Hi ,
I configured sleep/wake and GPIO02 in device tree location : L4T_Sources/r32.6.1/Linux_for_Tegra/source/public/hardware/nvidia/platform/t18x/lanai/kernel-dts/common/tegra186-p3509-0000-cvb.dtsi
Here I configure GPIO(L ,0) as Wake up pin and GPIO(FF ,0) as sleep pin.
As per the use-case ,If I short the sleep pin terminal should be stuck ie,it is going through sleep mode. When I short wake up pin it should come from that sleep mode.
Wake up using GPIO02 can be done ,but sleep can be done only by using "sudo systemctl suspend " command not by using sleep /wake up pin.
ie ,I have to sleep Jetson TX2 NX using sleep/wake up pin and wake up using GPIO02 pin. Both are not happening at the same time
Can someone pls help on this .Should I need to change anything in device Tree?
GPIO02 is by default WiFi Module BT Wake AP.
please check Chipset Power States session, there’re some common wake sources available on Jetson platforms.
Hi @JerryChang ,
I checked this but we need to configure sleep Jetson TX2 NX using sleep/wake up pin and wake up using GPIO02 pin according to our Schematics. .
Hi @JerryChang ,
Our requirement is to configure sleep Jetson TX2 NX using sleep/wake up pin and wake up using GPIO02 pin .We can’t change it.
Is there any option to configure like this
please also see [Figure 10-1. Audio Connections] in Jetson TX2 NX Product Design Guide,
there’s a note,
The Interrupt pin from the audio codec can connect to any available Jetson TX2 NX GPIO. If the pin must be wake-capable, choose one of the GPIOs that supports this function.
