I want to use busybox to control the GPIO pin PAC.06.
I want to know how can i use it, to make it as an output and make the pin low.
can i control it via busybox?
Also i want to know if i can reset the usb hub of jetson?
I don’t know what you are talking about with this.
How can i enable sysfs in orin??
previously we use to control the gpio via /sys/class/gpio. Can we enable that in Orin too?
You asked about busybox at first, which is to directly set the register, and you asked about sysfs now.
What exactly do you want?
I’ve talked with you a lot in this topic.:
Anything you still don’t get?
Am trying to understand all the possible ways to control the GPIO on Jetpack 6.
Also how to configure different things on Orin.
The only standard way on JetPack 6 is configuring the pinmux spreadsheet before flashing.
If you still need to use GPIO sysfs, please enable required kernel config and rebuild the kernel yourself.
We don’t have support for that.
Can you please tell me, how to enable the kernel config for sysfs?
Google will tell you.
