How to check if Optix denoiser is supported by GPU?
I integrated Optix denoiser inside our path tracer using Optix 8.0.0 and Cuda 12.6.
I want to be able to check if it is supported by the user GPU. Is there a way to do so?
If the OptiX SDK version you used is supported on the target system, then the denoiser is also always available.
(Unless something is wrong with the display driver installation as could happen with Docker images when required display driver components are missing. Then the denoiser creation will fail. Search the forum for explanations.)
If the question is if the denoiser is accelerated by Tensor cores, that could be queried via the compute capability major version. All GPUs since the Volta architecture have them.
If you want to check if the target system supports CUDA 12.6 or newer, you would need to read the CUDA driver’s version first.
Example code: https://github.com/NVIDIA/OptiX_Apps/blob/master/apps/intro_runtime/src/Application.cpp#L525
Checking if a specific OptiX version works is done by trying to initialize the OptixFunctionTable. If the raytracing drivers do not support the OPTIX_ABI_VERSION of the OptiX SDK version you compiled against, that initialization will fail.
If you’re interested in checking if the GPU has RT cores as well (all RTX boards and some data center GPUs have them), OptiX has a device query with OPTIX_DEVICE_PROPERTY_RTCORE_VERSION for that.
Thank you for helping <3
  1. For the cuda version I tried this:
  int versionDriver = 0;
  CUDA_CHECK( cudaDriverGetVersion(&versionDriver) );
This return 12090 on my system. What am i supposed to test this against for cuda 12.6 support?
  1. “Checking if a specific OptiX version works is done by trying to initialize the OptixFunctionTable”
    Where is that initilization happening?
    Here the code from Optix sample
 * SPDX-FileCopyrightText: Copyright (c) 2020 - 2024  NVIDIA CORPORATION & AFFILIATES. All rights reserved.
 * SPDX-License-Identifier: BSD-3-Clause
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice, this
 * list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright notice,
 * this list of conditions and the following disclaimer in the documentation
 * and/or other materials provided with the distribution.
 * 3. Neither the name of the copyright holder nor the names of its
 * contributors may be used to endorse or promote products derived from
 * this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
 * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
 * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <optix.h>
#include <optix_function_table_definition.h>
#include <optix_stubs.h>
#include <optix_denoiser_tiling.h>
#include <sutil/Exception.h>
#include <cuda_runtime.h>
#include <cmath>
#include <iostream>
#include <fstream>
#include <sstream>
#include <cstdlib>
#include <iomanip>
#include <vector>
static void context_log_cb( uint32_t level, const char* tag, const char* message, void* /*cbdata*/ )
    if( level < 4 )
        std::cerr << "[" << std::setw( 2 ) << level << "][" << std::setw( 12 ) << tag << "]: "
                  << message << "\n";
// Create four channel float OptixImage2D with given dimension. Allocate memory on device and
// Copy data from host memory given in hmem to device if hmem is nonzero.
static OptixImage2D createOptixImage2D( unsigned int width, unsigned int height, const float * hmem = nullptr )
    OptixImage2D oi;
    const uint64_t frame_byte_size = width * height * sizeof(float4);
    CUDA_CHECK( cudaMalloc( reinterpret_cast<void**>( &oi.data ), frame_byte_size ) );
    if( hmem )
        CUDA_CHECK( cudaMemcpy(
                    reinterpret_cast<void*>( oi.data ),
                    hmem,
                    frame_byte_size,
                    cudaMemcpyHostToDevice
    oi.width              = width;
    oi.height             = height;
    oi.rowStrideInBytes   = width*sizeof(float4);
    oi.pixelStrideInBytes = sizeof(float4);
    oi.format             = OPTIX_PIXEL_FORMAT_FLOAT4;
    return oi;
// Copy OptixImage2D from src to dest.
static void copyOptixImage2D( OptixImage2D& dest, const OptixImage2D& src )
    CUDA_CHECK( cudaMemcpy( (void*)dest.data, (void*)src.data, src.width * src.height * sizeof( float4 ), cudaMemcpyDeviceToDevice ) );
class OptiXDenoiser
public:
    struct Data
        uint32_t  width     = 0;
        uint32_t  height    = 0;
        float*    color     = nullptr;
        float*    albedo    = nullptr;
        float*    normal    = nullptr;
        float*    flow      = nullptr;
        float*    flowtrust = nullptr;
        std::vector< float* > aovs;     // input AOVs
        std::vector< float* > outputs;  // denoised beauty, followed by denoised AOVs
    // Initialize the API and push all data to the GPU -- normaly done only once per session.
