I am using the cusolver library to calculate the SVD. According to official examples, the functions “cusolverDnXgesvd()”, “cusolverDnXgesvdp()”, and “cusolverDnXgesvr()” can work well. However, I realize that a large of memory are required for three functions. For example, when the matrix with the size of12168*12168 is solved, the cusolverDnXgesvd(), cusolverDnXgesvdp(), and cusolverDnXgesvr() required 6806 MB, 8474 MB, and 7940MB memory. I make sure that k in “k-rank” is equal to 1 when cusolverDnXgesvr() is used.
I want to know whether all functions require similar memory.
I provide a part of my codes for you, which contain the process of calling three functions:
SUBROUTINE Regularization_Initial (Lambda, Jac_T)
IMPLICIT NONE
REAL(r8k),intent(inout) ::Lambda
REAL(r8k), intent(in)::Jac_T(Model_Num, NST)
INTEGER(i4k):: Hessian_row,Hessian_col,WtW_row
INTEGER(i4k):: moment, point, idx_tol
INTEGER(i8k)::t1,t2,count_rate !t1 denotes original cpu time , t2 denotes the end cpu time and t=t2-t1
REAL(r8k) ::t
CHARACTER(10)::str_6
CHARACTER(20)::str_2,str_3,str_4
CHARACTER(4)::str_1
!============= Assemble Hessian matrix APIs =============
REAL(r8k) ::Jac_TCopy(Model_Num, NST)
REAL(r8k) ::Jac(Model_Num,NST),Hessian(Model_Num,Model_Num)
REAL(r8k) ::beta, alpha1
INTEGER(i4k) :: start_pos, end_pos
!============= Calculate singular value APIs =============
TYPE(cusolverDnHandle):: handle ! A handle that handle to the cuSolver library context
TYPE(cusolverDnParams):: params ! A handle that handle to the cuSolver library context
INTEGER(i8k)::rows ! The number of rows of the dense matrix
INTEGER(i8k)::cols ! The number of columns of the dense matrix
INTEGER(i4k)::jobz,econ
INTEGER(i8k)::k,oversampling,niters
integer(i8k) :: workspaceInBytesOnDevice, workspaceInBytesOnHost
integer(i4k), device :: devinfo
INTEGER(i1k), DIMENSION(:), device, ALLOCATABLE :: bufferOnDevice
INTEGER(i1k), DIMENSION(:), ALLOCATABLE :: bufferOnHost
INTEGER(r8k) :: lda, ldu, ldvt
CHARACTER(i1k) :: jobu, jobv
REAL(r8k), device, DIMENSION(:,:), ALLOCATABLE:: U,VT
REAL(r8k), device, DIMENSION(:), ALLOCATABLE:: S
REAL(r8k), device :: Lambda_up, Lambda_down
REAL(r8k)::laida_up,laida_down
REAL(r8k)::h_err_sigma
!============= Host problem definition =============
if(test) then
write(*,*) "*******************This Is The Subroutine Compute_Gradient_GN*******************************"
endif
!============= Record the computation time =============
Hessian = 0
alpha1 = 1.d0
beta = 0.d0
Jac_TCopy = Jac_T
Jac = Jac_T
write(str_1,"(I4)")Num_Regularization+1
write(*,*)"========"//TRIM(str_1)//"th Regularization calculation==========="
!$OMP PARALLEL num_threads(Threads_Num)
!$OMP DO
do Hessian_col = 1, NST
Jac_TCopy( :,Hessian_col ) = Jac_TCopy( :,Hessian_col ) / Dataerr_Variance(Hessian_col)**2
enddo
!$OMP END DO
!$OMP END PARALLEL
!call DGEMM('N', 'T', Model_Num, Model_Num, NST, alpha1, Jac_TCopy, Model_Num, Jac, Model_Num, beta, Hessian, Model_Num)
!$acc data copyin(Jac_TCopy,Jac) copy(Hessian)
Call cublasDgemm( 'N', 'T', Model_Num, Model_Num, NST, alpha1, Jac_TCopy, Model_Num, Jac, Model_Num, beta, Hessian, Model_Num )
! istat = cublasDgemm_v2(handle_WtW,'N', 'T', Model_Num, Model_Num, NST, alpha1, Jac_TCopy, Model_Num, Jac, Model_Num, beta, Hessian, Model_Num )
!$acc end data
rows = Model_Num
cols = Model_Num
econ = 1
lda = rows
ldu = rows
ldvt = cols
jobu = "S"
jobv = "S"
call system_clock(count_rate=count_rate)
call system_clock (t1)
! ============= Device memory management =============
istat = cusolverDnCreate(handle)
istat = cusolverDnSetStream(handle,acc_get_cuda_stream(1))
istat = cusolverDnCreateParams(params)
istat = cusolverDnSetAdvOptions(params, CUSOLVERDN_GETRF, CUSOLVER_ALG_0)
!$acc data copyin(Mat_Wm2%Pos_Row_Firstdata,Mat_Wm2%Col_List, Mat_Wm2%Val_List) &
!$acc copyin(Hessian,Lambda,laida_up,laida_down)
ALLOCATE( S(cols),U(ldu,rows),VT(ldvt,cols) )
write(*,*)"========Solve the singular value of JtJ matrix==========="
