Hi to everyone,
I was trying to test CUDA with the OpenMP, on the SDK sample cudaOpenMP. After running the sample code (either directly through the SDK browser or after building it with the Microsoft Developer Studio 2008), I get the following results :
number of host CPUs: 8
number of CUDA devices: 2
0: GeForce GTX 295
1: GeForce GTX 295
CPU thread 0 (of 1) uses CUDA device 0
Test PASSED
Press ENTER to exit…
So my question is why do I take these results? I mean that since I have the GTX295, which is considered as 2 GPUs, I am expecting two CPU threads. To be precise if someone takes a look into the source code (see below) the number of threads for the OpenMP parallel region is set to the number of GPUs.
However no matter what value the number of GPUs takes, there is only one CPU thread. During debugging the code gives 2 as a result for num_gpus, but the result for num_cpu_threads is 1 ! Even if I change the value of omp_set_num_threads to, lets say 8, I get exactly the same results.
Has anyone faced the same problem ? Any ideas about it ?
Any help is appreciated because I am really stuck with this issue.
Also if anyone else has a GTX295 card could he/she post the results of the cudaOpenMP SDK sample test?
Thanks in advance.
[codebox]
Copyright 1993-2009 NVIDIA Corporation. All rights reserved.
NVIDIA Corporation and its licensors retain all intellectual property and
proprietary rights in and to this software and related documentation and
any modifications thereto. Any use, reproduction, disclosure, or distribution
of this software and related documentation without an express license
agreement from NVIDIA Corporation is strictly prohibited.
Multi-GPU sample using OpenMP for threading on the CPU side
needs a compiler that supports OpenMP 2.0
#include <omp.h>
#include <stdio.h> // stdio functions are used since C++ streams aren’t necessarily thread safe
#include <cutil_inline.h>
using namespace std;
// a simple kernel that simply increments each array element by b
global void kernelAddConstant(int *g_a, const int B)
int idx = blockIdx.x * blockDim.x + threadIdx.x;
g_a[idx] += b;
// a predicate that checks whether each array elemen is set to its index plus b
int correctResult(int *data, const int n, const int B)
for(int i = 0; i < n; i++)
if(data[i] != i + B)
return 0;
return 1;
int main(int argc, char *argv)
int num_gpus = 0; // number of CUDA GPUs
// determine the number of CUDA capable GPUs
cudaGetDeviceCount(&num_gpus);
if(num_gpus < 1)
printf("no CUDA capable devices were detected\n");
return 1;
// display CPU and GPU configuration
printf("number of host CPUs:\t%d\n", omp_get_num_procs());
printf("number of CUDA devices:\t%d\n", num_gpus);
for(int i = 0; i < num_gpus; i++)
cudaDeviceProp dprop;
cudaGetDeviceProperties(&dprop, i);
printf(" %d: %s\n", i, dprop.name);
printf("---------------------------\n");
// initialize data
unsigned int n = num_gpus * 8192;
unsigned int nbytes = n * sizeof(int);
int *a = 0; // pointer to data on the CPU
int b = 3; // value by which the array is incremented
a = (int*)malloc(nbytes);
if(0 == a)
printf("couldn't allocate CPU memory\n");
return 1;
for(unsigned int i = 0; i < n; i++)
a[i] = i;
// run as many CPU threads as there are CUDA devices
// each CPU thread controls a different device, processing its
// portion of the data. It's possible to use more CPU threads
// than there are CUDA devices, in which case several CPU
// threads will be allocating resources and launching kernels
// on the same device. For example, try omp_set_num_threads(2*num_gpus);
// Recall that all variables declared inside an "omp parallel" scope are
// local to each CPU thread
omp_set_num_threads(num_gpus); // create as many CPU threads as there are CUDA devices
//omp_set_num_threads(2*num_gpus);// create twice as many CPU threads as there are CUDA devices
#pragma omp parallel
unsigned int cpu_thread_id = omp_get_thread_num();
unsigned int num_cpu_threads = omp_get_num_threads();
// set and check the CUDA device for this CPU thread
int gpu_id = -1;
CUDA_SAFE_CALL(cudaSetDevice(cpu_thread_id % num_gpus)); // "% num_gpus" allows more CPU threads than GPU devices
CUDA_SAFE_CALL(cudaGetDevice(&gpu_id));
printf("CPU thread %d (of %d) uses CUDA device %d\n", cpu_thread_id, num_cpu_threads, gpu_id);
int *d_a = 0; // pointer to memory on the device associated with this CPU thread
int *sub_a = a + cpu_thread_id * n / num_cpu_threads; // pointer to this CPU thread's portion of data
unsigned int nbytes_per_kernel = nbytes / num_cpu_threads;
dim3 gpu_threads(128); // 128 threads per block
dim3 gpu_blocks(n / (gpu_threads.x * num_cpu_threads));
CUDA_SAFE_CALL(cudaMalloc((void**)&d_a, nbytes_per_kernel));
CUDA_SAFE_CALL(cudaMemset(d_a, 0, nbytes_per_kernel));
CUDA_SAFE_CALL(cudaMemcpy(d_a, sub_a, nbytes_per_kernel, cudaMemcpyHostToDevice));
kernelAddConstant<<<gpu_blocks, gpu_threads>>>(d_a, B);
CUDA_SAFE_CALL(cudaMemcpy(sub_a, d_a, nbytes_per_kernel, cudaMemcpyDeviceToHost));
CUDA_SAFE_CALL(cudaFree(d_a));
if(cudaSuccess != cudaGetLastError())
printf("%s\n", cudaGetErrorString(cudaGetLastError()));
// check the result
if(correctResult(a, n, B))
printf("Test PASSED\n");
else
printf("Test FAILED\n");
free(a); // free CPU memory
cudaThreadExit();
cutilExit(argc, argv);
return 0;
} ';[/codebox]