    // tileWidth, tileHeight: If nonzero, enable tiling with given dimension.
    // kpMode: If enabled, use kernel prediction model even if no AOVs are given.
    // temporalMode: If enabled, use a model for denoising sequences of images.
    // applyFlowMode: Apply flow vectors from current frame to previous image (no denoising).
    void init( const Data&  data,
               unsigned int tileWidth     = 0,
               unsigned int tileHeight    = 0,
               bool         kpMode        = false,
               bool         temporalMode  = false,
               bool         applyFlowMode = false,
               bool         upscale2xMode = false,
               OptixDenoiserAlphaMode alphaMode = OPTIX_DENOISER_ALPHA_MODE_COPY,
               bool         specularMode  = false );
    // Execute the denoiser. In interactive sessions, this would be done once per frame/subframe.
    void exec();
    // Update denoiser input data on GPU from host memory.
    void update( const Data& data );
    // Copy results from GPU to host memory.
    void getResults();
    // Return internal guide layer data for temporal models, if available. Returned memory must be freed.
    void getInternalGuideLayerData( unsigned char** data, size_t* sizeInBytes );
    // Cleanup state, deallocate memory -- normally done only once per render session.
    void finish();
private:
    // --- Test flow vectors: Flow is applied to noisy input image and written back to result.
    // --- No denoising.
    void applyFlow();
private:
    OptixDeviceContext    m_context      = nullptr;
    OptixDenoiser         m_denoiser     = nullptr;
    OptixDenoiserParams   m_params       = {};
    bool                  m_temporalMode;
    bool                  m_applyFlowMode;
    CUdeviceptr           m_intensity    = 0;
    CUdeviceptr           m_avgColor     = 0;
    CUdeviceptr           m_scratch      = 0;
    uint32_t              m_scratch_size = 0;
    CUdeviceptr           m_state        = 0;
    uint32_t              m_state_size   = 0;
    unsigned int          m_tileWidth    = 0;
    unsigned int          m_tileHeight   = 0;
    unsigned int          m_overlap      = 0;
    OptixDenoiserGuideLayer           m_guideLayer = {};
    std::vector< OptixDenoiserLayer > m_layers;
    std::vector< float* >             m_host_outputs;
void OptiXDenoiser::init( const Data&  data,
                          unsigned int tileWidth,
                          unsigned int tileHeight,
                          bool         kpMode,
                          bool         temporalMode,
                          bool         applyFlowMode,
                          bool         upscale2xMode,
                          OptixDenoiserAlphaMode alphaMode,
                          bool         specularMode )
    SUTIL_ASSERT( data.color  );
    SUTIL_ASSERT( data.outputs.size() >= 1 );
    SUTIL_ASSERT( data.width  );
    SUTIL_ASSERT( data.height );
    SUTIL_ASSERT_MSG( !data.normal || data.albedo, "Currently albedo is required if normal input is given" );
    SUTIL_ASSERT_MSG( ( tileWidth == 0 && tileHeight == 0 ) || ( tileWidth > 0 && tileHeight > 0 ), "tile size must be > 0 for width and height" );
    unsigned int outScale = 1;
    if( upscale2xMode )
        kpMode = true;
        outScale = 2;
    m_host_outputs = data.outputs;
    m_temporalMode = temporalMode;
    m_applyFlowMode = applyFlowMode;
    m_tileWidth  = tileWidth > 0 ? tileWidth : data.width;
    m_tileHeight = tileHeight > 0 ? tileHeight : data.height;
    // Initialize CUDA and create OptiX context
        // Initialize CUDA
        CUDA_CHECK( cudaFree( nullptr ) );
        CUcontext cu_ctx = nullptr;  // zero means take the current context
        OPTIX_CHECK( optixInit() );
        OptixDeviceContextOptions options = {};
        options.logCallbackFunction       = &context_log_cb;
        options.logCallbackLevel          = 4;
        OPTIX_CHECK( optixDeviceContextCreate( cu_ctx, &options, &m_context ) );
    // Create denoiser
        // Load user provided model if model.bin is present in the currrent directory,
        // configuration of filename not done here.
