I’m trying to install dlib libray (wget http://dlib.net/files/dlib-19.17.tar.bz2) on the Jetson AGX Xavier.
I downloaded and uncompressed the source code for dlib. Before compiling it, I commented the “forward_algo = forward_best_algo;” line in the dlib/cuda/cudnn_dlibapi.cpp file.
After that, I run this command to compile and install dlib:
sudo python3 setup.py install
but it won’t work.
The output I get by running the previous command is:
$ sudo python3 setup.py install
running install
running bdist_egg
running egg_info
creating dlib.egg-info
writing dlib.egg-info/PKG-INFO
writing dependency_links to dlib.egg-info/dependency_links.txt
writing top-level names to dlib.egg-info/top_level.txt
writing manifest file ‘dlib.egg-info/SOURCES.txt’
package init file ‘dlib/init.py’ not found (or not a regular file)
reading manifest file ‘dlib.egg-info/SOURCES.txt’
reading manifest template ‘MANIFEST.in’
installing library code to build/bdist.linux-aarch64/egg
running install_lib
running build_py
running build_ext
Building extension for Python 3.6.9 (default, Nov 7 2019, 10:44:02)
Invoking CMake setup: ‘cmake /home/xavier/dlib-19.17/tools/python -DCMAKE_LIBRARY_OUTPUT_DIRECTORY=/home/xavier/dlib-19.17/build/lib.linux-aarch64-3.6 -DPYTHON_EXECUTABLE=/usr/bin/python3 -DCMAKE_BUILD_TYPE=Release’
CMake Warning (dev) in CMakeLists.txt:
No project() command is present. The top-level CMakeLists.txt file must
contain a literal, direct call to the project() command. Add a line of
code such as
project(ProjectName)
near the top of the file, but after cmake_minimum_required().
CMake is pretending there is a “project(Project)” command on the first
line.
This warning is for project developers. Use -Wno-dev to suppress it.
– The C compiler identification is GNU 7.4.0
– The CXX compiler identification is GNU 7.4.0
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Found PythonInterp: /usr/bin/python3 (found version “3.6.9”)
– Found PythonLibs: /usr/lib/aarch64-linux-gnu/libpython3.6m.so
– Performing Test HAS_CPP14_FLAG
– Performing Test HAS_CPP14_FLAG - Success
– pybind11 v2.2.2
– Using CMake version: 3.15.2
– Compiling dlib version: 19.17.0
– Looking for pthread.h
– Looking for pthread.h - found
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
– Looking for pthread_create in pthreads
– Looking for pthread_create in pthreads - not found
– Looking for pthread_create in pthread - found
– Found Threads: TRUE
– Found X11: /usr/include
– Looking for XOpenDisplay in /usr/lib/aarch64-linux-gnu/libX11.so;/usr/lib/aarch64-linux-gnu/libXext.so
– Looking for XOpenDisplay in /usr/lib/aarch64-linux-gnu/libX11.so;/usr/lib/aarch64-linux-gnu/libXext.so - found
– Looking for gethostbyname
– Looking for gethostbyname - found
– Looking for connect
– Looking for connect - found
– Looking for remove
– Looking for remove - found
– Looking for shmat
– Looking for shmat - found
– Looking for IceConnectionNumber in ICE
– Looking for IceConnectionNumber in ICE - found
– Looking for png_create_read_struct
– Looking for png_create_read_struct - found
– Looking for jpeg_read_header
– Looking for jpeg_read_header - found
– Searching for BLAS and LAPACK
– Found PkgConfig: /usr/bin/pkg-config (found version “0.29.1”)
– Checking for module ‘cblas’
– No package ‘cblas’ found
– Checking for module ‘lapack’
– Found lapack, version 0.2.20+ds
– Looking for sys/types.h
– Looking for sys/types.h - found
– Looking for stdint.h
– Looking for stdint.h - found
– Looking for stddef.h
– Looking for stddef.h - found
– Check size of void*
– Check size of void* - done
– Found OpenBLAS library
– Looking for sgetrf_single
– Looking for sgetrf_single - found
– Using OpenBLAS’s built in LAPACK
– Looking for cblas_ddot
– Looking for cblas_ddot - found
– Looking for sgesv
– Looking for sgesv - not found
– Looking for sgesv_
– Looking for sgesv_ - not found
– Found CUDA: /usr/local/cuda (found suitable version “10.0”, minimum required is “7.5”)
– Looking for cuDNN install…
– Found cuDNN: /usr/local/cuda/lib64/libcudnn.so
– Building a CUDA test project to see if your compiler is compatible with CUDA…
– Checking if you have the right version of cuDNN installed.
– Enabling CUDA support for dlib. DLIB WILL USE CUDA
– C++11 activated.
