I tried to build cuda-gdb on TX1. I was able to build it successfully (with some minor changes), but can’t run it. It crashed on startup with “Attempt to register unknown architecture (2)". Any clues?
Related topics
| CUDA-gdb errors | 4 | 2872 | April 24, 2012 | |
| Program does only work when started with cuda-gdb | 3 | 654 | August 10, 2016 | |
| cuda-gdb threw make | 0 | 908 | December 28, 2009 | |
| cuda without x11 x11 cuda gdb cuda-gdb | 4 | 17170 | October 17, 2009 | |
| Kernel code execution causes segmentation fault in cuda-dbg but not when executed standalone | 4 | 835 | July 3, 2024 | |
| CUDA-GDB not work on debian | 6 | 967 | January 11, 2024 | |
| There is no aarch64-unknown-linux-gnu-gdb in gcc-4.8.5-aarch64 toolchain | 3 | 1187 | October 18, 2021 | |
| CUDA-GDB: The CUDA driver has hit an internal error | 1 | 722 | March 2, 2021 | |
| cuda-gdb missing from CUDA toolkit 9 on OS X? | 19 | 4825 | March 10, 2019 | |
| Exception while debugging. How to upgrade cuda-gdb? | 4 | 1708 | October 18, 2021 |