        std::ifstream file( "model.bin" );
        if ( file.good() ) {
            std::stringstream source_buffer;
            source_buffer << file.rdbuf();
            OPTIX_CHECK( optixDenoiserCreateWithUserModel( m_context, (void*)source_buffer.str().c_str(), source_buffer.str().size(), &m_denoiser ) );
        else
            OptixDenoiserOptions options = {};
            options.guideAlbedo  = data.albedo ? 1 : 0;
            options.guideNormal  = data.normal ? 1 : 0;
            options.denoiseAlpha = alphaMode;
            OptixDenoiserModelKind modelKind;
            if( upscale2xMode )
                modelKind = temporalMode ? OPTIX_DENOISER_MODEL_KIND_TEMPORAL_UPSCALE2X : OPTIX_DENOISER_MODEL_KIND_UPSCALE2X;
            else if( kpMode || data.aovs.size() > 0 )
                modelKind = temporalMode ? OPTIX_DENOISER_MODEL_KIND_TEMPORAL_AOV : OPTIX_DENOISER_MODEL_KIND_AOV;
            else
                modelKind = temporalMode ? OPTIX_DENOISER_MODEL_KIND_TEMPORAL : OPTIX_DENOISER_MODEL_KIND_AOV;
            OPTIX_CHECK( optixDenoiserCreate( m_context, modelKind, &options, &m_denoiser ) );
    // Allocate device memory for denoiser
        OptixDenoiserSizes denoiser_sizes;
        OPTIX_CHECK( optixDenoiserComputeMemoryResources(
                    m_denoiser,
                    m_tileWidth,
                    m_tileHeight,
                    &denoiser_sizes
        if( tileWidth == 0 )
            m_scratch_size = static_cast<uint32_t>( denoiser_sizes.withoutOverlapScratchSizeInBytes );
            m_overlap = 0;
        else
            m_scratch_size = static_cast<uint32_t>( denoiser_sizes.withOverlapScratchSizeInBytes );
            m_overlap = denoiser_sizes.overlapWindowSizeInPixels;
        if( data.aovs.size() == 0 && kpMode == false )
                        reinterpret_cast<void**>( &m_intensity ),
                        sizeof( float )
        else
                        reinterpret_cast<void**>( &m_avgColor ),
                        3 * sizeof( float )
                    reinterpret_cast<void**>( &m_scratch ),
                    m_scratch_size
                    reinterpret_cast<void**>( &m_state ),
                    denoiser_sizes.stateSizeInBytes
        m_state_size = static_cast<uint32_t>( denoiser_sizes.stateSizeInBytes );
        OptixDenoiserLayer layer = {};
        layer.input  = createOptixImage2D( data.width, data.height, data.color );
        layer.output = createOptixImage2D( outScale * data.width, outScale * data.height );
        if( m_temporalMode )
            layer.previousOutput = createOptixImage2D( outScale * data.width, outScale * data.height );
            // This is the first frame, create zero motion vector image.
            void* flowmem;
            CUDA_CHECK( cudaMalloc( &flowmem, data.width * data.height * sizeof( float4 ) ) );
            CUDA_CHECK( cudaMemset( flowmem, 0, data.width * data.height * sizeof(float4) ) );
            m_guideLayer.flow = {(CUdeviceptr)flowmem, data.width, data.height, (unsigned int)(data.width * sizeof( float4 )), (unsigned int)sizeof( float4 ), OPTIX_PIXEL_FORMAT_FLOAT4 };
            // Set first frame previous output to noisy input image from first frame
            if( !upscale2xMode )
                copyOptixImage2D( layer.previousOutput, layer.input );
            // Internal guide layer memory set to zero for first frame.
