I want to get stereo images from two image sensors which are equipped my customized carrier board (CSI-2).
I already checked the sensor working properly by storing the streams as separate videos.
Following commands are what I tested,
gst-launch-1.0 nvcamerasrc sensor-id=0 num-buffers=3000 ! omxh264enc ! qtmux ! filesink location=test0.mp4
gst-launch-1.0 nvcamerasrc sensor-id=1 num-buffers=3000 ! omxh264enc ! qtmux ! filesink location=test1.mp4
And I modified sample code to get stereo images and convert them to opencv matrice.
When running the modified code on separate processes, the function acquireFrame() works successfully.
./samples/syncSensor/argus_syncsensor 0 ← get left image from sensor 0
./samples/syncSensor/argus_syncsensor 1 ← get right image from sensor 1
But I got some error message when trying to get two images at one process.
./samples/syncSensor/argus_syncsensor ← get stereo images from sensor 0 and 1
(Argus) Error InvalidState: Max frames acquired (in src/eglstream/FrameConsumerImpl.cpp, function acquireFrame(), line 266)
… ( The error message occurs whenever executing acquireFrame() )
And, is the following code correct to convert iImage to opencv matrix?
// Get image data from mapbuffer
frames[i].img = cv::Mat(cv::Size(IMG_W, IMG_H), CV_8UC3, (void*)iImage->mapBuffer(), (size_t)iImage2D->getStride());
The whole code is as follows,
class SyncGrabber {
public:
struct Frame {
uint64_t id; //
double ts; // timestamp in seconds
cv::Mat img; //
/** @brief Contructor
* @param[in] w,h Width and height of image.
explicit SyncGrabber(const int numCams, const uint32_t w, const uint32_t h, const int cidx = -1);
~SyncGrabber();
void run();
private:
const int NUM_CAMS;
const uint32_t IMG_W;
const uint32_t IMG_H;
const int captureIndex_;
bool bExit_;
UniqueObj<CameraProvider> cameraProvider_;
ICameraProvider *iCameraProvider_;
std::vector<UniqueObj<CaptureSession> > captureSessions_;
std::vector<ICaptureSession*> iCaptureSessions_;
std::vector<UniqueObj<OutputStream> > outputStreams_;
std::vector<IStream*> iOutputStreams_;
std::vector<UniqueObj<EGLStream::FrameConsumer> > frameConsumers_;
std::vector<EGLStream::IFrameConsumer*> iFrameConsumers_;
std::vector<UniqueObj<Request> > requests_;
uint64_t stat_gfrm_; // grab frames
std::vector<uint64_t> stat_cnts_; // number of captured frames
uint64_t stat_disp_;
SyncGrabber();
void showStatistics();
SyncGrabber::SyncGrabber(const int numCams, const uint32_t w, const uint32_t h, const int cidx)
: NUM_CAMS(cidx < 0 ? numCams : 1), IMG_W(w), IMG_H(h), captureIndex_(cidx), bExit_(false)
, /* Initialize the Argus camera provider */ cameraProvider_(CameraProvider::create())
, /* Get the ICameraProvider interface from the global CameraProvider. */ iCameraProvider_(interface_cast<ICameraProvider>(cameraProvider_))
CHECK(NUM_CAMS > 0);
LOG_IF(FATAL, !iCameraProvider_) << "Failed to get ICameraProvider interface";
LOG(INFO) << "Version of libargus: " << iCameraProvider_->getVersion();
// Get the camera devices.
std::vector<CameraDevice*> cameraDevices;
iCameraProvider_->getCameraDevices(&cameraDevices);
LOG_IF(FATAL, cameraDevices.size() < NUM_CAMS) << "Must have at least " << NUM_CAMS << " image sensors available.";
LOG(INFO) << cameraDevices.size() << " camera devices are detected and "
<< NUM_CAMS << " camera device will be accessed (camera " << cidx << ").";
// Create the capture session, AutoControl will be based on what the 1st device sees.
for (int i = 0; i < cameraDevices.size(); i++) {
if (captureIndex_ >= 0 && i != captureIndex_) continue;
captureSessions_.push_back(UniqueObj<CaptureSession>(iCameraProvider_->createCaptureSession(cameraDevices[i])));
LOG_IF(FATAL, !captureSessions_[captureSessions_.size()-1]) << "Failed to create capture session " << i;
iCaptureSessions_.push_back(interface_cast<ICaptureSession>(captureSessions_[captureSessions_.size()-1]));
LOG_IF(FATAL, !iCaptureSessions_[iCaptureSessions_.size()-1]) << "Failed to get capture session interface " << i;
// Create stream settings object and set settings common to each stream.
