I have modified furushchev’s solution in “true” systemd way and become able to mount SSD drive as rootfs without overlay and reboot problems.
- Xavier was flashed and software was installed using SDKManager.
- Rootfs from eMMC was copied to SSD ( with one ext4 partition in my case):
#!/bin/bash sudo mount /dev/nvme0n1p1 /mnt sudo rsync -aAXv / --exclude={"/dev/*","/proc/*","/sys/*","/tmp/*","/run/*","/mnt/*","/media/*","/lost+found"} /mnt
- Then we need systemd unit, loading just after unmounting initrd image and mounting real rootfs, before any other targets running with systemd from real rootfs. Something like following:
setssdroot.service:
[Unit] Description=Change rootfs to SSD in M.2 key M slot (nvme0n1p1) DefaultDependencies=no Conflicts=shutdown.target After=systemd-remount-fs.service Before=local-fs-pre.target local-fs.target shutdown.target Wants=local-fs-pre.target ConditionPathExists=/dev/nvme0n1p1 ConditionVirtualization=!container [Service] Type=oneshot RemainAfterExit=yes ExecStart=/sbin/setssdroot.sh [Install] WantedBy=default.target
I added condition to start only if SSD is installed ( /dev/nvme0n1p1 exists).
setssdroot.sh:
#!/bin/sh NVME_DRIVE="/dev/nvme0n1p1" CHROOT_PATH="/nvmeroot" INITBIN=/lib/systemd/systemd EXT4_OPT="-o defaults -o errors=remount-ro -o discard" modprobe ext4 #modprobe fuse mkdir -p ${CHROOT_PATH} mount -t ext4 ${EXT4_OPT} ${NVME_DRIVE} ${CHROOT_PATH} cd ${CHROOT_PATH} /bin/systemctl --no-block switch-root ${CHROOT_PATH}
- New target was installed with following command:
#!/bin/sh sudo cp setssdroot.service /etc/systemd/system sudo cp setssdroot.sh /sbin sudo chmod 777 /sbin/setssdroot.sh systemctl daemon-reload sudo systemctl enable setssdroot.service
As a result, after reboot systemd mounts /dev/nvme0n1p1 as “/”. We are working with system (except kernel and initrd) from SSD and have “recovery” system on eMMC.
