I have a Mellanox MT27520 ConnectX-3 Pro (2x40G ports) with the latest MLNX OFED driver (version 4.6-1.0.1.1 for Debian 9.6) and I wonder if it is possible to attach a QSFP+ breakout cable (40G to 4x10G) on it?
My goal is to connect each of the 10G extremity to different 10Gb/s switches instead of using a regular 40G DAC to a single switch. I already played with multiple VFS on both ports to divide the 40Gb/s bandwidth accordingly but I would really like to use the QSFP+ breakout cable to enjoy physically separated connectivity.
As an example, I have seen that the Intel XL710 can be configured in such a mode (https://forums.intel.com/s/question/0D50P0000490RYESA2/connect-directly-x710-to-xl710-with-qsfp-breakout-cable?language=en_US). Is it possible to achieve the same with Mellanox driver/firmware? I didn’t find any relevant parameters using mlxconfig, here are the configuration options of my card:
Device #1:
Device type: ConnectX3Pro
Device: /dev/mst/mt4103_pci_cr0
Configurations: Next Boot
SRIOV_EN True(1)
NUM_OF_VFS 16
LINK_TYPE_P1 ETH(2)
PHY_TYPE_P1 XFI(2)
XFI_MODE_P1 _10G(0)
FORCE_MODE_P1 False(0)
LINK_TYPE_P2 ETH(2)
PHY_TYPE_P2 XFI(2)
XFI_MODE_P2 _10G(0)
FORCE_MODE_P2 False(0)
LOG_BAR_SIZE 5
BOOT_PKEY_P1 0
BOOT_PKEY_P2 0
BOOT_OPTION_ROM_EN_P1 True(1)
BOOT_VLAN_EN_P1 False(0)
BOOT_RETRY_CNT_P1 0
LEGACY_BOOT_PROTOCOL_P1 PXE(1)
BOOT_VLAN_P1 1
BOOT_OPTION_ROM_EN_P2 True(1)
BOOT_VLAN_EN_P2 False(0)
BOOT_RETRY_CNT_P2 0
LEGACY_BOOT_PROTOCOL_P2 PXE(1)
BOOT_VLAN_P2 1
IP_VER_P1 IPv4(0)
IP_VER_P2 IPv4(0)
CQ_TIMESTAMP True(1)
STEER_FORCE_VLAN False(0)
BR,
