Cuda-memcheck error in cusolverDnCgesvdjBatched function
I am using cusolverDnCgesvdjBatched function to calculate singular value decomposition (SVD) of multiple matrices, I use cuda-memcheck to check any memory issues, I am getting an error like this in the cusolverDnCgesvdjBatched function.
========= Invalid __global__ write of size 4
=========     at 0x000062f8 in void batched_svd_parallel_jacobi_32x16<float2, float>(int, int, int, int, float2*, __int64, int, float*, float2*, __int64, int, float2*, __int64, int, float, int, int*, float, int, int*, int, float)
=========     by thread (0,0,0) in block (4,0,0)
=========     Address 0x701019010 is out of bounds
=========     Saved host backtrace up to driver entry point at kernel launch time
=========     Host
========= Program hit CUDA_ERROR_LAUNCH_FAILED (error 719) due to "unspecified launch failure" on CUDA API call to cuModuleUnload.
=========     Saved host backtrace up to driver entry point at error
=========     Host Frame:C:\WINDOWS\system32\DriverStore\FileRepository\nvami.inf_amd64_72390dc4652f28fa\nvcuda64.dll (cuProfilerStop + 0x904ce) [0x2ae05e]
=========     Host Frame:C:\WINDOWS\system32\DriverStore\FileRepository\nvami.inf_amd64_72390dc4652f28fa\nvcuda64.dll (cuProfilerStop + 0x92e73) [0x2b0a03]
=========     Host Frame:C:\WINDOWS\system32\DriverStore\FileRepository\nvami.inf_amd64_72390dc4652f28fa\nvcuda64.dll [0x84cb7]
=========     Host Frame:C:\WINDOWS\system32\DriverStore\FileRepository\nvami.inf_amd64_72390dc4652f28fa\nvcuda64.dll [0x86e03]
=========     Host Frame:C:\WINDOWS\system32\DriverStore\FileRepository\nvami.inf_amd64_72390dc4652f28fa\nvcuda64.dll (cuProfilerStop + 0x11473a) [0x3322ca]
=========     Host Frame:C:\WINDOWS\system32\DriverStore\FileRepository\nvami.inf_amd64_72390dc4652f28fa\nvcuda64.dll (cuModuleUnload + 0x1d6) [0x1d5d36]
=========     Host Frame:D:\SVD\x64\Release\SVD.exe (cudart::module::unload + 0x115) [0x9535]
=========     Host Frame:D:\SVD\x64\Release\SVD.exe (cudart::contextState::unloadAllModules + 0x196) [0x9b36]
=========     Host Frame:D:\SVD\x64\Release\SVD.exe (cudart::contextStateManager::destroyAllContextStatesOnRuntimeUnload + 0x78) [0xa188]
=========     Host Frame:D:\SVD\x64\Release\SVD.exe (cudart::globalState::~globalState + 0x3d) [0x24dd]
=========     Host Frame:D:\SVD\x64\Release\SVD.exe (cudart::set<cudart::globalModule * __ptr64>::rehash + 0x106) [0x74c6]
=========     Host Frame:C:\WINDOWS\System32\ucrtbase.dll (execute_onexit_table + 0x156) [0x142d6]
=========     Host Frame:C:\WINDOWS\System32\ucrtbase.dll (execute_onexit_table + 0x7b) [0x141fb]
=========     Host Frame:C:\WINDOWS\System32\ucrtbase.dll (execute_onexit_table + 0x34) [0x141b4]
=========     Host Frame:C:\WINDOWS\System32\ucrtbase.dll (exit + 0x142) [0x20522]
=========     Host Frame:C:\WINDOWS\System32\ucrtbase.dll (exit + 0xcb) [0x204ab]
=========     Host Frame:C:\WINDOWS\System32\ucrtbase.dll (exit + 0x6e) [0x2044e]
=========     Host Frame:D:\SVD\x64\Release\SVD.exe (gpuErrchk + 0x4c) [0xf0dc]
=========     Host Frame:D:\SVD\x64\Release\SVD.exe (main + 0x3ef) [0xebaf]
=========     Host Frame:D:\SVD\x64\Release\SVD.exe (__scrt_common_main_seh + 0x10c) [0xf5c4]
=========     Host Frame:C:\WINDOWS\System32\KERNEL32.dll (BaseThreadInitThunk + 0x14) [0x17034]
=========     Host Frame:C:\WINDOWS\SYSTEM32\ntdll.dll (RtlUserThreadStart + 0x21) [0x52651]
========= ERROR SUMMARY: 8 errors
Please suggest fixes.
