Issue reaching 100 Gb/s with ConnectX-5 (MCX556A-ECAT) and HDR100 breakout cable (CBL-MCP7H50-H002R26)
Hello NVIDIA community!
We are trying to achieve 100 Gb/s per port on a server using the NVIDIA Mellanox ConnectX-5 (MCX556A-ECAT) adapter. Below is our current setup:
Environment:
  • Adapter: ConnectX-5 Dual-Port PCIe Gen3 x16 (MCX556A-ECAT)
  • Cable: HDR100 breakout DAC – CBL-MCP7H50-H002R26 (QSFP56 to 2x HDR100)
  • Switch: Mellanox Quantum MQM8790 (unmanaged), with ports set to SPLIT_2X mode
  • Driver version: MLNX_OFED 5.8-3.0.7.0
  • OS: Oracle Linux 8.8
  • Kernel: 4.18.0-477.21.1.el8_8.x86_64
Problem:
Even with the physical connections apparently correct, the InfiniBand interfaces on the server are limited to 25 Gb/s (1x EDR), as confirmed by ibstatus, ibv_devinfo, and ibdiagnet.
The HDR100 breakout cable is properly connected: the main end is plugged into a 200 Gb/s switch port (configured with SPLIT_2X), and each leg is connected to a separate port on the ConnectX-5 adapter. Both interfaces are up and functional.
Evidence:
ibstatus
[root@node01 ~]# ibstatus
Infiniband device 'mlx5_0' port 1 status:
	default gid:	 fe80:0000:0000:0000:e8eb:d303:00a9:3c42
	base lid:	 0x6d
	sm lid:		 0x1
	state:		 4: ACTIVE
	phys state:	 5: LinkUp
	rate:		 25 Gb/sec (1X EDR)
	link_layer:	 InfiniBand
Infiniband device 'mlx5_1' port 1 status:
	default gid:	 fe80:0000:0000:0000:e8eb:d303:00a9:3c43
	base lid:	 0x71
	sm lid:		 0x1
	state:		 4: ACTIVE
[root@node01 ~]#
ibv_devinfo
[root@node01 ~]# ibv_devinfo
hca_id:	mlx5_0
	transport:			InfiniBand (0)
	fw_ver:				16.32.1010
	node_guid:			e8eb:d303:00a9:3c42
	sys_image_guid:			e8eb:d303:00a9:3c42
	vendor_id:			0x02c9
	vendor_part_id:			4119
	hw_ver:				0x0
	board_id:			MT_0000000008
	phys_port_cnt:			1
		port:	1
			state:			PORT_ACTIVE (4)
			max_mtu:		4096 (5)
			active_mtu:		4096 (5)
			sm_lid:			1
			port_lid:		109
			port_lmc:		0x00
hca_id:	mlx5_1
	fw_ver:				16.32.1010
	node_guid:			e8eb:d303:00a9:3c43
	vendor_id:			0x02c9
	hw_ver:				0x0
	phys_port_cnt:			1
		port:	1
			max_mtu:		4096 (5)
			sm_lid:			1
			port_lid:		113
			port_lmc:		0x00
[root@node01 ~]#
mlxconfig
[root@node01 ~]# mlxconfig -d /dev/mst/SW_MT54000_Quantum_Mellanox_Technologies_lid-0x004a q
Device #1:
Device type:    Quantum
Description:    Mellanox Quantum(TM) HDR InfiniBand Switch; 40 QSFP56 ports; 2 Power Supplies (AC); unmanaged; standard depth; P2C airflow; Rail Kit; RoHS6
Device:         /dev/mst/SW_MT54000_Quantum_Mellanox_Technologies_lid-0x004a
Configurations:                                      Next Boot
         SPLIT_MODE                                  SPLIT_2X(1)
         DISABLE_AUTO_SPLIT                          ENABLE_AUTO_SPLIT(0)
         SPLIT_PORT                                  Array[1..64]
         GB_VECTOR_LENGTH                            0
         GB_UPDATE_MODE                              ALL(0)
         GB_VECTOR                                   Array[0..7]
[root@node01 ~]#
ibnetdiscover
[root@node01 ~]# ibnetdiscover | grep -i node01
[55]	"H-e8ebd30300a93c42"[1](e8ebd30300a93c42) 		# "node01 HCA-1" lid 109 1xEDR
[56]	"H-e8ebd30300a93c43"[1](e8ebd30300a93c43) 		# "node01 HCA-2" lid 113 1xEDR
Ca	1 "H-e8ebd30300a93c43"		# "node01 HCA-2"
Ca	1 "H-e8ebd30300a93c42"		# "node01 HCA-1"
[root@node01 ~]#
Switch-side link status:
Port 55 -> node01 HCA-1 : 1X 25.78125 Gbps Active
Port 56 -> node01 HCA-2 : 1X 25.78125 Gbps Active
[root@node01 ~]# mlxconfig -d /dev/mst/SW_MT54000_Quantum_Mellanox_Technologies_lid-0x004a q SPLIT_PORT[55..56]
Device #1:
         SPLIT_PORT[55]                              NO_SPLIT(0)
         SPLIT_PORT[56]                              NO_SPLIT(0)
[root@node01 ~]#
Physical port the cable is connected to (switch IB port 28):
[root@node01 ~]# mlxconfig -d /dev/mst/SW_MT54000_Quantum_Mellanox_Technologies_lid-0x004a q SPLIT_PORT[28]
Device #1:
         SPLIT_PORT[28]                              NO_SPLIT(0)
[root@node01 ~]#
Note: I tried to solve it by updating the OFED driver to version 5.8-6.0.4.2, but nothing changed.
Questions:
  1. Does the fallback to 1x EDR / 25 Gb/s result from a limitation in PAM4 support or signal compatibility?
  2. The ConnectX-5 works correctly with QSFP28 100G DAC passive cables (non-breakout)?
  3. Why doesn’t it achieve the same with the HDR breakout cable, even in SPLIT_2X mode?
  4. Are there any known compatibility constraints or design limitations regarding breakout cables with the ConnectX-5 MCX556A-ECAT?
Any suggestions or similar experience would be greatly appreciated.
Best regards,
Marcos Melo.
You can check the below link to be sure that you are using the correct supported cables for HDR switch and ConnectX-5 HCAs.
Hello Marlon, thank you very much for your help. After checking, the cable is indeed not compatible with the ConnectX-5 card. The cable transmits in PAM4, while the interface connectX-5 only supports NRZ — that was the issue. I’ll replace the cable with an EDR one and hope to achieve 100 Gb/s per interface on the node.
Thanks again for your help.
