the original ~/tegra_multimedia_api/argus/samples were built and run without issue. I need capture images from Leopard IMX185 camera and display it on opencv. So simply modified oneShort sample to use opencv with some suggestions on this forum. Then I ran into this error,
nvidia@tegra-ubuntu:~/tegra_multimedia_api/argus/build/samples/oneShot$ ./argus_oneshot
Executing Argus Sample: argus_oneshot
Argus Version: 0.96.2 (multi-process)
(img:13810): Gtk-ERROR **: GTK+ 2.x symbols detected. Using GTK+ 2.x and GTK+ 3 in the same process is not supported
Trace/breakpoint trap
Is Argus using gtk3.0 and opencv uses gtk2.0?
Here is my oneShot/main.cc. The changes are inside “#ifdef ORIGINAL_JPEG_IMAGE”.
nvidia@tegra-ubuntu:~/tegra_multimedia_api/argus/samples/oneShot$ cat main.cpp
* Copyright (c) 2016-2017, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "../../../include/nvbuf_utils.h"
#include "Options.h"
#include <Argus/Argus.h>
#include <Argus/Types.h>
#include <EGLStream/Frame.h>
#include <EGLStream/EGLStream.h>
#include <EGLStream/NV/ImageNativeBuffer.h>
#include <opencv2/core.hpp>
#include <opencv2/highgui.hpp>
#include <opencv2/imgproc.hpp>
#include <stdio.h>
#include <stdlib.h>
#include <sys/mman.h>
using namespace EGLStream;
#define EXIT_IF_NULL(val, msg) \
if (!val) { \
printf("%s\n", msg); \
return EXIT_FAILURE; \
#define EXIT_IF_NOT_OK(val, msg) \
if (val != Argus::STATUS_OK) { \
static const uint32_t DEFAULT_CAMERA_INDEX = 0;
* Program: oneShot
* Function: Capture a single image from a camera device and write to a JPG file
* Purpose: To demonstrate the most simplistic approach to getting the Argus
* Framework
* running, submitting a capture request, retrieving the resulting
* image and
* then writing the image as a JPEG formatted file.
int main(int argc, char **argv) {
printf("Executing Argus Sample: %s\n", basename(argv[0]));
ArgusSamples::Value<uint32_t> cameraIndex(DEFAULT_CAMERA_INDEX);
ArgusSamples::Options options(basename(argv[0]));
options.addOption(ArgusSamples::createValueOption(
"device", 'd', "INDEX", "Camera index.", cameraIndex));
if (!options.parse(argc, argv))
if (options.requestedExit())
return EXIT_SUCCESS;
const uint64_t FIVE_SECONDS_IN_NANOSECONDS = 5000000000;
std::vector<Argus::CameraDevice *> cameraDevices;
* Set up Argus API Framework, identify available camera devices, and create
* a capture session for the first available device
Argus::UniqueObj<Argus::CameraProvider> cameraProvider(
Argus::CameraProvider::create());
Argus::ICameraProvider *iCameraProvider =
Argus::interface_cast<Argus::ICameraProvider>(cameraProvider);
EXIT_IF_NULL(iCameraProvider, "Cannot get core camera provider interface");
printf("Argus Version: %s\n", iCameraProvider->getVersion().c_str());
Argus::Status status = iCameraProvider->getCameraDevices(&cameraDevices);
EXIT_IF_NOT_OK(status, "Failed to get camera devices");
EXIT_IF_NULL(cameraDevices.size(), "No camera devices available");
if (cameraDevices.size() <= cameraIndex.get()) {
printf("Camera device specifed on command line is not available\n");
Argus::UniqueObj<Argus::CaptureSession> captureSession(
iCameraProvider->createCaptureSession(cameraDevices[cameraIndex.get()],
&status));
Argus::ICaptureSession *iSession =
Argus::interface_cast<Argus::ICaptureSession>(captureSession);
EXIT_IF_NULL(iSession, "Cannot get Capture Session Interface");
* Creates the stream between the Argus camera image capturing
* sub-system (producer) and the image acquisition code (consumer). A
* consumer object is
* created from the stream to be used to request the image frame. A
* successfully submitted
* capture request activates the stream's functionality to eventually make a
* frame available
* for acquisition.