            void* internalMemIn  = 0;
            void* internalMemOut = 0;
            size_t internalSize = outScale * data.width * outScale * data.height * denoiser_sizes.internalGuideLayerPixelSizeInBytes;
            CUDA_CHECK( cudaMalloc( &internalMemIn, internalSize ) );
            CUDA_CHECK( cudaMalloc( &internalMemOut, internalSize ) );
            CUDA_CHECK( cudaMemset( internalMemIn, 0, internalSize ) );
            m_guideLayer.previousOutputInternalGuideLayer.data   = (CUdeviceptr)internalMemIn;
            m_guideLayer.previousOutputInternalGuideLayer.width  = outScale * data.width;
            m_guideLayer.previousOutputInternalGuideLayer.height = outScale * data.height;
            m_guideLayer.previousOutputInternalGuideLayer.pixelStrideInBytes = unsigned( denoiser_sizes.internalGuideLayerPixelSizeInBytes );
            m_guideLayer.previousOutputInternalGuideLayer.rowStrideInBytes = m_guideLayer.previousOutputInternalGuideLayer.width * m_guideLayer.previousOutputInternalGuideLayer.pixelStrideInBytes;
            m_guideLayer.previousOutputInternalGuideLayer.format = OPTIX_PIXEL_FORMAT_INTERNAL_GUIDE_LAYER;
            m_guideLayer.outputInternalGuideLayer = m_guideLayer.previousOutputInternalGuideLayer;
            m_guideLayer.outputInternalGuideLayer.data = (CUdeviceptr)internalMemOut;
            if( data.flowtrust )
                void* ftmem;
                CUDA_CHECK( cudaMalloc( &ftmem, data.width * data.height * sizeof( float4 ) ) );
                CUDA_CHECK( cudaMemset( ftmem, 0, data.width * data.height * sizeof( float4 ) ) );
                m_guideLayer.flowTrustworthiness = {(CUdeviceptr)ftmem, data.width, data.height, (unsigned int)(data.width * sizeof( float4 )), (unsigned int)sizeof( float4 ), OPTIX_PIXEL_FORMAT_FLOAT4 };
        m_layers.push_back( layer );
        if( data.albedo )
            m_guideLayer.albedo = createOptixImage2D( data.width, data.height, data.albedo );
        if( data.normal )
            m_guideLayer.normal = createOptixImage2D( data.width, data.height, data.normal );
        for( size_t i=0; i < data.aovs.size(); i++ )
            layer = {};
            layer.input  = createOptixImage2D( data.width, data.height, data.aovs[i] );
                // First frame initializaton.
                if( specularMode )
                    layer.type = OPTIX_DENOISER_AOV_TYPE_SPECULAR;
    // Setup denoiser
        OPTIX_CHECK( optixDenoiserSetup(
                    m_denoiser,
                    nullptr,  // CUDA stream
                    m_tileWidth + 2 * m_overlap,
                    m_tileHeight + 2 * m_overlap,
                    m_state,
                    m_state_size,
                    m_scratch,
                    m_scratch_size
        m_params.hdrIntensity    = m_intensity;
        m_params.hdrAverageColor = m_avgColor;
        m_params.blendFactor     = 0.0f;
        m_params.temporalModeUsePreviousLayers = 0;
void OptiXDenoiser::update( const Data& data )
    CUDA_CHECK( cudaMemcpy( (void*)m_layers[0].input.data, data.color, data.width * data.height * sizeof( float4 ), cudaMemcpyHostToDevice ) );
        CUDA_CHECK( cudaMemcpy( (void*)m_guideLayer.flow.data, data.flow, data.width * data.height * sizeof( float4 ), cudaMemcpyHostToDevice ) );
    if( data.albedo )
        CUDA_CHECK( cudaMemcpy( (void*)m_guideLayer.albedo.data, data.albedo, data.width * data.height * sizeof( float4 ), cudaMemcpyHostToDevice ) );
    if( data.normal )
        CUDA_CHECK( cudaMemcpy( (void*)m_guideLayer.normal.data, data.normal, data.width * data.height * sizeof( float4 ), cudaMemcpyHostToDevice ) );
        CUDA_CHECK( cudaMemcpy( (void*)m_guideLayer.flowTrustworthiness.data, data.flowtrust, data.width * data.height * sizeof( float4 ), cudaMemcpyHostToDevice ) );
        CUDA_CHECK( cudaMemcpy( (void*)m_layers[1+i].input.data, data.aovs[i], data.width * data.height * sizeof( float4 ), cudaMemcpyHostToDevice ) );
        OptixImage2D temp = m_guideLayer.previousOutputInternalGuideLayer;
