cusolverSpScsreigvsi throws segmentation fault for larger matrices (e.g. 33000x33000)
Hi all, I’ve implemented cusolverSpScsreigvsi to compute the largest eigenvalue of a sparse matrix formatted in CSR. For matrices of size 12080x12080, it works. But, it throws a segmentation fault for 33000x33000. Since I cannot allocate the buffer, so I suspect it might be the issue. Can anybody rescue me?
Here is the code:
// C++ DEPENDENCIES
#include <iostream>
#include <fstream>
#include <sstream>
// CUDA TOOLKIT DEPENDENCIES
#include <cuda_runtime_api.h>
#include <cusparse.h>
#include <cusolverSp.h>
#include <thrust/device_vector.h>
#include <thrust/transform.h>
#include <thrust/random.h>
// To check if CUDA API calls are successful
#define CHECK_CUDA(func)                                                       \
    cudaError_t status = (func);                                               \
    if (status != cudaSuccess) {                                               \
        printf("CUDA API failed at line %d with error: %s (%d)\n",             \
               __LINE__, cudaGetErrorString(status), status);                  \
        exit(EXIT_FAILURE);                                                    \
// To check if cuSPARSE API calls are successful
#define CHECK_CUSPARSE(func)                                                   \
    cusparseStatus_t status = (func);                                          \
    if (status != CUSPARSE_STATUS_SUCCESS) {                                   \
        printf("CUSPARSE API failed at line %d with error: %s (%d)\n",         \
               __LINE__, cusparseGetErrorString(status), status);              \
// To check if cuSOLVER API calls are successful
#define CHECK_CUSOLVER(func)                                                   \
    cusolverStatus_t status = (func);                                          \
    if (status != CUSOLVER_STATUS_SUCCESS) {                                   \
        printf("CUSOLVER API failed at line %d with error: %s (%d)\n",         \
               __LINE__, status, status);                                      \
// Generate random number in the range [0, 1)
struct genRandomNumber {
    __device__
    float operator () (int idx) {
        thrust::default_random_engine randGen;
        thrust::uniform_real_distribution<float> uniDist;
        randGen.discard(idx);
        return uniDist(randGen);
struct CSThrust {
  int m;  // number of rows
  int n;  // number of columns
  int nnz;  // number of non-zero elements
  std::string format; // Either "CSC" or "CSR"
  thrust::device_vector<int> pointers;  // can be column pointer (also called column offsets) or row pointer (also called row offsets)
  thrust::device_vector<int> indices;  // can be row indices or column indices
  thrust::device_vector<float> values;  // can be cscValues or csrValues
// Read a matrix market file and return a CSR matrix
// See https://math.nist.gov/MatrixMarket/formats.html for more details
void readMTXFile2CSR(const std::string& filepath, CSThrust& csr) {
  std::ifstream mtxfile(filepath.c_str(), std::ios::in);
  if (!mtxfile.is_open()) {
    std::cout << "Error opening file: " << filepath << std::endl;
    exit(EXIT_FAILURE);
  // Reading header
  std::string header;
  std::getline(mtxfile, header);
  assert(mtxfile.good());
  std::stringstream formatheader(header);
  std::string substr[5];
  formatheader >> substr[0] >> substr[1] >> substr[2] >> substr[3] >> substr[4];
  assert(substr[0] == "%%MatrixMarket");
  assert(substr[1] == "matrix");
  assert(substr[2] == "coordinate");
  if (substr[3].compare("complex") == 0) {
    std::cout << "Only real and integer valued matrices are supported" << std::endl;
    exit(EXIT_FAILURE);
  // Get symmetry (matrix needs to be square matrix)
  bool is_symmetric = false;
  if (substr[4] == "symmetric") {
    is_symmetric = true;
  } else if (substr[4] == "general") {
  } else {
    std::cout << "Only symmetric and general matrices are supported" << std::endl;
    exit(EXIT_FAILURE);
  // Ignore comments afterwards
  while (mtxfile.peek() == '%') {
    mtxfile.ignore(2048, '\n');
  // Read nrows, ncols, nnz
  int nrows, ncols, nnz;
  mtxfile >> nrows >> ncols >> nnz;
  // Set and resize CSR variables
  csr.format = "CSR";
  csr.m = nrows;
  csr.n = ncols;
  // Symmetric matrix is a square matrix
  if (is_symmetric) {
    assert(nrows == ncols);
    csr.nnz = 2* nnz - nrows;
  } else {
    csr.nnz = nnz;
  // Read the matrix from mtx file, if it's symmetric, then recreate upper triangular part.
