The example provided in deepstream-test-4 shows how to attach additional metadata, but these are not user-defined. What if I want to attach a custom Python object? Is there any way to do so using the bindings?
Hi @amr.mustafa
An easy way we found to attach custom meta to DeepStream meta was by adding a JSON string as NvDsEventMsgMeta
In this answer I added the code of how we do it on C:
But we also have a python element that adds custom metadata this way:
def custom_meta_copy_func(data, user_data):
user_meta = pyds.NvDsUserMeta.cast(data)
src_meta_data = user_meta.user_meta_data
srcmeta = pyds.NvDsEventMsgMeta.cast(src_meta_data)
dstmeta_ptr = pyds.memdup(
pyds.get_ptr(srcmeta), sys.getsizeof(
pyds.NvDsEventMsgMeta))
dstmeta = pyds.NvDsEventMsgMeta.cast(dstmeta_ptr)
dstmeta.otherAttrs = pyds.get_string(srcmeta.otherAttrs)
dstmeta.objectId = pyds.get_string(srcmeta.objectId)
return dstmeta
def custom_meta_free_func(data, user_data):
srcmeta = pyds.NvDsEventMsgMeta.cast(user_meta.user_meta_data)
pyds.free_buffer(srcmeta.otherAttrs)
pyds.free_buffer(srcmeta.objectId)
def _add_custom_meta_to_buffer(self, meta_str, buf):
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buf))
user_event_meta = pyds.nvds_acquire_user_meta_from_pool(batch_meta)
msg_meta = pyds.alloc_nvds_event_msg_meta()
msg_meta = pyds.NvDsEventMsgMeta.cast(msg_meta)
# We are using the otherAttrs field of NvDsEventMsgMeta to pass the
# custom JSON meta string downstream
msg_meta.otherAttrs = meta_str
# We distinguish our event meta from other DeepStream events by
# setting the objectId field
msg_meta.objectId = "custom"
if(user_event_meta):
user_event_meta.user_meta_data = msg_meta
user_event_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_EVENT_MSG_META
# Set callbacks for the event msg meta. These are needed to
# avoid memory leaks.
pyds.set_user_copyfunc(user_event_meta, custom_meta_copy_func)
pyds.set_user_releasefunc(
user_event_meta, custom_meta_free_func)
pyds.nvds_add_user_meta_to_batch(batch_meta, user_event_meta)
else:
Gst.error("Error in attaching event meta to buffer\n")
Hope this helps
This is so cool! I will give it a try when I get back to work. Let’s mark this as the solution. Thank you!
