Thanks for the help, however, unfortunately this didn’t help.
Without firing command:
CA PortInfo:
Port info: Lid 144 port 1
LinkState:…Active
PhysLinkState:…LinkUp
Lid:…144
SMLid:…442
LMC:…0
LinkWidthSupported:…1X or 4X
LinkWidthEnabled:…1X or 4X
LinkWidthActive:…4X
LinkSpeedSupported:…2.5 Gbps or 5.0 Gbps or 10.0 Gbps
LinkSpeedEnabled:…2.5 Gbps or 5.0 Gbps or 10.0 Gbps
LinkSpeedActive:…10.0 Gbps
LinkSpeedExtSupported:…14.0625 Gbps
LinkSpeedExtEnabled:…14.0625 Gbps
LinkSpeedExtActive:…14.0625 Gbps
Extended Port info: Lid 144 port 1
StateChangeEnable:…0x00
LinkSpeedSupported:…0x01
LinkSpeedEnabled:…0x01
LinkSpeedActive:…0x00
After firing the above mentioned commands, i.e.
ibportstate 144 1 fdr10 0 espeed 30
ibportstate 144 1 reset
We get below output
CA PortInfo:
LinkState:…Active
Lid:…144
SMLid:…442
LMC:…0
LinkWidthActive:…4X
LinkSpeedEnabled:…0x00
Can you please help ?
CA ‘mlx4_0’
CA type: MT4099
Number of ports: 1
Firmware version: 2.30.8000
Hardware version: 0
Node GUID: 0x0002c903001f69e0
System image GUID: 0x0002c903001f69e3
Port 1:
State: Active
Physical state: LinkUp
Rate: 56
Base lid: 144
LMC: 0
SM lid: 442
Capability mask: 0x02514868
Port GUID: 0x0002c903001f69e1
Link layer: InfiniBand