I am using the following code:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
#include <cuda_runtime.h>
#include <cusolverDn.h>
#include "Utilities.cuh"
#include "TimingGPU.cuh"
#define FULLSVD
#define PRINTRESULTS
/* MAIN */
int main() {
    const int           M = 10;
    const int           N = 5;
    const int           lda = M;
    //const int         numMatrices = 3;
    const int           numMatrices = 256;
    TimingGPU timerGPU;
    // --- Setting the host matrix
    cuComplex *h_A = (cuComplex *)malloc(lda * N * numMatrices * sizeof(double));
    for (unsigned int k = 0; k < numMatrices; k++)
        for (unsigned int i = 0; i < M; i++)
            for (unsigned int j = 0; j < N; j++)
                h_A[k * M * N + j * M + i] = make_float2((1. / (k + 1)) * (i + j * j) * (i + j), (1. / (k + 1)) * (i + j * j) * (i + j));
                //printf("[%d, %d] %f\n", i, j, h_A[j*M + i]);
                //printf("%f %f", h_A[j*M + i].x, h_A[j * M + i].y);
            //printf("\n");
    // --- Setting the device matrix and moving the host matrix to the device
    cuComplex *d_A;         gpuErrchk(cudaMalloc(&d_A, M * N * numMatrices * sizeof(cuComplex)));
    gpuErrchk(cudaMemcpy(d_A, h_A, M * N * numMatrices * sizeof(cuComplex), cudaMemcpyHostToDevice));
    // --- host side SVD results space
    float *h_S = (float *)malloc(N * numMatrices * sizeof(float));
    cuComplex *h_U = NULL;
    cuComplex *h_V = NULL;
#ifdef FULLSVD
    h_U = (cuComplex *)malloc(M * M * numMatrices * sizeof(cuComplex));
    h_V = (cuComplex *)malloc(N * N * numMatrices * sizeof(cuComplex));
#endif
    // --- device side SVD workspace and matrices
    int work_size = 0;
    int *devInfo;        gpuErrchk(cudaMalloc(&devInfo, sizeof(int)));
    float *d_S;         gpuErrchk(cudaMalloc(&d_S, N * numMatrices * sizeof(float)));
    cuComplex *d_U = NULL;
    cuComplex *d_V = NULL;
#ifdef FULLSVD
    gpuErrchk(cudaMalloc(&d_U, M * M * numMatrices * sizeof(cuComplex)));
    gpuErrchk(cudaMalloc(&d_V, N * N * numMatrices * sizeof(cuComplex)));
#endif
    cuComplex *d_work = NULL; /* devie workspace for gesvdj */
    int devInfo_h = 0; /* host copy of error devInfo_h */
    // --- Parameters configuration of Jacobi-based SVD
    const double            tol = 1.e-7;
    const int               maxSweeps = 15;
    cusolverEigMode_t jobz;                                   // --- CUSOLVER_EIG_MODE_VECTOR - Compute eigenvectors; CUSOLVER_EIG_MODE_NOVECTOR - Compute singular values only
#ifdef FULLSVD
    jobz = CUSOLVER_EIG_MODE_VECTOR;
#else
    jobz = CUSOLVER_EIG_MODE_NOVECTOR;
#endif
    const int               econ = 0;                            // --- econ = 1 for economy size
    // --- Numerical result parameters of gesvdj
    double                  residual = 0;
    int                     executedSweeps = 0;
    // --- CUDA solver initialization
    cusolverDnHandle_t solver_handle = NULL;
    cusolveSafeCall(cusolverDnCreate(&solver_handle));
    // --- Configuration of gesvdj
    gesvdjInfo_t gesvdj_params = NULL;
    cusolveSafeCall(cusolverDnCreateGesvdjInfo(&gesvdj_params));
    // --- Set the computation tolerance, since the default tolerance is machine precision
    cusolveSafeCall(cusolverDnXgesvdjSetTolerance(gesvdj_params, tol));
    // --- Set the maximum number of sweeps, since the default value of max. sweeps is 100
    cusolveSafeCall(cusolverDnXgesvdjSetMaxSweeps(gesvdj_params, maxSweeps));
    // --- Query the SVD workspace
    cusolveSafeCall(cusolverDnCgesvdjBatched_bufferSize(
        solver_handle,
        jobz,                                       // --- Compute the singular vectors or not