– Configuring done
– Generating done
– Build files have been written to: /home/xavier/dlib-19.17/build/temp.linux-aarch64-3.6
Invoking CMake build: ‘cmake --build . --config Release – -j8’
[ 2%] Building NVCC (Device) object dlib_build/CMakeFiles/dlib.dir/cuda/dlib_generated_cusolver_dlibapi.cu.o
[ 2%] Building NVCC (Device) object dlib_build/CMakeFiles/dlib.dir/cuda/dlib_generated_cuda_dlib.cu.o
Scanning dependencies of target dlib
[ 3%] Building CXX object dlib_build/CMakeFiles/dlib.dir/base64/base64_kernel_1.cpp.o
[ 4%] Building CXX object dlib_build/CMakeFiles/dlib.dir/bigint/bigint_kernel_1.cpp.o
[ 5%] Building CXX object dlib_build/CMakeFiles/dlib.dir/bigint/bigint_kernel_2.cpp.o
[ 6%] Building CXX object dlib_build/CMakeFiles/dlib.dir/bit_stream/bit_stream_kernel_1.cpp.o
[ 7%] Building CXX object dlib_build/CMakeFiles/dlib.dir/entropy_decoder/entropy_decoder_kernel_1.cpp.o
[ 8%] Building CXX object dlib_build/CMakeFiles/dlib.dir/entropy_decoder/entropy_decoder_kernel_2.cpp.o
[ 9%] Building CXX object dlib_build/CMakeFiles/dlib.dir/entropy_encoder/entropy_encoder_kernel_1.cpp.o
[ 10%] Building CXX object dlib_build/CMakeFiles/dlib.dir/entropy_encoder/entropy_encoder_kernel_2.cpp.o
[ 11%] Building CXX object dlib_build/CMakeFiles/dlib.dir/md5/md5_kernel_1.cpp.o
[ 12%] Building CXX object dlib_build/CMakeFiles/dlib.dir/tokenizer/tokenizer_kernel_1.cpp.o
[ 13%] Building CXX object dlib_build/CMakeFiles/dlib.dir/unicode/unicode.cpp.o
[ 15%] Building CXX object dlib_build/CMakeFiles/dlib.dir/data_io/image_dataset_metadata.cpp.o
[ 16%] Building CXX object dlib_build/CMakeFiles/dlib.dir/data_io/mnist.cpp.o
[ 17%] Building CXX object dlib_build/CMakeFiles/dlib.dir/global_optimization/global_function_search.cpp.o
[ 18%] Building CXX object dlib_build/CMakeFiles/dlib.dir/filtering/kalman_filter.cpp.o
[ 19%] Building CXX object dlib_build/CMakeFiles/dlib.dir/test_for_odr_violations.cpp.o
[ 20%] Building CXX object dlib_build/CMakeFiles/dlib.dir/svm/auto.cpp.o
[ 21%] Building CXX object dlib_build/CMakeFiles/dlib.dir/sockets/sockets_kernel_1.cpp.o
[ 22%] Building CXX object dlib_build/CMakeFiles/dlib.dir/bsp/bsp.cpp.o
[ 23%] Building CXX object dlib_build/CMakeFiles/dlib.dir/dir_nav/dir_nav_kernel_1.cpp.o
[ 24%] Building CXX object dlib_build/CMakeFiles/dlib.dir/dir_nav/dir_nav_kernel_2.cpp.o
[ 25%] Building CXX object dlib_build/CMakeFiles/dlib.dir/dir_nav/dir_nav_extensions.cpp.o
[ 26%] Building CXX object dlib_build/CMakeFiles/dlib.dir/linker/linker_kernel_1.cpp.o
[ 27%] Building CXX object dlib_build/CMakeFiles/dlib.dir/logger/extra_logger_headers.cpp.o
[ 29%] Building CXX object dlib_build/CMakeFiles/dlib.dir/logger/logger_kernel_1.cpp.o
[ 30%] Building CXX object dlib_build/CMakeFiles/dlib.dir/logger/logger_config_file.cpp.o
[ 31%] Building CXX object dlib_build/CMakeFiles/dlib.dir/misc_api/misc_api_kernel_1.cpp.o
[ 32%] Building CXX object dlib_build/CMakeFiles/dlib.dir/misc_api/misc_api_kernel_2.cpp.o
[ 33%] Building CXX object dlib_build/CMakeFiles/dlib.dir/sockets/sockets_extensions.cpp.o
[ 34%] Building CXX object dlib_build/CMakeFiles/dlib.dir/sockets/sockets_kernel_2.cpp.o
[ 35%] Building CXX object dlib_build/CMakeFiles/dlib.dir/sockstreambuf/sockstreambuf.cpp.o
[ 36%] Building CXX object dlib_build/CMakeFiles/dlib.dir/sockstreambuf/sockstreambuf_unbuffered.cpp.o
[ 37%] Building CXX object dlib_build/CMakeFiles/dlib.dir/server/server_kernel.cpp.o
[ 38%] Building CXX object dlib_build/CMakeFiles/dlib.dir/server/server_iostream.cpp.o
