We have just racked up 16 new Dell compute nodes with Infiniband cards that identify as MT28908:
e2:00.0 Infiniband controller: Mellanox Technologies MT28908 Family [ConnectX-6]
These are connected to an unmanaged FDR-capable switch identifying as a ‘SwitchX - Mellanox Technologies’.
All the new nodes only achieve SDR speeds:
[root@node098 ~]# ibstatus
Infiniband device ‘mlx5_0’ port 1 status:
default gid: fe80:0000:0000:0000:1c34:da03:0050:6600
base lid: 0x2c4
sm lid: 0xa8
state: 4: ACTIVE
phys state: 5: LinkUp
rate: 10 Gb/sec (4X SDR)
link_layer: InfiniBand
Old nodes attached to the same switch get FDR.
I’ve upgraded the card firmware without affecting anything. mlxlink says
[root@node098 ~]# mlxlink -d e2:00.0
Operational Info
State : Active
Physical state : LinkUp
Speed : IB-SDR
Width : 4x
FEC : Firecode FEC
Loopback Mode : No Loopback
Auto Negotiation : ON
Supported Info
Enabled Link Speed : 0x00000011 (FDR,SDR)
Supported Cable Speed : 0x0000001f (FDR,FDR10,QDR,DDR,SDR)
Troubleshooting Info
Status Opcode : 35
Group Opcode : PHY FW
Recommendation : The active speed was degraded from maximal possible speed due to peer signal integrity issue.
Any suggestions for how to troubleshoot this?
MvB
September 6, 2020, 3:26am
2
Hello Martin,
Thank you for posting your inquiry on the NVIDIA Networking Community.
Based on the information provided, please make sure that all ConnectX-6 VPI HCA’s and the FDR switches are running the latest f/w available. You can download the latest f/w through the following link → NVIDIA Networking Firmaware Downloads
Furthermore, when connecting HDR components to FDR components, please make sure you are following the recommended connectivity matrix → https://docs.mellanox.com/display/ConnectX6Firmwarev20281002/Firmware+Compatible+Products#FirmwareCompatibleProducts-SwitchandHCAsInfiniBandCableConnectivityMatrix
This matrix also provides the information on the supported cables you need to use, to connect the ConnectX-6 VPI HCA to a FDR switch (Switch-X) → https://docs.mellanox.com/display/ConnectX6Firmwarev20281002/Firmware+Compatible+Products#FirmwareCompatibleProducts-ValidatedandSupportedFDRCables
Just to be aware when using a ConnectX-6 Dual-port VPI ( 1 port IB/ 1 port Eth.), FDR speed/connectivity is not supported and the link will come up as QDR/SDR (As mentioned in the section “VPI Protocol Support”)
Thank you and regards,
~NVIDIA Networking Technical Support
