If rootfs from SSD is mounted, you will see SD drive on desktop (Ubuntu gives SD icon to eMMC).
systemd-analize result attached.
Now we need to find how to load new kernel from SSD with flashed kernel’s kexec :).
| Native boot from M.2 NVME SSD | 76 | 23543 | October 6, 2021 | |
| NX DevKit Boot Process: First Impressions | 21 | 4883 | July 8, 2020 | |
| Jetson xavier xn stuck in boot loop after trying to initrd flash to nvme SSD | 9 | 1458 | January 16, 2023 | |
| Flashing JetPack on an NVMe SSD on Xavier AGX | 9 | 5417 | August 23, 2023 | |
| XNX could not boot from NVMe with L4T 32.6.1 | 7 | 1492 | September 3, 2021 | |
| Does JetsonXavierNx support kernel boot rootfs from emmc when kernel boot from nvme fails? | 23 | 697 | January 12, 2024 | |
| Jetson Xavier Boot on SSD with Cboot | 19 | 4709 | August 4, 2021 | |
| Issue with flashing an NVMe ssd with initrd | 10 | 3974 | August 9, 2021 | |
| How does Xavier boot the system from NVME SSD | 6 | 1508 | November 15, 2020 | |
| Is it possible to set up 5.0.2 boot from nvme by only flashing eMMC first? | 27 | 3132 | January 28, 2023 |
