It appears that as long as I do the cudaSetDevice once, later iterations will continue to be assigned to the same device. See the colored regions below:
[codebox]/*
#include <omp.h>
#include <stdio.h> // stdio functions are used since C++ streams aren’t necessarily thread safe
#include <cutil_inline.h>
using namespace std;
// a simple kernel that simply increments each array element by b
global void kernelAddConstant(int *g_a, const int b)
int idx = blockIdx.x * blockDim.x + threadIdx.x;
g_a[idx] += b;
// a predicate that checks whether each array elemen is set to its index plus b
int correctResult(int *data, const int n, const int b)
for(int i = 0; i < n; i++)
if(data[i] != i + b)
return 0;
return 1;
int main(int argc, char *argv)
int num_gpus = 0; // number of CUDA GPUs
// determine the number of CUDA capable GPUs
cudaGetDeviceCount(&num_gpus);
if(num_gpus < 1)
printf("no CUDA capable devices were detected\n");
return 1;
// display CPU and GPU configuration
printf("number of host CPUs:\t%d\n", omp_get_num_procs());
printf("number of CUDA devices:\t%d\n", num_gpus);
for(int i = 0; i < num_gpus; i++)
cudaDeviceProp dprop;
cudaGetDeviceProperties(&dprop, i);
printf(" %d: %s\n", i, dprop.name);
printf("---------------------------\n");
for( int j = 0; j < 20; j++ )
// initialize data
unsigned int n = num_gpus * 8192;
unsigned int nbytes = n * sizeof(int);
int *a = 0; // pointer to data on the CPU
int b = 3; // value by which the array is incremented
a = (int*)malloc(nbytes);
if(0 == a)
printf("couldn't allocate CPU memory\n");
return 1;
for(unsigned int i = 0; i < n; i++)
a[i] = i;
// run as many CPU threads as there are CUDA devices
// each CPU thread controls a different device, processing its
// portion of the data. It's possible to use more CPU threads
// than there are CUDA devices, in which case several CPU
// threads will be allocating resources and launching kernels
// on the same device. For example, try omp_set_num_threads(2*num_gpus);
// Recall that all variables declared inside an "omp parallel" scope are
// local to each CPU thread
omp_set_num_threads(num_gpus); // create as many CPU threads as there are CUDA devices
//omp_set_num_threads(2*num_gpus);// create twice as many CPU threads as there are CUDA devices
#pragma omp parallel
unsigned int cpu_thread_id = omp_get_thread_num();
unsigned int num_cpu_threads = omp_get_num_threads();
// set and check the CUDA device for this CPU thread
int gpu_id = -1;
if( j == 0 )
CUDA_SAFE_CALL(cudaSetDevice(cpu_thread_id % num_gpus)); // "% num_gpus" allows more CPU threads than GPU devices
CUDA_SAFE_CALL(cudaGetDevice(&gpu_id));
printf("CPU thread %d (of %d) uses CUDA device %d\n", cpu_thread_id, num_cpu_threads, gpu_id);
int *d_a = 0; // pointer to memory on the device associated with this CPU thread
int *sub_a = a + cpu_thread_id * n / num_cpu_threads; // pointer to this CPU thread's portion of data
unsigned int nbytes_per_kernel = nbytes / num_cpu_threads;
dim3 gpu_threads(128); // 128 threads per block
dim3 gpu_blocks(n / (gpu_threads.x * num_cpu_threads));
CUDA_SAFE_CALL(cudaMalloc((void**)&d_a, nbytes_per_kernel));
CUDA_SAFE_CALL(cudaMemset(d_a, 0, nbytes_per_kernel));
CUDA_SAFE_CALL(cudaMemcpy(d_a, sub_a, nbytes_per_kernel, cudaMemcpyHostToDevice));
kernelAddConstant<<<gpu_blocks, gpu_threads>>>(d_a, b);
CUDA_SAFE_CALL(cudaMemcpy(sub_a, d_a, nbytes_per_kernel, cudaMemcpyDeviceToHost));
CUDA_SAFE_CALL(cudaFree(d_a));
if(cudaSuccess != cudaGetLastError())
printf("%s\n", cudaGetErrorString(cudaGetLastError()));
// check the result
if(correctResult(a, n, b))
printf("Test PASSED\n");
else
printf("Test FAILED\n");
free(a); // free CPU memory
cudaThreadExit();
cutilExit(argc, argv);
return 0;
[/codebox]
Results in:
[codebox]number of host CPUs: 2
number of CUDA devices: 2
0: GeForce GTX 295
1: GeForce GTX 295
CPU thread 0 (of 2) uses CUDA device 0
CPU thread 1 (of 2) uses CUDA device 1
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Press ENTER to exit…[/codebox]
Is it safe to assume this behavior is reliable?
If this is the case, I can just
create a function called createContext() which will set the devices
Remove the setDevice from my function
call my function as many times as I want
As in:
[codebox]/*
#include <omp.h>
g_a[idx] += b;
return 0;
return 1;
int createContext()
if(num_gpus < 1)
return 1;
return 0;
createContext();
if(num_gpus < 1)
return 1;
// initialize data
if(0 == a)
return 1;
a[i] = i;
int gpu_id = -1;
// CUDA_SAFE_CALL(cudaSetDevice(cpu_thread_id % num_gpus)); // "% num_gpus" allows more CPU threads than GPU devices
// check the result
else
cudaThreadExit();
return 0;
[/codebox]
Which has the same result as the earlier code:
0: GeForce GTX 295
1: GeForce GTX 295
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED
Test PASSED[/codebox]
Any feedback would be appreciated!
