I have a Connectx 5 Ex (MCX516A-BDAT) with a QSFP28 port that I want to connect to a 10 GbE switch with SFP+ ports. I have seen two options to do this:
- A breakout cable. In https://community.mellanox.com/s/article/mellanox-breakout-cables-40g--gt--4x10g-and-100g--gt--4x25g it is said that breakout cables only work on the switch side, not on the NIC side. Is this true?
- An adapter such as https://store.mellanox.com/products/nvidia-mam1q00a-qsa-sp-single-pack-mam1q00a-qsa-ethernet-cable-adapter-40gb-s-to-10gb-s-qsfp-to-sfp.html
Are both options valid?. Which do you recommend?
