Connect QSFP to dual SFP
I have two Ubuntu machines, A and B. Machine A is equipped with a BlueField-2 card (100Gbps Ethernet, dual-port), while machine B has a ConnectX-6 network card (25Gbps Ethernet, dual-port).
I am using a QSFP28 to SFP28 DAC breakout cable to connect one port of the BlueField-2 card to both ports of the CX6 network card. However, strangely, only one port on machine B is working (the one connected by the first cable).
Here is output of ibstat on machine B
CA ‘mlx5_2’
CA type: MT4127
Number of ports: 1
Firmware version: 26.35.3502
Hardware version: 0
Node GUID: 0xb83fd20300192696
System image GUID: 0xb83fd20300192696
Port 1:
State: Active
Physical state: LinkUp
Rate: 25
Base lid: 0
LMC: 0
SM lid: 0
Capability mask: 0x00010000
Port GUID: 0xba3fd2fffe192696
Link layer: Ethernet
CA ‘mlx5_3’
CA type: MT4127
Number of ports: 1
Hardware version: 0
Node GUID: 0xb83fd20300192697
Port 1:
State: Down
Physical state: Disabled
Rate: 40
Base lid: 0
LMC: 0
SM lid: 0
Port GUID: 0xba3fd2fffe192697
Here is output of ifconfig on machine B,port ens14f0np0 and ens14f1np1 are on the CX6 network adapter.
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:f0:68:6d:f5 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
ens11f0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.44 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::a242:3fff:fe34:8000 prefixlen 64 scopeid 0x20
ether a0:42:3f:34:80:00 txqueuelen 1000 (Ethernet)
RX packets 75133 bytes 5098311 (5.0 MB)
TX packets 40586 bytes 3860875 (3.8 MB)
device memory 0xc7120000-c713ffff
ens11f1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether a0:42:3f:34:80:01 txqueuelen 1000 (Ethernet)
device memory 0xc7100000-c711ffff
ens14f0np0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.111.44 netmask 255.255.255.0 broadcast 192.168.111.255
inet6 fe80::ba3f:d2ff:fe19:2696 prefixlen 64 scopeid 0x20
ether b8:3f:d2:19:26:96 txqueuelen 1000 (Ethernet)
RX packets 313 bytes 101412 (101.4 KB)
TX packets 20 bytes 1496 (1.4 KB)
ens14f1np1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.111.45 netmask 255.255.255.128 broadcast 192.168.111.127
ether b8:3f:d2:19:26:97 txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 10826 bytes 981774 (981.7 KB)
TX packets 10826 bytes 981774 (981.7 KB)
Here is output of ibstat on machine A
CA ‘mlx5_0’
CA type: MT41686
Number of ports: 1
Firmware version: 24.38.1002
Hardware version: 1
Node GUID: 0xb83fd2030054c116
System image GUID: 0xb83fd2030054c116
Port 1:
State: Down
Rate: 40
Base lid: 0
LMC: 0
SM lid: 0
Port GUID: 0xba3fd2fffe54c116
CA ‘mlx5_1’
CA type: MT41686
Number of ports: 1
Hardware version: 1
Node GUID: 0xb83fd2030054c117
Port 1:
State: Active
Rate: 25
Base lid: 0
LMC: 0
SM lid: 0
Port GUID: 0xba3fd2fffe54c117
Here is output of ifconfig on machine A:
ether 02:42:e5:c2:34:fa txqueuelen 0 (Ethernet)
inet 192.168.1.43 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::a242:3fff:fe34:809c prefixlen 64 scopeid 0x20
ether a0:42:3f:34:80:9c txqueuelen 1000 (Ethernet)
RX packets 441558 bytes 39350842 (39.3 MB)
TX packets 287031 bytes 34946941 (34.9 MB)
device memory 0xc7220000-c723ffff
ether a0:42:3f:34:80:9d txqueuelen 1000 (Ethernet)
device memory 0xc7200000-c721ffff
ens14f1np1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 9000
inet 192.168.111.43 netmask 255.255.255.0 broadcast 192.168.111.255
inet6 fe80::ba3f:d2ff:fe54:c117 prefixlen 64 scopeid 0x20
ether b8:3f:d2:54:c1:17 txqueuelen 1000 (Ethernet)
RX packets 111848467 bytes 483459752210 (483.4 GB)
RX errors 0 dropped 1966 overruns 0 frame 0
TX packets 157996435 bytes 701246606387 (701.2 GB)
RX packets 42460 bytes 7151796 (7.1 MB)
TX packets 42460 bytes 7151796 (7.1 MB)
tmfifo_net0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.100.1 netmask 255.255.255.0 broadcast 192.168.100.255
inet6 fe80::21a:caff:feff:ff02 prefixlen 64 scopeid 0x20
ether 00:1a:ca:ff:ff:02 txqueuelen 1000 (Ethernet)
RX packets 50601 bytes 4369920 (4.3 MB)
TX packets 37211 bytes 3887597 (3.8 MB)
Can you help me with this?
Breakout(split) cable only support switch to NIC port, can’t link NIC to NIC.
You can check FW RN select tested cable,
https://docs.nvidia.com/networking/display/connectx6firmwarev20392048lts/validated+and+supported+cables+and+switches
