Hi all,
I am using a custom camera with an imager AR0820 connected with GMSL2 MIPI CSI interface, i am able to capture using nvarguscamerasrc using the CLI
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)NV12, framerate=(fraction)30/1' ! nvvidconv ! queue ! xvimagesink
And i am able to capture using samples from /home/jetson/jetson_multimedia_api/argus/samples, but know i want create a custom application using LibArgus, so i just try to to instanciate a camera provider with Argus with the following program :
#include <stdio.h>
#include <Argus/Argus.h>
int main() {
Argus::UniqueObj<Argus::CameraProvider> cameraProvider(Argus::CameraProvider::create());
return 0;
The project include :
main.cpp : A program to instanciate the camera provider
Argus : The folder including Argus.h and all sources files of the API
I’ve executed the following CLI :
g++ *.cpp -o prog -I jetson_multimedia_api/argus/include -L /usr/lib/aarch64-linux-gnu/tegra -lnvargus
I could compile without any errors, but when i execute ./prog i had the following output :
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
LSC: LSC surface is not based on full res!
I am wondering if i’m missing anything when i compiled my program ? Why i couldn’t create a camera provider ?