        M,                                          // --- Number of rows of A, 0 <= M
        N,                                          // --- Number of columns of A, 0 <= N
        d_A,                                        // --- M x N
        lda,                                        // --- Leading dimension of A
        d_S,                                        // --- Square matrix of size min(M, N) x min(M, N)
        d_U,                                        // --- M x M if econ = 0, M x min(M, N) if econ = 1
        lda,                                        // --- Leading dimension of U, ldu >= max(1, M)
        d_V,                                        // --- N x N if econ = 0, N x min(M,N) if econ = 1
        lda,                                        // --- Leading dimension of V, ldv >= max(1, N)
        &work_size,
        gesvdj_params,
        numMatrices));
    gpuErrchk(cudaMalloc(&d_work, sizeof(cuComplex) * work_size));
    // --- Compute SVD
    timerGPU.StartCounter();
    cusolveSafeCall(cusolverDnCgesvdjBatched(
        solver_handle,
        d_A,                                        // --- M x N
        d_V,                                        // --- N x N if econ = 0, N x min(M, N) if econ = 1
        N,                                          // --- Leading dimension of V, ldv >= max(1, N)
        d_work,
        work_size,
        devInfo,
        gesvdj_params,
        numMatrices));
    printf("Calculation of the singular values only: %f ms\n\n", timerGPU.GetCounter());
    gpuErrchk(cudaMemcpy(&devInfo_h, devInfo, sizeof(int), cudaMemcpyDeviceToHost));
    gpuErrchk(cudaMemcpy(h_S, d_S, sizeof(float) * N * numMatrices, cudaMemcpyDeviceToHost));
#ifdef FULLSVD
    gpuErrchk(cudaMemcpy(h_U, d_U, sizeof(cuComplex) * lda * M * numMatrices, cudaMemcpyDeviceToHost));
    gpuErrchk(cudaMemcpy(h_V, d_V, sizeof(cuComplex) * N * N * numMatrices, cudaMemcpyDeviceToHost));
#endif
#ifdef PRINTRESULTS
    printf("SINGULAR VALUES \n");
    printf("_______________ \n");
    for (int k = 0; k < numMatrices; k++)
        for (int p = 0; p < N; p++)
            printf("Matrix nr. %d; SV nr. %d; Value = %f\n", k, p, h_S[k * N + p]);
        printf("\n");
#if 0 //FULLSVD
    printf("SINGULAR VECTORS U \n");
    printf("__________________ \n");
        for (int q = 0; q < (1 - econ) * M + econ * min(M, N); q++)
            for (int p = 0; p < M; p++)
                printf("Matrix nr. %d; U nr. %d; Value = %f\n", k, p, h_U[((1 - econ) * M + econ * min(M, N)) * M * k + q * M + p]);
        printf("\n");
    printf("SINGULAR VECTORS V \n");
        for (int q = 0; q < (1 - econ) * N + econ * min(M, N); q++)
                printf("Matrix nr. %d; V nr. %d; Value = %f\n", k, p, h_V[((1 - econ) * N + econ * min(M, N)) * N * k + q * N + p]);
        printf("\n");
#endif
#endif
    if (0 == devInfo_h)
        printf("gesvdj converges \n");
    else if (0 > devInfo_h)
        printf("%d-th parameter is wrong \n", -devInfo_h);
        exit(1);
    else
        printf("WARNING: devInfo_h = %d : gesvdj does not converge \n", devInfo_h);
    // --- Free resources
    if (d_A) gpuErrchk(cudaFree(d_A));
    if (d_S) gpuErrchk(cudaFree(d_S));
#ifdef FULLSVD
    if (d_U) gpuErrchk(cudaFree(d_U));
    if (d_V) gpuErrchk(cudaFree(d_V));
#endif
    if (devInfo) gpuErrchk(cudaFree(devInfo));
    if (d_work) gpuErrchk(cudaFree(d_work));
    if (solver_handle) cusolveSafeCall(cusolverDnDestroy(solver_handle));
    if (gesvdj_params) cusolveSafeCall(cusolverDnDestroyGesvdjInfo(gesvdj_params));
    gpuErrchk(cudaDeviceReset());
    return 0;
Could you provide the full code to reproduce with the included headers?
