How to configure USB 3.0 OTG function
I tried to pair USB2 P0 and SS P0 to have USB3.0 OTG function on developer kit.
After reading TRM page 1283, I think we may need send USB2 P0 and SS P0 signals to XUSB controller.
My questions are below:
  1. How to configure MUX for USB2 P0 signal to XUSB controller instead of to USB2 controller#1 (OTG)?
  2. If USB 3.0 OTG works, how to force set TX1 as a device. Can we control USB_ID_PIN to enable this function?
Thanks for any help.
Hi yenyu,
Did you ever check this topic [url]https://devtalk.nvidia.com/default/topic/933330/jetson-tx1/jetson-tx1-usb3-0-otg[/url]/ ? Hope it can help you.
Hi Trumany,
Thank you for your help.
I have followed below topics to configure our device and kernel menuconfig to pair USB2 P0 and SS P1
https://devtalk.nvidia.com/default/topic/925646/tx1-usb3-0-design/
In host mode, it seems OK.
[ 124.054848] extcon-gpio-states 1.extcon: Cable state 2
[ 124.054995] tegra-xotg xotg.26: extcon_id_notifications():219: USB_ID pin grounded
[ 124.055087] tegra-xhci tegra-xhci: received otg event 2
[ 124.055192] tegra-xudc tegra-xudc: extcon_notifications():609: device is not ready, ignore this event
[ 124.055741] tegra-xhci tegra-xhci: received otg event 5
[ 124.055816] tegra-xhci tegra-xhci: otg port pp on
[ 124.056474] tegra-xotg xotg.26: xotg_work():857: state b_idle → a_idle
[ 124.056592] tegra-xotg xotg.26: xotg_work():1228: state a_idle → a_wait_vrise
[ 124.056749] tegra-xotg xotg.26: xotg_enable_vbus():471: id gnd to vbus on :0 ms
[ 124.060400] tegra-xotg xotg.26: xotg_work():1278: state a_wait_vrise → a_wait_bcon
[ 124.081061] tegra-xotg xotg.26: xotg_work():1387: state a_wait_bcon → a_host
[ 124.081165] tegra-xotg xotg.26: otg->gadget or gadget->dev.parent null
[ 124.224262] extcon-gpio-states 1.extcon: Cable state 2
[ 124.355194] usb 2-2: new SuperSpeed USB device number 3 using tegra-xhci
[ 124.383714] usb 2-2: device v05e3 p0616 is not supported
[ 124.389214] usb 2-2: New USB device found, idVendor=05e3, idProduct=0616
[ 124.389316] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 124.389405] usb 2-2: Product: USB3.0 Hub
[ 124.389486] usb 2-2: Manufacturer: GenesysLogic
[ 124.398736] hub 2-2:1.0: USB hub found
[ 124.399713] hub 2-2:1.0: 4 ports detected
[ 124.533718] usb 1-1: new high-speed USB device number 3 using tegra-xhci
[ 124.567194] usb 1-1: device v05e3 p0610 is not supported
[ 124.572694] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
[ 124.572795] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 124.572885] usb 1-1: Product: USB2.0 Hub
[ 124.572966] usb 1-1: Manufacturer: GenesysLogic
[ 124.583877] hub 1-1:1.0: USB hub found
[ 124.584887] hub 1-1:1.0: 4 ports detected
[ 124.689190] usb 2-2.1: new SuperSpeed USB device number 4 using tegra-xhci
[ 124.708208] usb 2-2.1: Parent hub missing LPM exit latency info. Power management will be impacted.
[ 124.716309] usb 2-2.1: device v8564 p1000 is not supported
[ 124.721983] usb 2-2.1: New USB device found, idVendor=8564, idProduct=1000
[ 124.722091] usb 2-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 124.722177] usb 2-2.1: Product: Mass Storage Device
[ 124.722257] usb 2-2.1: Manufacturer: JetFlash
[ 124.722338] usb 2-2.1: SerialNumber: 05Q0TMFDLSRL0RKA
[ 124.727080] usb-storage 2-2.1:1.0: USB Mass Storage device detected
[ 124.728582] scsi0 : usb-storage 2-2.1:1.0
[ 124.884995] usb 1-1.2: new high-speed USB device number 4 using tegra-xhci
[ 124.914353] usb 1-1.2: device v1005 pb113 is not supported
[ 124.920031] usb 1-1.2: New USB device found, idVendor=1005, idProduct=b113
[ 124.920132] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 124.920223] usb 1-1.2: Product: USB FLASH DRIVE
[ 124.920306] usb 1-1.2: Manufacturer:
[ 124.920387] usb 1-1.2: SerialNumber: 07085B470F944E45
[ 124.926519] usb-storage 1-1.2:1.0: USB Mass Storage device detected
and “lsusb -t” information, I plugged in two USB disk (3.0 and 2.0)
ubuntu@tegra-ubuntu:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xhci/4p, 5000M
|__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
|__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 1: Dev 4, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xhci/5p, 480M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 4, If 0, Class=Mass Storage, Driver=usb-storage, 480M
When I tried to set TX1 as device mode by controlling USB_ID, I got below kernel log.
[ 649.730187] extcon-gpio-states 1.extcon: Cable state 0
[ 649.730333] tegra-xotg xotg.26: extcon_id_notifications():222: USB_ID pin floating
[ 649.730422] tegra-xhci tegra-xhci: received otg event 6
[ 649.730521] tegra-xudc tegra-xudc: extcon_notifications():609: device is not ready, ignore this event
[ 649.738485] tegra-xotg xotg.26: xotg_work():1207: state a_idle → b_idle
[ 651.329825] tegra-xotg xotg.26: xotg_work():906: state b_idle → b_srp_init
[ 651.429756] tegra-xotg xotg.26: xotg_work():969: state b_srp_init → b_idle
[ 651.438542] tegra-xudc tegra-xudc: IRQ event for host controller as well
Then I tried to set TX1 as mass_storage by below commands
  1. sudo insmod libcomposite.ko
  2. sudo insmod g_mass_storage.ko file=/dev/mmcblk1p1
I got below error messages:
[ 927.017502] g_mass_storage gadget: Mass Storage Function, version: 2009/09/11
[ 927.017514] g_mass_storage gadget: Number of LUNs=1
[ 927.017526] lun0: LUN: file: /dev/mmcblk1p1
[ 927.017538] g_mass_storage gadget: unable to autoconfigure all endpoints
[ 927.024778] g_mass_storage tegra-xudc: failed to start g_mass_storage: -524
Could you give me some ideals to fix this issue?
And I also tried another method to set TX1 as device mode.
https://devtalk.nvidia.com/default/topic/952472/jtx1_usb_as-device/?offset=4
But if I enable CONFIG_USB_G_ANDROID=y in kernel config, TX1 was crashed when booting.
Could you also give me some ideals of this issue?
Thank you very much.
Hi yenyu,
I see you make progress in
[url]https://devtalk.nvidia.com/default/topic/952472/jetson-tx1/jtx1_usb_as-device/post/5033515/#5033515[/url]
So now you have get USB 2.0 otg work but USB 3.0 otg still fails?
Hi DaneLLL,
We was able to set TX1 as an USB 3.0 device successfully.
