Just to share more information:
The system (Ubuntu 16.04) can detect that this is a DAC module but can’t detect speed and duplex mode.
Settings for eno7:
Supported ports: [ FIBRE ]
Supported link modes: 10000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: No
Advertised link modes: 10000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: No
Speed: Unknown!
Duplex: Unknown! (255)
Port: Direct Attach Copper
PHYAD: 0
Transceiver: external
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: no
ethtool -m eno7
Identifier : 0x03 (SFP)
Extended identifier : 0x04 (GBIC/SFP defined by 2-wire interface ID)
Connector : 0x21 (Copper pigtail)
Transceiver codes : 0x01 0x00 0x00 0x04 0x00 0x04 0x80 0xd5
Transceiver type : Infiniband: 1X Copper Passive
Transceiver type : Ethernet: 1000BASE-CX
Transceiver type : FC: Copper Passive
Transceiver type : FC: Twin Axial Pair (TW)
Transceiver type : FC: 1200 MBytes/sec
Transceiver type : FC: 800 MBytes/sec
Transceiver type : FC: 400 MBytes/sec
Transceiver type : FC: 200 MBytes/sec
Transceiver type : FC: 100 MBytes/sec
Encoding : 0x00 (unspecified)
BR, Nominal : 10300MBd
Rate identifier : 0x00 (unspecified)
Length (SMF,km) : 0km
Length (SMF) : 0m
Length (50um) : 0m
Length (62.5um) : 0m
Length (Copper) : 3m
Length (OM3) : 0m
Passive Cu cmplnce. : 0x01 (SFF-8431 appendix E) [SFF-8472 rev10.4 only]
Vendor name : Mellanox
Vendor OUI : 00:02:c9
Vendor PN : MC2609130-003
Vendor rev : A3
Option values : 0x00 0x00
BR margin, max : 0%
BR margin, min : 0%
Vendor SN : MT1713VS01917
Date code : 170323
Trying to set the speed or advertise the correct speed also not working.
ethtool -s eno7 speed 10000
Cannot set new settings: Invalid argument
not setting speed
ethtool -s eno7 advertise 0x1000
Is there any more thing i can try, does using other cable such as cable from Intel a possible solution?
Cw
