I need it to extend the root partition easily
Moving to Jetson Nano forum for resolution.
hello antoniosapuppo,
may I know which JetPack release you’re used, also, which Nano platform you’re working with, is it Nano-SD?
BTW,
what’s your actual use-case of LVM2, could you please refer to below for verification?
thanks
i use JP 4.4 L4T 32.4.3, now I am using the microSD module, in production we will only have 16 GB on eMMC
I’ve never tried with LVM before for storage device management.
FYI,
please also refer to developer guide and check Partition Configuration session.
it’s APP partition which contains the RootFS, there’s also have size definition by APPSIZE.
thanks