UniqueObj<OutputStreamSettings> streamSettings[NUM_CAMS];
for (int i = 0; i < NUM_CAMS; i++) {
streamSettings[i].reset(iCaptureSessions_[i]->createOutputStreamSettings());
IOutputStreamSettings *iStreamSettings = interface_cast<IOutputStreamSettings>(streamSettings[i]);
LOG_IF(FATAL, !iStreamSettings) << "Failed to create OutputStreamSettings " << i;
iStreamSettings->setPixelFormat(PIXEL_FMT_YCbCr_420_888);
iStreamSettings->setResolution(Size2D<uint32_t>(w, h));
// Create egl streams
LOG(INFO) << "Creating left and right output streams.";
outputStreams_.resize(NUM_CAMS);
iOutputStreams_.resize(NUM_CAMS);
outputStreams_[i].reset(iCaptureSessions_[i]->createOutputStream(streamSettings[i].get()));
iOutputStreams_[i] = interface_cast<IStream>(outputStreams_[i]);
LOG_IF(FATAL, !iOutputStreams_[i]) << "Failed to get OutputStream Interface " << i;
// Create frame consumers
frameConsumers_.resize(NUM_CAMS);
iFrameConsumers_.resize(NUM_CAMS);
frameConsumers_[i].reset(EGLStream::FrameConsumer::create(outputStreams_[i].get(), 1));
iFrameConsumers_[i] = interface_cast<EGLStream::IFrameConsumer>(frameConsumers_[i]);
LOG_IF(FATAL, !iFrameConsumers_[i]) << "Failed to initialize Consumer " << i;
// Create a request
requests_.resize(NUM_CAMS);
// Enable outputStream
requests_[i].reset(iCaptureSessions_[i]->createRequest(CAPTURE_INTENT_PREVIEW));//CAPTURE_INTENT_STILL_CAPTURE));
IRequest *iRequest = interface_cast<IRequest>(requests_[i]);
LOG_IF(FATAL, !iRequest) << "Failed to create Request " << i;
iRequest->enableOutputStream(outputStreams_[i].get());
// Set source settings such as framerate
ISourceSettings *iSourceSettings = interface_cast<ISourceSettings>(iRequest->getSourceSettings());
LOG_IF(FATAL, !iSourceSettings) << "Failed to get ISourceSettings interface " << i;
iSourceSettings->setFrameDurationRange(Range<uint64_t>(1e9 / 60));
// Submit capture for the specified time.
LOG(INFO) << "Starting repeat capture requests.";
int status = iCaptureSessions_[i]->repeat(requests_[i].get());
LOG_IF(FATAL, status != STATUS_OK) << "Failed to start repeat capture request for still image " << i;
stat_gfrm_ = stat_disp_ = 0;
stat_cnts_.resize(NUM_CAMS, 0);
SyncGrabber::~SyncGrabber() {
// Stop the capture requests and wait until they are complete.
// Disconnect Argus producer from the EGLStreams (and unblock consumer acquire).
LOG(INFO) << "Try to exit SyncGrabber.";
iCaptureSessions_[i]->stopRepeat();
iCaptureSessions_[i]->waitForIdle();
iOutputStreams_[i]->disconnect();
LOG(INFO) << "Stop the capture requests, wait until they are complete and disconnect producers.";
// Shut down Argus.
cameraProvider_.reset();
LOG(INFO) << "Shut down argus provider";
void SyncGrabber::showStatistics() {
static uint64_t t_lastDisp_ = v::chrono::tic();
uint64_t dt;
if ((dt = v::chrono::toc(t_lastDisp_)) > 10*1e6) {
std::stringstream ss;
ss << std::setprecision(2) << std::fixed;
ss << "Last " << 10 << " secs," << std::endl;
ss << " Grab frame : " << stat_gfrm_ / 1000. << " ms, ";
for (size_t i = 0; i < stat_cnts_.size(); i++) {
ss << "[" << i << "]: " << (double)stat_cnts_[i] / (dt/1e6) << " fps ";
ss << std::endl;
ss << " Display : frame : " << stat_disp_/ 1000. << " ms";
LOG(INFO) << ss.str();
std::fill(stat_cnts_.begin(), stat_cnts_.end(), 0);
void SyncGrabber::run()
LOG(INFO) << "Run SyncGrabber loop";
uint64_t t0;
while(!bExit_) {
struct Frame frames[NUM_CAMS];
t0 = v::chrono::tic();
Argus::Status status;
UniqueObj<EGLStream::Frame> frame(iFrameConsumers_[i]->acquireFrame(5000000000/*TIMEOUT_INFINITE*/, &status));
EGLStream::IFrame *iFrame = Argus::interface_cast<EGLStream::IFrame>(frame);
if (!iFrame) {
LOG(WARNING) << "Failed to get IFrame interface " << i << ", status: " << status;
continue;
EGLStream::Image *image = iFrame->getImage();
LOG_IF(WARNING, !image) << "Failed to get Image from iFrame->getImage()";
EGLStream::IImage *iImage = interface_cast<EGLStream::IImage>(image);
LOG_IF(WARNING, !iImage) << "Failed to cast IImage from image " << i;
EGLStream::IImage2D *iImage2D = interface_cast<EGLStream::IImage2D>(image);
LOG_IF(WARNING, !iImage2D) << "Failed to get IImage2D from image " << i;
if (!image || !iImage || !iImage2D) continue;
frames[i].id = iFrame->getNumber();
frames[i].ts = (double)iFrame->getTime() / 1e6; // nanoseconds to secs
v::chrono::toc(t0, 0, &stat_gfrm_);
// Display streamed images.
bool bEmptyAll = true;
if (!frames[i].img.empty()) {
stat_cnts_[i]++;
cv::imshow("SyncGrabber Viewer (left) - Copyright 2018 Polaris3D", frames[i].img); // SEGFAULT ERROR!!
bEmptyAll &= false;
cv::waitKey(5);
v::chrono::toc(t0, 0, &stat_disp_);
// Display statistics
showStatistics();
LOG(INFO) << "Done -- exiting.";
int main(int argc, const char *argv[])
FLAGS_alsologtostderr = true;
google::SetLogDestination(google::GLOG_INFO, "./");
google::InitGoogleLogging(argv[0]);
LOG(INFO) << "Executing Argus Sample: " << basename(argv[0]);
int captureIndex = -1;
if (argc > 1) {
captureIndex = atoi(argv[1]);
SyncGrabber syncGrabber(2, 1948, 1096, captureIndex);
syncGrabber.run();
return 0;
