Rate sdr instead hdr
I have a system with Infiniband HDR 200 cards and Mellanox QM8700 switches installed. After configuring everything and also trying to force the speed to hdr I always get speed sdr link. What can I do?
I carried out tests both with sm installed on the switch and externally with the usual partition. No improvement.
These are the details of my hardware:
[root@md15 ~]# ibstat
CA ‘mlx5_0’
CA type: MT4123
Number of ports: 1
Firmware version: 20.35.1012
Hardware version: 0
Node GUID: 0x946dae03005d2ae6
System image GUID: 0x946dae03005d2ae6
Port 1:
State: Active
Physical state: LinkUp
Rate: 10
Base lid: 20
LMC: 0
SM lid: 2
Capability mask: 0xa651e848
Port GUID: 0x946dae03005d2ae6
Link layer: InfiniBand
ibstat ibstatus
[root@md15 ~]# ibstatus
Infiniband device ‘mlx5_0’ port 1 status:
default gid: fe80:0000:0000:0000:946d:ae03:005d:2ae6
base lid: 0x14
sm lid: 0x1
state: 4: ACTIVE
phys state: 5: LinkUp
rate: 10 Gb/sec (4X SDR)
link_layer: InfiniBand
Partition:
Partition Name PKey Default Member IPoIB Rate MTU SL Scope
Default 0x7FFF full Yes 200 4K default default
QM8700:
QM8700 Software Version: X86_64 3.10.4006 2022-11-09 14:28:37 x86_64
QM8700 Firmware Version: 27.2010.4034
MLNX-OFED: 23.07-0.5.0.0
Do you have any suggestions for solving the problem and obtaining hdr connections?
Thank you
Matteo
Some details from switch port:
Port Info
Port number :
15
Port type :
IB
IB Subnet :
infiniband-default
Port description :
Logical port state :
Active
Physical port state :
LinkUp
Current line rate :
10.0 Gbps
Supported speeds :
sdr, hdr
Speed :
sdr
Supported widths :
1X, 2X, 4X
Width :
4X
Max supported MTUs :
4096
MTU :
4096
VL admin capabilities :
VL0 - VL7
Operational VLs :
VL0 - VL3
Threshold Level :
N/A
Port CountersClear Port 15 Counters
RX bytes :
75256
RX packets :
417
RX errors :
0
Symbol errors :
0
VL15 dropped packets :
0
TX bytes :
76952
TX packets :
441
TX wait :
0
TX discarded packets :
0
Transceiver Information
Identifier :
QSFP56
Cable/ Module type :
Passive copper, unequalized
Infiniband speeds :
unknown
Vendor :
Mellanox
Cable length :
2 m
Part number :
MCP1650-V002E26
Revision :
A3
Serial number :
MT2248VB82669
Please use Infiniband cables.
the cable in USE PN: MCP1650-V002E26. is a 200GbE cable and not an HDR cable.
What cable are y on using.
There’s no need to force any speed it should work in accordance to the cable and raise HDR.
Please use mlxlink with ‘m e c’ flags and attach the output for both sides. You can use device as lid- for inband access.
mellanox-qm8700 [standalone: master] (config) # show interfaces ib 1/01 transceiver
IB1/1 state:
identifier : QSFP56
cable/module type : Passive copper, unequalized
infiniband speeds : unknown
vendor : Mellanox
cable length : 2m
part number : MCP1650-V002E26
revision : A3
serial number : MT2248VB82448
mlxlink -d /dev/mst/mt4123_pciconf0 -p 1 -m -c
Operational Info
State : Active
Physical state : LinkUp
Speed : IB-SDR
Width : 4x
FEC : No FEC
Loopback Mode : No Loopback
Auto Negotiation : ON
Supported Info
Enabled Link Speed : 0x00000001 (SDR)
Supported Cable Speed : 0x00000001 (SDR)
Troubleshooting Info
Status Opcode : 0
Group Opcode : N/A
Recommendation : No issue was observed
Tool Information
Firmware Version : 20.35.1012
amBER Version : 2.17
MFT Version : mft 4.25.0-62
Module Info
Identifier : QSFP28
Compliance : N/A
Cable Technology : Copper cable unequalized
Cable Type : Passive copper cable
OUI : Mellanox
Vendor Name : Mellanox
Vendor Part Number : MCP1650-V002E26
Vendor Serial Number : MT2248VB82483
Rev : A3
Wavelength [nm] : N/A
Transfer Distance [m] : 2
Attenuation (5g,7g,12g) [dB] : 5,6,10
FW Version : N/A
Digital Diagnostic Monitoring : No
Power Class : N/A
CDR RX : N/A
CDR TX : N/A
LOS Alarm : N/A
Temperature [C] : N/A
Voltage [mV] : N/A
Bias Current [mA] : N/A
Rx Power Current [dBm] : N/A
Tx Power Current [dBm] : N/A
SNR Media Lanes [dB] : N/A
SNR Host Lanes [dB] : N/A
IB Cable Width : 1x,2x,4x
Memory Map Revision : 8
Linear Direct Drive : 0
Cable Breakout : Channels implemented [1,2,3,4]/Cable with single far-end with 4 channels implemented, or separable module with a 4-channel connector
SMF Length : N/A
MAX Power : 0
Cable Rx AMP : N/A
Cable Rx Emphasis : N/A
Cable Rx Post Emphasis : N/A
Cable Tx Equalization : N/A
Wavelength Tolerance : N/A
Module State : N/A
DataPath state [per lane] : N/A
Rx Output Valid [per lane] : N/A
Nominal bit rate : 26.500Gb/s
Rx Power Type : OMA
Manufacturing Date : 16_11_22
Active Set Host Compliance Code : N/A
Active Set Media Compliance Code : N/A
Error Code Response : N/A
Module FW Fault : N/A
DataPath FW Fault : N/A
Tx Fault [per lane] : N/A
Tx LOS [per lane] : N/A
Tx CDR LOL [per lane] : N/A
Rx LOS [per lane] : N/A
Rx CDR LOL [per lane] : N/A
Tx Adaptive EQ Fault [per lane] : N/A
Physical Counters and BER Info
Time Since Last Clear [Min] : 207.3
Symbol Errors : 0
Symbol BER : 15E-255
Effective Physical Errors : 0
Effective Physical BER : 15E-255
Raw Physical Errors Per Lane : 0,0,0,0
Raw Physical BER : 15E-255
Link Down Counter : 6
Link Error Recovery Counter : 0
Ok. But why the connection rate is 10Gbit/s instead 200Gbit/s? What is the differences between MCP1650-H and MCP1650-V?
Thank you
when there is no IB support for a cable - the devices on both ends will only try to Link up at SDR (2.5x4)
MCP1650 are HDR DAC cables