[ 39%] Building CXX object dlib_build/CMakeFiles/dlib.dir/server/server_http.cpp.o
[ 40%] Building CXX object dlib_build/CMakeFiles/dlib.dir/threads/multithreaded_object_extension.cpp.o
[ 41%] Building CXX object dlib_build/CMakeFiles/dlib.dir/threads/threaded_object_extension.cpp.o
[ 43%] Building CXX object dlib_build/CMakeFiles/dlib.dir/threads/threads_kernel_1.cpp.o
[ 44%] Building CXX object dlib_build/CMakeFiles/dlib.dir/threads/threads_kernel_2.cpp.o
[ 45%] Building CXX object dlib_build/CMakeFiles/dlib.dir/threads/threads_kernel_shared.cpp.o
[ 46%] Building CXX object dlib_build/CMakeFiles/dlib.dir/threads/thread_pool_extension.cpp.o
[ 47%] Building CXX object dlib_build/CMakeFiles/dlib.dir/threads/async.cpp.o
[ 48%] Building CXX object dlib_build/CMakeFiles/dlib.dir/timer/timer.cpp.o
[ 49%] Building CXX object dlib_build/CMakeFiles/dlib.dir/stack_trace.cpp.o
[ 50%] Building CXX object dlib_build/CMakeFiles/dlib.dir/cuda/cpu_dlib.cpp.o
[ 51%] Building CXX object dlib_build/CMakeFiles/dlib.dir/cuda/tensor_tools.cpp.o
[ 52%] Building CXX object dlib_build/CMakeFiles/dlib.dir/gui_widgets/fonts.cpp.o
[ 53%] Building CXX object dlib_build/CMakeFiles/dlib.dir/gui_widgets/widgets.cpp.o
[ 54%] Building CXX object dlib_build/CMakeFiles/dlib.dir/gui_widgets/drawable.cpp.o
[ 55%] Building CXX object dlib_build/CMakeFiles/dlib.dir/gui_widgets/canvas_drawing.cpp.o
[ 56%] Building CXX object dlib_build/CMakeFiles/dlib.dir/gui_widgets/style.cpp.o
[ 58%] Building CXX object dlib_build/CMakeFiles/dlib.dir/gui_widgets/base_widgets.cpp.o
[ 59%] Building CXX object dlib_build/CMakeFiles/dlib.dir/gui_core/gui_core_kernel_1.cpp.o
[ 60%] Building CXX object dlib_build/CMakeFiles/dlib.dir/gui_core/gui_core_kernel_2.cpp.o
[ 61%] Building CXX object dlib_build/CMakeFiles/dlib.dir/image_loader/png_loader.cpp.o
[ 62%] Building CXX object dlib_build/CMakeFiles/dlib.dir/image_saver/save_png.cpp.o
[ 63%] Building CXX object dlib_build/CMakeFiles/dlib.dir/image_loader/jpeg_loader.cpp.o
[ 64%] Building CXX object dlib_build/CMakeFiles/dlib.dir/image_saver/save_jpeg.cpp.o
[ 65%] Building CXX object dlib_build/CMakeFiles/dlib.dir/cuda/cudnn_dlibapi.cpp.o
[ 66%] Building CXX object dlib_build/CMakeFiles/dlib.dir/cuda/cublas_dlibapi.cpp.o
[ 67%] Building CXX object dlib_build/CMakeFiles/dlib.dir/cuda/curand_dlibapi.cpp.o
[ 68%] Building CXX object dlib_build/CMakeFiles/dlib.dir/cuda/cuda_data_ptr.cpp.o
[ 69%] Building CXX object dlib_build/CMakeFiles/dlib.dir/cuda/gpu_data.cpp.o
[ 70%] Linking CXX static library libdlib.a
[ 70%] Built target dlib
Scanning dependencies of target dlib_python
[ 72%] Building CXX object CMakeFiles/dlib_python.dir/src/dlib.cpp.o
[ 73%] Building CXX object CMakeFiles/dlib_python.dir/src/matrix.cpp.o
[ 74%] Building CXX object CMakeFiles/dlib_python.dir/src/vector.cpp.o
[ 75%] Building CXX object CMakeFiles/dlib_python.dir/src/svm_c_trainer.cpp.o
[ 76%] Building CXX object CMakeFiles/dlib_python.dir/src/svm_rank_trainer.cpp.o
[ 77%] Building CXX object CMakeFiles/dlib_python.dir/src/decision_functions.cpp.o
[ 78%] Building CXX object CMakeFiles/dlib_python.dir/src/other.cpp.o
[ 79%] Building CXX object CMakeFiles/dlib_python.dir/src/basic.cpp.o
[ 80%] Building CXX object CMakeFiles/dlib_python.dir/src/cca.cpp.o
[ 81%] Building CXX object CMakeFiles/dlib_python.dir/src/sequence_segmenter.cpp.o
[ 82%] Building CXX object CMakeFiles/dlib_python.dir/src/svm_struct.cpp.o
[ 83%] Building CXX object CMakeFiles/dlib_python.dir/src/image.cpp.o