  // Store in row-major order
  std::vector<float> values(nrows * ncols, 0.0);
  int row, col;
  float val;
  int diag_count = 0;
  for (int coeff = 0; coeff < nnz; coeff++) {
    mtxfile >> row >> col >> val;
    if (row == col) {
      diag_count++;
      values[(row - 1) * ncols + (col - 1)] = val;
      if (is_symmetric) {
        values[(col - 1) * ncols + (row - 1)] = val;
    } else {
      if (is_symmetric) {
  assert(diag_count == nrows);
  mtxfile.close();
  // Convert to CSR
  csr.pointers.resize(csr.m + 1);
  csr.indices.resize(csr.nnz);
  csr.values.resize(csr.nnz);
  // Setting row offset start with 0 index
  csr.pointers[0] = 0;
  // Extract out the CSR variables
  int nnz_idx = 0;
  for (int row = 0; row < csr.m; row++) {
    for (int col = 0; col < csr.n; col++) {
      if (values[row * csr.n + col] != 0.0) {
        csr.indices[nnz_idx] = col;
        csr.values[nnz_idx] = values[row * csr.n + col];
        nnz_idx++;
    csr.pointers[row + 1] = nnz_idx;
float computeMaxEigenvalue(const CSThrust& M) {
  assert(M.format == "CSR");  // We only use CSR format
  assert(M.m == M.n);
  cusolverSpHandle_t solver_handle = NULL;
  CHECK_CUSOLVER( cusolverSpCreate(&solver_handle) )
  cusparseMatDescr_t M_descr;
  CHECK_CUSPARSE( cusparseCreateMatDescr(&M_descr) )
  //! @note CuSolverSp only supports the matrix is general type. i.e. CUSPARSE_MATRIX_TYPE_GENERAL
  //!       So, if the Matrix is stored only in the upper or lower triangular part, then we need to
  //!       extend into its missing lower or upper part, otherwise the result would be wrong.
  //!       Fortunately, we don't need to do this, because cusparseSpGEMM() will automatically
  //!       store its result in the general format.
  //!       See: https://docs.nvidia.com/cuda/cusolver/index.html#cusolversp-t-csreigvsi
  CHECK_CUSPARSE( cusparseSetMatType(M_descr, CUSPARSE_MATRIX_TYPE_GENERAL) )
  CHECK_CUSPARSE( cusparseSetMatIndexBase(M_descr, CUSPARSE_INDEX_BASE_ZERO) )
  // Define required intial values and threshold
  float tol = 1e-3;  // tolerance to determine the convergence
  int max_iter = 1000;  // maximum number of iterations
  //! @note To set the simple version of upper bound of the largest eigenvalue of the (graph-)Laplacian.
  //!       We use Gershgorin circle theorem such that
  //!       |\lambda_max_computed| <= |lambda_max_guess| = d_i^max + R_i where,
  //!       d_i^max is largest degree of the vertex at ith vertex, and
  //!       R_i is the radius of the Gershgorin circle at ith vertex := \sum_{j \ne i} |M_ij|
  //!       For simplicity, we replace R_i by 2*(nnz - m)/m. lambda_max_guess doesn't needs to be perfect because it's
  //!       just a initial guess, but it should be as close as possible to the actual max. eigenvalue.
