How to clear the temperature warning message?
When using orin nx for a while, the following the notification about the temperature warning message is showed as below.
Could you please tell me how to clear it? or modify to not show this message?
Hi lishi2002,
Are you using the devkit or custom board for Orin NX?
Are you running any application with heavily loading and the chip in hot temperature?
Please share the full serial console log for further check.
Thanks for reply
  1. We use a custom hardware with fpga designed from devkit.
  2. we use the nvidia original BSP with 35.4.1
  3. when running, power mode shows MAXN kernel logs output some log like below:
cooling state: 0 → 1
cooling state: 1 → 0
now I just want to disable the notification.
Hi:
Got it from Disable "Caution - Hot surface. Do not touch." warning - #5 by linuxdev
thanks
