How to Boot from NVMe SSD?
USB firmware is needed because otherwise the usb port will not work.
If you use initrd generated without firmware hook, system do will boot, you will see login screen, but without keyboard it’s useless :).
P.S. I will try APPEND parameter combinations later on weekends.