[ 84%] Building CXX object CMakeFiles/dlib_python.dir/src/image2.cpp.o
[ 86%] Building CXX object CMakeFiles/dlib_python.dir/src/image3.cpp.o
[ 87%] Building CXX object CMakeFiles/dlib_python.dir/src/image4.cpp.o
[ 88%] Building CXX object CMakeFiles/dlib_python.dir/src/rectangles.cpp.o
[ 89%] Building CXX object CMakeFiles/dlib_python.dir/src/object_detection.cpp.o
[ 90%] Building CXX object CMakeFiles/dlib_python.dir/src/shape_predictor.cpp.o
[ 91%] Building CXX object CMakeFiles/dlib_python.dir/src/correlation_tracker.cpp.o
[ 92%] Building CXX object CMakeFiles/dlib_python.dir/src/face_recognition.cpp.o
[ 93%] Building CXX object CMakeFiles/dlib_python.dir/src/cnn_face_detector.cpp.o
[ 94%] Building CXX object CMakeFiles/dlib_python.dir/src/global_optimization.cpp.o
[ 95%] Building CXX object CMakeFiles/dlib_python.dir/src/image_dataset_metadata.cpp.o
[ 96%] Building CXX object CMakeFiles/dlib_python.dir/src/numpy_returns.cpp.o
[ 97%] Building CXX object CMakeFiles/dlib_python.dir/src/line.cpp.o
[ 98%] Building CXX object CMakeFiles/dlib_python.dir/src/gui.cpp.o
[100%] Linking CXX shared module /home/xavier/dlib-19.17/build/lib.linux-aarch64-3.6/dlib.cpython-36m-aarch64-linux-gnu.so
/usr/local/cuda/lib64/libcudnn.so: error adding symbols: File in wrong format
collect2: error: ld returned 1 exit status
CMakeFiles/dlib_python.dir/build.make:475: recipe for target ‘/home/xavier/dlib-19.17/build/lib.linux-aarch64-3.6/dlib.cpython-36m-aarch64-linux-gnu.so’ failed
make[2]: *** [/home/xavier/dlib-19.17/build/lib.linux-aarch64-3.6/dlib.cpython-36m-aarch64-linux-gnu.so] Error 1
CMakeFiles/Makefile2:80: recipe for target ‘CMakeFiles/dlib_python.dir/all’ failed
make[1]: *** [CMakeFiles/dlib_python.dir/all] Error 2
Makefile:83: recipe for target ‘all’ failed
make: *** [all] Error 2
File “setup.py”, line 261, in
‘Topic :: Software Development’,
File “/usr/local/lib/python3.6/dist-packages/setuptools/init.py”, line 145, in setup
return distutils.core.setup(**attrs)
File “/usr/lib/python3.6/distutils/core.py”, line 148, in setup
dist.run_commands()
File “/usr/lib/python3.6/distutils/dist.py”, line 955, in run_commands
self.run_command(cmd)
File “/usr/lib/python3.6/distutils/dist.py”, line 974, in run_command
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/install.py”, line 67, in run
self.do_egg_install()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/install.py”, line 109, in do_egg_install
self.run_command(‘bdist_egg’)
File “/usr/lib/python3.6/distutils/cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/bdist_egg.py”, line 172, in run
cmd = self.call_command(‘install_lib’, warn_dir=0)
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/bdist_egg.py”, line 158, in call_command
self.run_command(cmdname)
cmd_obj.run()
File “/usr/local/lib/python3.6/dist-packages/setuptools/command/install_lib.py”, line 11, in run
self.build()
File “/usr/lib/python3.6/distutils/command/install_lib.py”, line 109, in build
self.run_command(‘build_ext’)
cmd_obj.run()
File “setup.py”, line 135, in run
self.build_extension(ext)
File “setup.py”, line 175, in build_extension
subprocess.check_call(cmake_build, cwd=build_folder)
File “/usr/lib/python3.6/subprocess.py”, line 311, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘[‘cmake’, ‘–build’, ‘.’, ‘–config’, ‘Release’, ‘–’, ‘-j8’]’ returned non-zero exit status 2.
Did anyone have the same problem with this library and know how to solve it?
Thanks in advance