  //!       Let me show you how I got this formula:
  //!       1. Probability of nnz elements on the (i, j) excluding diagonal (i.e. i != j) is (nnz - m)/(m^2 - m) = (nnz - m)/(m(m - 1)).
  //!       2. Total possible nnz elements on the ith row excluding diagonal ii is (m - 1) * (nnz - m)/(m(m -1)) = (nnz - m)/m.
  //!       3. Total possible  nnz elements on the ith column excluding diagonal ii is (m - 1) * (nnz - m)/(m(m -1)) = (nnz - m)/m.
  //!       4. Total possible nnz elements either on the row or column excluding its diagonal element is 2*(nnz - m)/m.
  float lambda_max_guess = *thrust::max_element(M.values.begin(), M.values.end()) + ((M.nnz - M.m)/M.m)*2;
  std::cout << "Initial guess for the largest eigenvalue: " << lambda_max_guess << std::endl;
  thrust::device_vector<float> x0(M.m);  // Get the random initial vector
  thrust::transform(thrust::make_counting_iterator(0),
                    thrust::make_counting_iterator(M.m),
                    x0.begin(),
                    genRandomNumber());
  thrust::device_vector<float> x(M.m, 0);  // the eigenvector
  // Setting the variable for the largest eigenvalue to store
  //! @note cuSolver has incorrect documentation for cusolverSpScsreigvsi. mu (i.e. lambda_max_computed)
  //!       should be a device pointer, not a host pointer.
  float *d_lambda_max_computed;
  CHECK_CUDA(cudaMalloc(&d_lambda_max_computed, sizeof(float)));
  CHECK_CUDA(cudaMemset(d_lambda_max_computed, 0, sizeof(float)));
  // Get eigenvalue and eigenvector near to the upper bound of the largest eigenvalue
  CHECK_CUSOLVER( cusolverSpScsreigvsi(solver_handle,
                                        M.m, M.nnz,
                                        M_descr,
                                        thrust::raw_pointer_cast(M.values.data()),
                                        thrust::raw_pointer_cast(M.pointers.data()),
                                        thrust::raw_pointer_cast(M.indices.data()),
                                        lambda_max_guess,
                                        thrust::raw_pointer_cast(x0.data()),
                                        max_iter, tol,
                                        thrust::raw_pointer_cast(x.data())) )  // This line throws segmentation fault for larger matrix sizes. RESCUE ME?
  // Copy to host
  float lambda_max_computed;
  CHECK_CUDA(cudaMemcpy(&lambda_max_computed, d_lambda_max_computed, sizeof(float), cudaMemcpyDeviceToHost));
  // Destroy the descriptor, handle
  CHECK_CUSPARSE( cusparseDestroyMatDescr(M_descr) )
  // CHECK_CUSPARSE( cusparseDestroy(sparse_handle) )
  CHECK_CUSOLVER( cusolverSpDestroy(solver_handle) )
  return lambda_max_computed;
int main(int argc, char** argv) {
  std::string mtx_filepath;
  if (argc > 1) {
    mtx_filepath = argv[1];
  } else {
    std::cout << "Please provide a path to a matrix market file path" << std::endl;
    return EXIT_FAILURE;
  CSThrust M;  // Create a sparse matrix instance
  readMTXFile2CSR(mtx_filepath, M);  // Read the matrix market file and convert it to csr
  float lambda_max = computeMaxEigenvalue(M);  // Compute the largest eigenvalue
  std::cout << "Max eigenvalue: " << lambda_max << std::endl;
  return EXIT_SUCCESS;
I have also attached the matrix in MTX format for testing purpose.
dL22.mtx (9.3 MB)
A seg fault is a problem in host code activity. It can always be localized to a single line of your code that generates the seg fault.
I suggest 1. providing a complete example. 2. identifying the exact line of the example where the seg fault occurs. 3. Identify the CUDA version you are using.
Hi @Robert_Crovella, you can find the complete code at https://github.com/drhere/maxEigenValueGPU. cusolverSpScsreigvsi() api line encounter the segmentation fault. I ran the code in NVIDIA GeForce RTX 2080 Ti with CUDA version 11.7.
