Hi, due to Jetson orin nano SCL only has 1 M.2 Wifi module, and it is wifi 5 solution.
If I want to use wifi 6 module, how to check if the module can be use or not?
The module is use the same M.2 interface WIFI(PCIE)+BT(USB) module as SCL.
You may need to check whether that module can support to run withLinux K5.10 on ARM64 device.