Argus::UniqueObj<Argus::OutputStreamSettings> streamSettings(
iSession->createOutputStreamSettings());
Argus::IOutputStreamSettings *iStreamSettings =
Argus::interface_cast<Argus::IOutputStreamSettings>(streamSettings);
EXIT_IF_NULL(iStreamSettings, "Cannot get OutputStreamSettings Interface");
iStreamSettings->setPixelFormat(Argus::PIXEL_FMT_YCbCr_420_888);
iStreamSettings->setResolution(Argus::Size2D<uint32_t>(640, 480));
iStreamSettings->setMetadataEnable(true);
Argus::UniqueObj<Argus::OutputStream> stream(
iSession->createOutputStream(streamSettings.get()));
Argus::IStream *iStream = Argus::interface_cast<Argus::IStream>(stream);
EXIT_IF_NULL(iStream, "Cannot get OutputStream Interface");
Argus::UniqueObj<EGLStream::FrameConsumer> consumer(
EGLStream::FrameConsumer::create(stream.get()));
EGLStream::IFrameConsumer *iFrameConsumer =
Argus::interface_cast<EGLStream::IFrameConsumer>(consumer);
EXIT_IF_NULL(iFrameConsumer, "Failed to initialize Consumer");
Argus::UniqueObj<Argus::Request> request(
iSession->createRequest(Argus::CAPTURE_INTENT_STILL_CAPTURE));
Argus::IRequest *iRequest = Argus::interface_cast<Argus::IRequest>(request);
EXIT_IF_NULL(iRequest, "Failed to get capture request interface");
status = iRequest->enableOutputStream(stream.get());
EXIT_IF_NOT_OK(status, "Failed to enable stream in capture request");
uint32_t requestId = iSession->capture(request.get());
EXIT_IF_NULL(requestId, "Failed to submit capture request");
* Acquire a frame generated by the capture request, get the image from the
* frame
* and create a .JPG file of the captured image
Argus::UniqueObj<EGLStream::Frame> frame(
iFrameConsumer->acquireFrame(FIVE_SECONDS_IN_NANOSECONDS, &status));
EGLStream::IFrame *iFrame = Argus::interface_cast<EGLStream::IFrame>(frame);
EXIT_IF_NULL(iFrame, "Failed to get IFrame interface");
EGLStream::Image *image = iFrame->getImage();
EXIT_IF_NULL(image, "Failed to get Image from iFrame->getImage()");
EGLStream::IImageJPEG *iImageJPEG =
Argus::interface_cast<EGLStream::IImageJPEG>(image);
EXIT_IF_NULL(iImageJPEG, "Failed to get ImageJPEG Interface");
status = iImageJPEG->writeJPEG("oneShot.jpg");
EXIT_IF_NOT_OK(status, "Failed to write JPEG");
#else
CvSize m_framesize(640, 480);
// Acquire a Frame.
Argus::UniqueObj<EGLStream::Frame> frame(iFrameConsumer->acquireFrame());
EGLStream::IFrame *iFrame = Argus::interface_cast<IFrame>(frame);
// Get the Frame's Image.
EGLStream::NV::IImageNativeBuffer *iImageNativeBuffer =
Argus::interface_cast<EGLStream::NV::IImageNativeBuffer>(image);
EXIT_IF_NULL(iImageNativeBuffer, "Failed to create an IImageNativeBuffer");
int fd = iImageNativeBuffer->createNvBuffer(
Argus::Size2D<uint32_t>{m_framesize.width, m_framesize.height},
NvBufferColorFormat_YUV420, NvBufferLayout_Pitch, &status);
EXIT_IF_NOT_OK(status, "Failed to create a native buffer");
NvBufferParams params;
NvBufferGetParams(fd, ¶ms);
int fsize = params.pitch[0] * m_framesize.height;
char *data_mem = (char *)mmap(NULL, fsize, PROT_READ | PROT_WRITE, MAP_SHARED,
fd, params.offset[0]);
if (data_mem == MAP_FAILED)
printf("mmap failed : %s\n", strerror(errno));
cv::Mat imgbuf = cv::Mat(m_framesize.height, m_framesize.width, CV_8UC1,
data_mem, params.pitch[0]);
cv::imshow("img", imgbuf);
cv::waitKey(1);
NvBufferDestroy(fd);
#endif
thanks!
Steve
