nwlee
December 27, 2017, 7:50am
#1
I’d like to convert gstreamer commands as below to python code.
gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw, width=1920, height=1080, framerate=60/1, format=UYVY’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=60/1, format=I420’ ! nvoverlaysink sync=false
Could you let me know your idea?
Thanks & BR,
DaneLLL
December 27, 2017, 8:05am
#2
Hi nwlee,
We don’t have experience in this. I search online and get https://brettviren.github.io/pygst-tutorial-org/pygst-tutorial.pdf
Please check if it helps.
nwlee
January 2, 2018, 9:54am
#3
Hi Dane,
Thank you for your support.
I saw the document that you sent. But, I don’t know exactly.
I’d like to know that working the gst command with the python code to the v4l2src method (not nvcamerasrc, filesrc).
Could you give me a sample command?
Thank you $ BR,
nwlee
January 3, 2018, 12:57am
#4
Hi Dane,
Please let me know your idea.
If you don’t know this issue, please assign known person for this issue.
Thanks & BR,
nwlee
January 3, 2018, 11:54am
#5
Hi Dane,
I have written as below.
import cv2
import numpy as np
import gi
gi.require_version(“Gst”,“1.0”)
from gi.repository import Gst
import time
Gst.init(None)
class mygst:
def init (self):
self.pipeline = None
self.connection = None
self.client_address = None
self.bitrate = 2000000
self.control_queue = None
if self.pipeline is not None:
return
pipeline_string = " v4l2src device=/dev/video0" + \
" ! 'video/x-raw, width=1920, height=1080, framerate=60/1, format=UYVY' " + \
" ! nvvidconv " + \
" ! 'video/x-raw(memory:NVMM), format=NV12' " + \
" ! tee name=t t. " + \
" ! queue " + \
" ! omxh264enc bitrate=8000000 " + \
" ! h264parse " + \
" ! matroskamux " + \
" ! filesink location=EO_image.mp4 t. " + \
" ! queue " + \
" ! nvtee " + \
" ! nvoverlaysink sync=false "
self.pipeline = Gst.parse_launch(pipeline_string)
ret = self.pipeline.set_state(Gst.State.PLAYING)
if ret == Gst.StateChangeReturn.FAILURE:
print("Unable to set pipeline to playing")
self.pipeline.set_state(Gst.State.NULL)
def main():
prevTime = time.time()
cap = cv2.VideoCapture(“EO_image.mp4”)
while True:
ret, frame = cap.read()
curTime = time.time()
sec = curTime - prevTime
fps = 1/sec
print("sec : ",sec)
print("fps : ",fps)
str = "FPS : %0.1f" % fps
cv2.putText(frame,str,(0,100),cv2.FONT_HERSHEY_SIMPLEX,1,(0,255,0))
if not ret:
print("Video Error")
cv2.imshow('image',frame)
cv2.imwrite('img.jpg',frame)
#server = mygst()
#server.__init__()
if cv2.waitKey(50) & 0xFF == 27:
break
cv2.destroyAllWindows()
cap.release()
main()
But, It’s not working.
What is wrong?
I need your help.
Thanks & BR,
