We are using the mellanox connectx3 adapter(Link Speed:40Gps) on windows10 PCs. We also use the proper infiniband cable for this kind of adapter which can provide the rational infiniband speed .
However, we still failed to reach the rational speed. I use the nd_read_bw to test the speed , it was just about 6Gps. It’s further out of our expectation.
So l use the command “vstat” to show some info about my PC:
This is vstat result on the same host:11.4.12.11
C:\Windows\system32>vstat
hca_idx=0
uplink={BUS=PCI_E Gen2, SPEED=5.0 Gbps, WIDTH=x2, CAPS=8.0*x8}
MSI-X={ENABLED=1, SUPPORTED=128, GRANTED=10, ALL_MASKED=N}
vendor_id=0x02c9
vendor_part_id=4099
hw_ver=0x0
fw_ver=2.42.5000
PSID=MT_1100110028
node_guid=f452:1403:0047:63f0
num_phys_ports=1
port=1
port_guid=f452:1403:0047:63f1
port_state=PORT_ACTIVE (4)
link_speed=10.00 Gbps
link_width=4x (2)
rate=40.00 Gbps
real_rate=32.00 Gbps (QDR)
port_phys_state=LINK_UP (5)
active_speed=10.00 Gbps
sm_lid=0x0004
port_lid=0x0004
port_lmc=0x0
transport=IB
max_mtu=4096 (5)
active_mtu=4096 (5)
GID[0]=fe80:0000:0000:0000:f452:1403:0047:63f1
This is test result on the same host:11.4.12.11
C:\Windows\system32>nd_read_bw -S 11.4.12.11
Listening for incoming connection request…
Connection accepted.
C:\Windows\system32>nd_read_bw -C 11.4.12.11
#qp #bytes #iterations MR [Mmps] Gb/s CPU Util.
0 65536 100000 0.011 5.95 100.00
Test finished. Releasing resources…
0 65536 100000 0.011 5.94 100.00
Can someone help me solve the problem why we can’t reach the rational speed?
