Module supporting Wifi 6 and Bluetooth5
Hi, is there any suggestions on Wifi BT module for Jetson Orin NX which supports Wifi 6 and bluetooth 5
The SCL of Orin NX is as below. Please refer to that. If you can not find what you want there, you can check with the vendors in ecosystem.
Jetson Orin NX Series and Jetson Orin Nano Series Supported Component List
