If you have both an nvlink and a PCIE connection,but I want to use PCIE connect this gpu.What should I do.
Not possible in the P2P case.
Otherwise, just make sure that P2P is not enabled, and data will flow between the GPUs on PCIE (and through the CPU).
Related topics
| DGX-1 using PCIe only instead of NVLink | 2 | 3166 | August 5, 2021 | |
| P2P Transfers Across Single PCIe Switch Fail | 5 | 1725 | April 15, 2024 | |
| NVLink with different model gaming cards? | 0 | 630 | June 15, 2020 | |
| How to use p2p over PCIe or NVLink between different containers on the same node? | 0 | 315 | August 16, 2024 | |
| NV-Link Setup Troubleshooting and NV-Link Status Output Help | 7 | 13742 | April 13, 2023 | |
| Peer-To-Peer Access Fails on 4x A6000 | 0 | 353 | July 18, 2023 | |
| No P2P - Dual NVlinked RTX 2080 TI setup on HP workstation - NVLink not working, no SLI option in control panel | 6 | 2640 | December 26, 2019 | |
| Making work NVLink on Windows 10 with dual 3090 | 0 | 2760 | April 13, 2021 | |
| A100 Nvlink on Dual CPU System | 1 | 1079 | January 28, 2022 | |
| Failed to simpleP2P | 2 | 404 | August 26, 2024 |