        m_guideLayer.previousOutputInternalGuideLayer = m_guideLayer.outputInternalGuideLayer;
        m_guideLayer.outputInternalGuideLayer = temp;
        for( size_t i=0; i < m_layers.size(); i++ )
            temp = m_layers[i].previousOutput;
            m_layers[i].previousOutput = m_layers[i].output;
            m_layers[i].output = temp;
    m_params.temporalModeUsePreviousLayers = 1;
void OptiXDenoiser::exec()
    if( m_intensity )
        OPTIX_CHECK( optixDenoiserComputeIntensity(
                    m_denoiser,
                    &m_layers[0].input,
                    m_intensity,
                    m_scratch,
                    m_scratch_size
    if( m_avgColor )
        OPTIX_CHECK( optixDenoiserComputeAverageColor(
                    m_denoiser,
                    &m_layers[0].input,
                    m_avgColor,
                    m_scratch,
                    m_scratch_size
    if( m_applyFlowMode )
        applyFlow();
    else
        // This sample is always using tiling mode.
#if 0
        OPTIX_CHECK( optixDenoiserInvoke(
                    m_denoiser,
                    &m_params,
                    m_state,
                    m_state_size,
                    &m_guideLayer,
                    m_layers.data(),
                    static_cast<unsigned int>( m_layers.size() ),
                    0, // input offset X
                    0, // input offset y
                    m_scratch,
                    m_scratch_size
#else
        OPTIX_CHECK( optixUtilDenoiserInvokeTiled(
                    m_denoiser,
                    &m_params,
                    m_state,
                    m_state_size,
                    &m_guideLayer,
                    m_layers.data(),
                    m_scratch,
                    m_scratch_size,
                    m_overlap,
                    m_tileWidth,
                    m_tileHeight
#endif
    CUDA_SYNC_CHECK();
inline float catmull_rom(
    float       p[4],
    float       t)
    return p[1] + 0.5f * t * ( p[2] - p[0] + t * ( 2.f * p[0] - 5.f * p[1] + 4.f * p[2] - p[3] + t * ( 3.f * ( p[1] - p[2]) + p[3] - p[0] ) ) );
// Apply flow to image at given pixel position (using bilinear interpolation), write back RGB result.
static void addFlow(
    float4*             result,
    const float4*       image,
    const float4*       flow,
    unsigned int        width,
    unsigned int        x,
    unsigned int        y )
    float dst_x = float( x ) - flow[x + y * width].x;
    float dst_y = float( y ) - flow[x + y * width].y;
    float x0 = dst_x - 1.f;
    float y0 = dst_y - 1.f;
    float r[4][4], g[4][4], b[4][4];
    for (int j=0; j < 4; j++)
        for (int k=0; k < 4; k++)
            int tx = static_cast<int>( x0 ) + k;
            if( tx < 0 )
                tx = 0;
            else if( tx >= (int)width )
                tx = width - 1;
            int ty = static_cast<int>( y0 ) + j;
            if( ty < 0 )
                ty = 0;
            else if( ty >= (int)height )
                ty = height - 1;
            r[j][k] = image[tx + ty * width].x;
            g[j][k] = image[tx + ty * width].y;
            b[j][k] = image[tx + ty * width].z;
    float tx = dst_x <= 0.f ? 0.f : dst_x - floorf( dst_x );
    r[0][0] = catmull_rom( r[0], tx );
    r[0][1] = catmull_rom( r[1], tx );
    r[0][2] = catmull_rom( r[2], tx );
    r[0][3] = catmull_rom( r[3], tx );
    g[0][0] = catmull_rom( g[0], tx );
    g[0][1] = catmull_rom( g[1], tx );
    g[0][2] = catmull_rom( g[2], tx );
    g[0][3] = catmull_rom( g[3], tx );
    b[0][0] = catmull_rom( b[0], tx );
    b[0][1] = catmull_rom( b[1], tx );
    b[0][2] = catmull_rom( b[2], tx );
    b[0][3] = catmull_rom( b[3], tx );
    float ty = dst_y <= 0.f ? 0.f : dst_y - floorf( dst_y );
    result[y * width + x].x = catmull_rom( r[0], ty );
    result[y * width + x].y = catmull_rom( g[0], ty );
    result[y * width + x].z = catmull_rom( b[0], ty );
// Apply flow from current frame to the previous noisy image.