istat = cusolverDnXgesvd_bufferSize(handle,params,jobu,jobv,rows,cols,cudaDataType(CUDA_R_64F),&
Hessian,lda,cudaDataType(CUDA_R_64F),S,cudaDataType(CUDA_R_64F),U,ldu,&
cudaDataType(CUDA_R_64F),VT,ldvt,cudaDataType(CUDA_R_64F),&
workspaceInBytesOnDevice, workspaceInBytesOnHost)
allocate(bufferOnDevice(workspaceInBytesOnDevice) , bufferOnHost(workspaceInBytesOnHost) )
istat = cusolverDnXgesvd(handle,params,jobu,jobv,rows,cols,cudaDataType(CUDA_R_64F),&
bufferOnDevice,workspaceInBytesOnDevice,&
bufferOnHost,workspaceInBytesOnHost,&
devinfo)
if(istat/=0)then
write(*,*)"Some superdiagonals are not converge to zero. Maybe Hessian matrix is not very good "
write(*,*)istat
endif
!$acc kernels
Lambda_up = S(1)
laida_up = Lambda_up
!$acc loop collapse(2)
do Hessian_row=1, Model_Num
do Hessian_col=1, Model_Num
Hessian( Hessian_row, Hessian_col ) = 0.0
enddo
enddo
!$acc loop
!$acc loop seq
do WtW_row=Mat_Wm2%Pos_Row_Firstdata(Hessian_row), Mat_Wm2%Pos_Row_Firstdata(Hessian_row+1)-1
Hessian_col = Mat_Wm2%Col_List(WtW_row)
Hessian( Hessian_row, Mat_Wm2%Col_List(Hessian_col) ) = Mat_Wm2%Val_List(WtW_row)
enddo
enddo
!$acc end kernels
devinfo)
if(istat/=0)then
write(*,*)istat
endif
call system_clock (t2)
t = REAL(t2 - t1) / REAL(count_rate)
write(str_6,"(f10.6)")t/60.0
write(*,*) " The computing time of the regularization is:"//TRIM(str_6)//"min"
!$acc kernels
Lambda_down = S(1)
laida_down = Lambda_down
if(istat/=0)then
CALL Regularization_Cooling( Lambda, Num_Regularization+1 )
else
Lambda = Lambda_up/Lambda_down
endif
!$acc end kernels
deallocate( bufferOnDevice,bufferOnHost )
deallocate( S,U,VT )
!$acc update host(Lambda,laida_down,laida_up)
!$acc end data
istat = cusolverDnDestroyParams(params)
istat = cusolverDnDestroy(handle)
Num_Regularization = Num_Regularization+1
write(str_2,"(f20.10)")Lambda
write(str_3,"(f20.10)")laida_up
write(str_4,"(f20.10)")laida_down
write(*,*)"The new lambda is"//TRIM(str_2)//" ("//TRIM(str_3)//";"//TRIM(str_4)//")"
!=========================cusolverDnXgesvdp===========================================================================
IMPLICIT NONE
REAL(r8k) ::t
CHARACTER(4)::str_1
INTEGER(i8k)::k
CHARACTER(i1k) :: jobu, jobvt, jobv
if(test) then
endif
Hessian = 0
alpha1 = 1.d0
beta = 0.d0
Jac_TCopy = Jac_T
Jac = Jac_T
!$OMP DO
enddo
!$OMP END DO
!$OMP END PARALLEL
!$acc end data
rows = Model_Num
cols = Model_Num
econ = 1
lda = rows
ldu = rows
ldvt = cols
jobz = CUSOLVER_EIG_MODE_NOVECTOR
istat = cusolverDnXgesvdp_bufferSize(handle,params,jobz,econ,rows,cols,cudaDataType(CUDA_R_64F),&
istat = cusolverDnXgesvdp(handle,params,jobz,econ,rows,cols,cudaDataType(CUDA_R_64F),&
devinfo,h_err_sigma)
if(istat/=0)then
write(*,*)istat
endif
!$acc kernels
Lambda_up = S(1)
enddo
enddo
!$acc loop
!$acc loop seq
enddo
enddo
!$acc end kernels
if(istat/=0)then
write(*,*)istat
endif
!$acc kernels
Lambda_down = S(1)
if(istat/=0)then
else
endif
!$acc end kernels
!$acc end data
!=========================cusolverDnXgesvdr=============================================================
IMPLICIT NONE
REAL(r8k) ::t
CHARACTER(4)::str_1
if(test) then
endif
Hessian = 0
alpha1 = 1.d0
beta = 0.d0
Jac_TCopy = Jac_T
Jac = Jac_T
!$OMP DO
enddo
!$OMP END DO
!$OMP END PARALLEL
!$acc end data
rows = Model_Num
cols = Model_Num
k = 1
oversampling = 2*k
niters = 3
lda = rows
ldu = rows
ldvt = cols
jobu = "S"
jobv = "S"
write(*,*)"22222222222",Model_Num
istat = cusolverDnXgesvdr_bufferSize(handle,params,jobu,jobv,rows,cols,k,oversampling,niters,cudaDataType(CUDA_R_64F),&
istat = cusolverDnXgesvdr(handle,params,jobu,jobv,rows,cols,k,oversampling,niters,cudaDataType(CUDA_R_64F),&
devinfo)
if(istat/=0)then
write(*,*)istat
endif
!$acc kernels
Lambda_up = S(1)
enddo
enddo
!$acc loop
!$acc loop seq
enddo
enddo
!$acc end kernels
devinfo)
if(istat/=0)then
write(*,*)istat
endif
!$acc kernels
Lambda_down = S(1)
if(istat/=0)then
else
endif
!$acc end kernels
!$acc end data
RETURN
ENDSUBROUTINE Regularization_Initial
regards,
Amore.
