I’m trying to build dlib from the source in DeepStream-l4t docker container on a jetson nano. while building CMake is detecting Cuda-10.2. but it’s not enabling Cuda since cudnn not found.
Is DeepStream-l4t contains cudnn files or do I have to install it? Please help me out. Im not sure from where to download cudnn files for aarch64 system.
The build log is
Found CUDA: /usr/local/cuda-10.2 (found suitable version “10.2”, minimum required is “7.5”)
– Looking for cuDNN install…
– *** cuDNN V5.0 OR GREATER NOT FOUND.
– *** Dlib requires cuDNN V5.0 OR GREATER. Since cuDNN is not found DLIB WILL NOT USE CUDA. ***
– *** If you have cuDNN then set CMAKE_PREFIX_PATH to include cuDNN’s folder. ***
– Disabling CUDA support for dlib. DLIB WILL NOT USE CUDA
cuDNN is pre-installed in the Deepstream-l4t image.
The root cause is that cuDNN version information is moved from cudnn.h into cudnn_version.h.
So you may need some update in the dlib CMakeLists.txt.’
I replaced cudnn.h to cudnn_version.h in
./dlib/dlib/cmake_utils/test_for_cudnn/find_cudnn.txt but it didn’t work.
and also I did a quick search for both cudnn.h and cudnn_version.h using
find / -type f -name cudnn_version.h in
nvcr.io/nvidia/deepstream-l4t:5.0-dp-20.04-base image I didn’t find these files.
Can you please help me out on this. Thanks
Sure.
Would you mind to share which dlib version do you use first?
I tried with 19.16 and 19.4, both was giving same errors.
Here are some detail of the failure.
The cuDNN cannot be included since the cudnn_test is failed.
The reason why cudnn_test failed is that some API has changed in the cuDNN v8.0.
So the corresponding update is needed for the dlib to ensure the compatibility:
root@nvidia-desktop:/home/nvidia/dlib-19.16/dlib/cmake_utils/test_for_cudnn# make
Scanning dependencies of target cudnn_test
[ 50%] Building CXX object CMakeFiles/cudnn_test.dir/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp.o
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp: In member function 'void dlib::cuda::tensor_conv::setup(const dlib::tensor&, const dlib::tensor&, int, int, int, int)':
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:851:57: error: 'CUDNN_CONVOLUTION_FWD_PREFER_FASTEST' was not declared in this scope
dnn_prefer_fastest_algorithms()?CUDNN_CONVOLUTION_FWD_PREFER_FASTEST:CUDNN_CONVOLUTION_FWD_NO_WORKSPACE,
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:43:33: note: in definition of macro 'CHECK_CUDNN'
const cudnnStatus_t error = call; \
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:851:57: note: suggested alternative: 'CUDNN_CONVOLUTION_BWD_FILTER_ALGO_3'
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:851:94: error: 'CUDNN_CONVOLUTION_FWD_NO_WORKSPACE' was not declared in this scope
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:851:94: note: suggested alternative: 'CUDNN_CONVOLUTION_FWD_ALGO_WINOGRAD'
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:845:29: error: 'cudnnGetConvolutionForwardAlgorithm' was not declared in this scope
CHECK_CUDNN(cudnnGetConvolutionForwardAlgorithm(
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:845:29: note: suggested alternative: 'cudnnGetConvolutionForwardAlgorithm_v7'
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:873:57: error: 'CUDNN_CONVOLUTION_BWD_DATA_PREFER_FASTEST' was not declared in this scope
dnn_prefer_fastest_algorithms()?CUDNN_CONVOLUTION_BWD_DATA_PREFER_FASTEST:CUDNN_CONVOLUTION_BWD_DATA_NO_WORKSPACE,
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:873:57: note: suggested alternative: 'CUDNN_CONVOLUTION_BWD_DATA_ALGO_FFT'
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:873:99: error: 'CUDNN_CONVOLUTION_BWD_DATA_NO_WORKSPACE' was not declared in this scope
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:873:99: note: suggested alternative: 'CUDNN_CONVOLUTION_BWD_DATA_ALGO_WINOGRAD'
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:867:29: error: 'cudnnGetConvolutionBackwardDataAlgorithm' was not declared in this scope
CHECK_CUDNN(cudnnGetConvolutionBackwardDataAlgorithm(
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:867:29: note: suggested alternative: 'cudnnGetConvolutionBackwardDataAlgorithm_v7'
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:896:57: error: 'CUDNN_CONVOLUTION_BWD_FILTER_PREFER_FASTEST' was not declared in this scope
dnn_prefer_fastest_algorithms()?CUDNN_CONVOLUTION_BWD_FILTER_PREFER_FASTEST:CUDNN_CONVOLUTION_BWD_FILTER_NO_WORKSPACE,
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:896:57: note: suggested alternative: 'CUDNN_CONVOLUTION_BWD_FILTER_ALGO_FFT'
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:896:101: error: 'CUDNN_CONVOLUTION_BWD_FILTER_NO_WORKSPACE' was not declared in this scope
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:896:101: note: suggested alternative: 'CUDNN_CONVOLUTION_BWD_FILTER_ALGO_WINOGRAD'
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:890:29: error: 'cudnnGetConvolutionBackwardFilterAlgorithm' was not declared in this scope
CHECK_CUDNN(cudnnGetConvolutionBackwardFilterAlgorithm(
/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp:890:29: note: suggested alternative: 'cudnnGetConvolutionBackwardFilterAlgorithm_v7'
CMakeFiles/cudnn_test.dir/build.make:62: recipe for target 'CMakeFiles/cudnn_test.dir/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp.o' failed
make[2]: *** [CMakeFiles/cudnn_test.dir/home/nvidia/dlib-19.16/dlib/cuda/cudnn_dlibapi.cpp.o] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/cudnn_test.dir/all' failed
make[1]: *** [CMakeFiles/cudnn_test.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
It looks like the latest source on the GitHub already has the cuDNN v8.0 support.
Please compile it with the GitHub source directly.
