing pipeline ...
No cameras available could be the context of the tegra_camera_platform{} incorrect. Could be the devname incorrect or something else.
That means I should look for fixing the problem in the camera driver or in the device tree?
Need fix by device tree.
