The Kernel Configuration has so many items, I dont konw how to config these items.
Such as General setup–>
Enable loadable module support–>
Do have some reference files to explain the meaning of every item ?
So that I can config them easily and comfortably.
The command I use is menuconfig.
Thank you very much!
Hi lnu_liuyang,
Please refer to the L4T development guide first - https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fkernel_custom.html%23
Thank you for your reply!
I want to config the Kernel Configuration,and how to config every item.Thank you !
Is there a graphical interface configuration manual to config the Kernel Configuration
Have a try make menuconfig need install “sudo apt-get install libncurses5-dev”
[img][img]
I had open the menu of Kernel Configuration .
But I dont konw how to config the every item of menu of Kernel Configuration .
Are you clear what I say???
I want a manual which can tell me how to config the menu of the Kernel Configuration.
I think you can find every item by google search.
You can get a basic idea on how to configure each menu item by reading the help message available when you run the make menuconfig command
Because I dont konw how to configure each option to config Y ,N ,M,and the meaning of every item of the Kernel Configuration .
Thank you very much!That’s a good idea!
The target “make tegra_defconfig” will set sane defaults for everything. From there you simply need to start the “make menuconfig”, and then set a few entries which you are interested in changing.
The “y” entries change the kernel itself, and may imply a need to do a more involved installation. The “m” entry builds as a module, and is a simple file copy, but not all features can be in module format (“make menuconfig” will not offer “m” if module format is not available).
Note that a Jetson will show its current running config via the “/proc/config.gz” file. After gunzip of this and change of name to “.config”, this is nearly an exact match for duplicating the existing config. CONFIG_LOCALVERSION is the only thing this does not match. This thread is a bit old, but has some basics:
https://devtalk.nvidia.com/default/topic/1038175/jetson-tx2/tx2i-wifi-support/post/5274619/#5274619
Note that “make tegra_defconfig” is mostly the same as starting with the “/proc/config.gz” file you would obtain and put in place if the system you copy the file from uses the default kernel.
This talks about modules versus integrated features (“m” versus “y”):
https://devtalk.nvidia.com/default/topic/1012382/jetson-tx2/usb-wifi-adapter-s-/post/5290682/#5290682
