FYI – A strange and annoying behavior (CUDA 2.3).
When compiling with nvcc, “#pragma omp parallel” doesn’t work in a templated function (i.e. only 1 thread executes).
It works fine in a non-template function.
When compiling directly with Visual C++ it works, as expected, in either type of function.
Test case is trivial modification of classic cudaOpenMP example.
-Mike
[codebox]/*
Copyright 1993-2009 NVIDIA Corporation. All rights reserved.
NVIDIA Corporation and its licensors retain all intellectual property and
proprietary rights in and to this software and related documentation and
any modifications thereto. Any use, reproduction, disclosure, or distribution
of this software and related documentation without an express license
agreement from NVIDIA Corporation is strictly prohibited.
Multi-GPU sample using OpenMP for threading on the CPU side
needs a compiler that supports OpenMP 2.0
#include <omp.h>
#include <stdio.h> // stdio functions are used since C++ streams aren’t necessarily thread safe
#include <cutil_inline.h>
using namespace std;
// a simple kernel that simply increments each array element by b
global void kernelAddConstant(int *g_a, const int B)
int idx = blockIdx.x * blockDim.x + threadIdx.x;
g_a[idx] += b;
// a predicate that checks whether each array elemen is set to its index plus b
int correctResult(int *data, const int n, const int B)
for(int i = 0; i < n; i++)
if(data[i] != i + B)
return 0;
return 1;
int testFunc1( int n )
omp_set_num_threads( n );
int i = omp_get_thread_num();
int n = omp_get_num_threads();
printf_s("testFunc1: Hello from thread %d, num threads = %d\n", i, n);
return 0;
template
int testFunc2( T n )
printf_s("testFunc2: Hello from thread %d, num threads = %d\n", i, n);
return 0;
int main(int argc, char *argv)
int num_gpus = 0; // number of CUDA GPUs
testFunc1( 4 );
testFunc2( 3 );
// determine the number of CUDA capable GPUs
cudaGetDeviceCount(&num_gpus);
if(num_gpus < 1)
printf("no CUDA capable devices were detected\n");
return 1;
// display CPU and GPU configuration
printf("number of host CPUs:\t%d\n", omp_get_num_procs());
printf("number of CUDA devices:\t%d\n", num_gpus);
for(int i = 0; i < num_gpus; i++)
cudaDeviceProp dprop;
cudaGetDeviceProperties(&dprop, i);
printf(" %d: %s\n", i, dprop.name);
printf("---------------------------\n");
// initialize data
unsigned int n = num_gpus * 8192;
unsigned int nbytes = n * sizeof(int);
int *a = 0; // pointer to data on the CPU
int b = 3; // value by which the array is incremented
a = (int*)malloc(nbytes);
if(0 == a)
printf("couldn't allocate CPU memory\n");
return 1;
for(unsigned int i = 0; i < n; i++)
a[i] = i;
// run as many CPU threads as there are CUDA devices
// each CPU thread controls a different device, processing its
// portion of the data. It's possible to use more CPU threads
// than there are CUDA devices, in which case several CPU
// threads will be allocating resources and launching kernels
// on the same device. For example, try omp_set_num_threads(2*num_gpus);
// Recall that all variables declared inside an "omp parallel" scope are
// local to each CPU thread
omp_set_num_threads(num_gpus); // create as many CPU threads as there are CUDA devices
//omp_set_num_threads(2*num_gpus);// create twice as many CPU threads as there are CUDA devices
printf( "Before parallel section, num_threads: %d max_threads: %d\n",
omp_get_num_threads(), omp_get_max_threads() );
unsigned int cpu_thread_id = omp_get_thread_num();
unsigned int num_cpu_threads = omp_get_num_threads();
// set and check the CUDA device for this CPU thread
int gpu_id = -1;
CUDA_SAFE_CALL(cudaSetDevice(cpu_thread_id % num_gpus)); // "% num_gpus" allows more CPU threads than GPU devices
CUDA_SAFE_CALL(cudaGetDevice(&gpu_id));
printf("CPU thread %d (of %d) uses CUDA device %d\n", cpu_thread_id, num_cpu_threads, gpu_id);
int *d_a = 0; // pointer to memory on the device associated with this CPU thread
int *sub_a = a + cpu_thread_id * n / num_cpu_threads; // pointer to this CPU thread's portion of data
unsigned int nbytes_per_kernel = nbytes / num_cpu_threads;
dim3 gpu_threads(128); // 128 threads per block
dim3 gpu_blocks(n / (gpu_threads.x * num_cpu_threads));
CUDA_SAFE_CALL(cudaMalloc((void**)&d_a, nbytes_per_kernel));
CUDA_SAFE_CALL(cudaMemset(d_a, 0, nbytes_per_kernel));
CUDA_SAFE_CALL(cudaMemcpy(d_a, sub_a, nbytes_per_kernel, cudaMemcpyHostToDevice));
kernelAddConstant<<<gpu_blocks, gpu_threads>>>(d_a, B);
CUDA_SAFE_CALL(cudaMemcpy(sub_a, d_a, nbytes_per_kernel, cudaMemcpyDeviceToHost));
CUDA_SAFE_CALL(cudaFree(d_a));
if(cudaSuccess != cudaGetLastError())
printf("%s\n", cudaGetErrorString(cudaGetLastError()));
// check the result
if(correctResult(a, n, B))
printf("Test PASSED\n");
else
printf("Test FAILED\n");
free(a); // free CPU memory
cudaThreadExit();
cutilExit(argc, argv);
return 0;
[/codebox]