Here is output using cuda-memcheck:
$ cuda-memcheck --report-api-errors yes maxeigenvalue mtxs/dL22.mtx
========= CUDA-MEMCHECK
========= This tool is deprecated and will be removed in a future release of the CUDA toolkit
========= Please use the compute-sanitizer tool as a drop-in replacement
Initial guess for the largest eigenvalue: 63
========= Program hit cudaErrorMemoryAllocation (error 2) due to "out of memory" on CUDA API call to cudaMalloc.
=========     Saved host backtrace up to driver entry point at error
=========     Host Frame:/usr/lib/libcuda.so.1 [0x423646]
=========     Host Frame:/opt/cuda/lib64/libcusolver.so.11 [0x697d0b]
=========     Host Frame:/opt/cuda/lib64/libcusolver.so.11 (cusolverSpXcsrqrAnalysis + 0x70b) [0x1039db]
=========     Host Frame:/opt/cuda/lib64/libcusolver.so.11 [0x12babc]
=========     Host Frame:maxeigenvalue [0xe39e]
=========     Host Frame:maxeigenvalue [0xe646]
=========     Host Frame:/usr/lib/libc.so.6 [0x29290]
=========     Host Frame:/usr/lib/libc.so.6 (__libc_start_main + 0x8a) [0x2934a]
=========     Host Frame:maxeigenvalue [0xd2c5]
=========     Host Frame:/opt/cuda/lib64/libcusolver.so.11 (cusolverSpXcsrqrAnalysis + 0x71f) [0x1039ef]
========= Program hit cudaErrorInvalidValue (error 1) due to "invalid argument" on CUDA API call to cudaMemcpyAsync.
=========     Host Frame:/opt/cuda/lib64/libcusolver.so.11 [0x6b01b4]
=========     Host Frame:/opt/cuda/lib64/libcusolver.so.11 [0x12b9aa]
========= Error: process didn't terminate successfully
=========        The application may have hit an error when dereferencing Unified Memory from the host. Please rerun the application under cuda-gdb or Nsight Eclipse Edition to catch host side errors.
========= No CUDA-MEMCHECK results found
If you want to actually post your code here in this forum (like you did in your original posting), I’ll take a look.
But based on what you have posted already, it looks like the proximal issue is that cusparse requires more memory than what is available on your 2080 Ti to process a matrix of that size. So that leads me to 2 observations:
  1. You might want to try it on a GPU with more memory. I don’t have any magic buttons to push that somehow cause cusparse to use less memory than it otherwise would.
  2. In my view, you should not run into a seg fault. The cudaMalloc operation that is part of the cusparse call, that is failing, should result in a graceful handling of the failure, with a returned error code from the cusparse call, not a seg fault. In situations like this I usually recommend checking the behavior against the latest cuda version (because that’s what our QA team would do) and if it still persists, then file a bug. So you may wish to file a bug. At some point when time permits, I may file a bug if I can understand the issue well enough. But to be clear, the bug I’m suggesting is not about getting the operation to work with less memory, its about better error handling.
Hi @Robert_Crovella, I updated the issue with the complete code. I hope, cuSolver will have better error handling as you said.
I checked the same matrix (dL22.mtx) using Spectra library in the CPU. It works perfectly well. With nev =1, ncv=20, Spectra::SortRule::LargestMagn, it took a few seconds to get the approximated largest eigenvalue to be 70.2057. Is it possible to request such features (with different algorithms other than shift-Inverse; for eg. Lanczos algorithm) in cuSolver?
Sure. You can request features by filing bugs. Just indicate that it is a “request for enhancement” or similar wording.
I filed the report yesterday and with the link to this discussion, but forget to mention it’s a request for enhancement. I hope they’ll understand by reading your comments.
It should be|\lambda_max_computed| has initial guess to be |lambda_max_guess| = d_i^max + R_i. or simply just |lambda_max_guess| = d_i^max + R_i.
