I have to two x86_64 servers and they have identical hardware configurations. Each of them have a 100Gb CX5 in PCIe slot1. Both servers and VMs are running OEL7U8, UEK5 kernel. I intend to aggregate the two ports of CX5 bandwidth in hosts and VMs. So I enabled SR-IOV and created VFs in both hosts:
[rpmem@scaoda8m020 ~]$ lspci |grep Mella
af:00.0 Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex]
af:00.1 Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex]
af:00.2 Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex Virtual Function]
af:00.3 Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex Virtual Function]
af:00.6 Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex Virtual Function]
af:00.7 Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex Virtual Function]
While I was creating the VFs of CX5 I noticed that
af:00.2 and af:00.3 are the VFs from PF at af:00.0
af:00.6 and af:00.7 are the VFs from PF at af:00.1
So I PCI passthrough af:00.2 and af:00.6 to VM in each host
and in VM they looked like:
[root@scaoda8m020c2n1 network-scripts]# lspci |grep Mella
00:08.0 Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex Virtual Function]
00:09.0 Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex Virtual Function]
So I believe ens8 is the af:00.2(port 1), and ens9 is the af:00.6 (port 2) in hosts.
I have qspf28 cables connecting port1-port1, port2-port2 of CX5 in both physical servers.
I want to aggregate the two VF ports bandwidth to get better throughput (~200Gb?) so I bond them together mode=4: BONDING_OPTS=“mode=4 miimon=100 lacp_rate=1”
but somehow then the two VFs (in two VMs) can’t ping each other. In fact it also kill the bonding interface in the KVM hosts. But if I bond them with mode=1:
BONDING_OPTS=“mode=active-backup miimon=100 primary=ens8”
then they can ping each other successfully. Since mode=1 is active-backup so I believe only the ens8 is used normally. I also checked by ifup only ens8 or ens9 (without bonding) in both VMs and found they can ping each other successfully. So I think the individual connections are fine. That left the aggregation algorithm suspicious. Wonder is 802.3ad aggregation is supported in CX5? If this mode is not supported please suggest which mode I should use to aggregate CX5 two ports bandwidth. Please help me configure VFs (from two ports) in VM and get the max throughput.
Thanks,
Ken