void OptiXDenoiser::applyFlow()
    if( m_layers.size() == 0 )
        return;
    const uint64_t frame_size = m_layers[0].output.width * m_layers[0].output.height;
    const uint64_t frame_byte_size = frame_size * sizeof(float4);
    const float4* device_flow = (float4*)m_guideLayer.flow.data;
    if( !device_flow )
        return;
    float4* flow = new float4[ frame_size ];
    CUDA_CHECK( cudaMemcpy( flow, device_flow, frame_byte_size, cudaMemcpyDeviceToHost ) );
    float4* image = new float4[ frame_size ];
    float4* result = new float4[frame_size];
        CUDA_CHECK( cudaMemcpy( image, (float4*)m_layers[i].previousOutput.data, frame_byte_size, cudaMemcpyDeviceToHost ) );
        for( unsigned int y=0; y < m_layers[i].previousOutput.height; y++ )
            for( unsigned int x=0; x < m_layers[i].previousOutput.width; x++ )
                addFlow( result, image, flow, m_layers[i].previousOutput.width, m_layers[i].previousOutput.height, x, y );
        CUDA_CHECK( cudaMemcpy( (void*)m_layers[i].output.data, result, frame_byte_size, cudaMemcpyHostToDevice ) );
    delete[] result;
    delete[] image;
    delete[] flow;
void OptiXDenoiser::getResults()
    const uint64_t frame_byte_size = m_layers[0].output.width*m_layers[0].output.height*sizeof(float4);
                    m_host_outputs[i],
                    reinterpret_cast<void*>( m_layers[i].output.data ),
                    frame_byte_size,
        // We start with a noisy image in this mode for each frame, otherwise the warped images would accumulate.
                                    reinterpret_cast<void*>( m_layers[i].input.data ),
void OptiXDenoiser::getInternalGuideLayerData( unsigned char** data, size_t* sizeInBytes )
    *data        = 0;
    *sizeInBytes = 0;
    if( m_guideLayer.outputInternalGuideLayer.data )
        *sizeInBytes = m_guideLayer.outputInternalGuideLayer.width * m_guideLayer.outputInternalGuideLayer.height * m_guideLayer.outputInternalGuideLayer.pixelStrideInBytes;
        *data = new unsigned char[ *sizeInBytes ];
        CUDA_CHECK( cudaMemcpy( *data, (void*)m_guideLayer.outputInternalGuideLayer.data, *sizeInBytes, cudaMemcpyDeviceToHost ) );
void OptiXDenoiser::finish()
    // Cleanup resources
    optixDenoiserDestroy( m_denoiser );
    optixDeviceContextDestroy( m_context );
    CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_intensity)) );
    CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_avgColor)) );
    CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_scratch)) );
    CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_state)) );
    CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_guideLayer.albedo.data)) );
    CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_guideLayer.normal.data)) );
    CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_guideLayer.flow.data)) );
    CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_guideLayer.flowTrustworthiness.data)) );
    CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_guideLayer.previousOutputInternalGuideLayer.data)) );
    CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_guideLayer.outputInternalGuideLayer.data)) );
        CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_layers[i].input.data) ) );
        CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_layers[i].output.data) ) );
        CUDA_CHECK( cudaFree(reinterpret_cast<void*>(m_layers[i].previousOutput.data) ) );
  1. Please have a look at the linked example code again. The next code lines explain the version format and do the decoding into major and minor CUDA driver version. You need to check if (major > 12 || (major == 12 && minor >= 6)) for CUDA 12.6 support. Your driver supports even CUDA 12.9.
  2. Look into the optixInit() function. Search all OptiX SDK example code for OPTIX_ABI_VERSION.
It’s good that you use the AOV denoiser mode. That’s the recommended mode.
Gracias <3
