I followed OptiX 7 documentation and made a quick test code for the Denoiser.
However, it didn’t work with error: unsigned char pixel format not supported.
Did I do something wrong?
The code is below:
class DenoiserRenderPass
public:
void init(OptixDeviceContext context, unsigned int width, unsigned int height)
_options.inputKind = OPTIX_DENOISER_INPUT_RGB;
_options.pixelFormat = OPTIX_PIXEL_FORMAT_UCHAR4;
optixDenoiserCreate(context, &_options, &_denoiser);
optixDenoiserSetModel(_denoiser, OPTIX_DENOISER_MODEL_KIND_LDR, nullptr, 0);
OptixDenoiserSizes sizes;
optixDenoiserComputeMemoryResources(_denoiser, width, height, &sizes);
_denoiserStateSizeInBytes = sizes.stateSizeInBytes;
_scratchSizeInBytes = sizes.recommendedScratchSizeInBytes;
cudaMalloc((void**)&_scratch, _scratchSizeInBytes);
cudaStreamCreate(&_stream);
cudaMalloc((void**)&_denoiserState, _denoiserStateSizeInBytes);
optixDenoiserSetup(_denoiser, _stream, width, height, _denoiserState, _denoiserStateSizeInBytes, _scratch, _scratchSizeInBytes);
cudaMalloc((void**)&_outputIntensity, width * height * sizeof(uchar4));
void launchRender(const RTBuffer2D<uchar4>& src, RTBuffer2D<uchar4>& dst)
_denoiserParams = {};
_inputImage.width = src.width();
_inputImage.height = src.height();
_inputImage.rowStrideInBytes = src.pitch();
_inputImage.pixelStrideInBytes = src.stride();
_inputImage.data = (CUdeviceptr)src.ptr();
_inputImage.format = OPTIX_PIXEL_FORMAT_UCHAR4;
optixDenoiserComputeIntensity(
_denoiser, _stream, &_inputImage, _outputIntensity, _scratch, _scratchSizeInBytes);
_outputImage.width = dst.width();
_outputImage.height = dst.height();
_outputImage.rowStrideInBytes = dst.pitch();
_outputImage.pixelStrideInBytes = dst.stride();
_outputImage.data = (CUdeviceptr)dst.ptr();
_outputImage.format = OPTIX_PIXEL_FORMAT_UCHAR4;
optixDenoiserInvoke(_denoiser, _stream, &_denoiserParams,
_denoiserState, _denoiserStateSizeInBytes, &_inputImage, 1, 0, 0, &_outputImage, _scratch, _scratchSizeInBytes);
private:
OptixDenoiserOptions _options;
OptixDenoiser _denoiser;
CUstream _stream;
CUdeviceptr _denoiserState;
size_t _denoiserStateSizeInBytes;
OptixDenoiserParams _denoiserParams;
OptixImage2D _inputImage;
OptixImage2D _outputImage;
CUdeviceptr _outputIntensity;
CUdeviceptr _scratch;
size_t _scratchSizeInBytes;
