Hi Guys,
does anyone know how to convert a mpeg2 to mp4 (h264) with NVENC?
My setup is like this:
- NVIDIA GTX 750 TI (Maxwell)
- Windows 7 Pro
- NVIDIA 335.23 Driver
- NVENC 3.0 SDK
It’s doing fine if I pass a *.YUV Video file to the “nvEncoder_32.exe” but it isn’t working if I pass a *.mpeg file to the “nvEncoder”.
This is the Commandline that I use:
nvEncoder_32 -configFile=config.txt -outfile=output.264
Doesn’t work with Input.mpg → “inFile = input.mpg”
Commandline Verbose for not working mpg file:
Result:
But if I convert via “ffmpeg” the “input.mpg” to “input.yuv” and pass it to nvEncoder it’s working fine:
Working fine with Input.yuv → “inFile = input.yuv”
Result:
And this is my config.txt file:
// H.264 encoder parameter file
// syntax: [parameter [=] value] [[#|//] comment]
// Profile, Level
profile = 100 // 66=Baseline, 77=Main, 100=High, 0=auto(=lowest possible profile)
level = 40 // 10,11,12,13,20,21,22,30,31,32,40,41,42,50,51=level_idc, 0=auto(=lowest possible level)
// sequence structure
gopLength = 25 // IDR frame distance
numBFrames = 1 // number of B frames between I and P frames
fieldMode = 1 // 0=prog frame, 1=field
bottomfieldFirst = 0 // 0=top field first, 1=bottom field first
numSlices = 1 // 0=auto, 1..PicHeightInMbs=number of slices per picture
// Input File Details
width = 1920 // Width of Input Frame
height = 1080 // Height of Input Frame
maxwidth = 1920 // Max Width for resource allocation. Max resoultion change during reconfiguration can not go beyond MaxWidth, MaxHeight
maxheight = 1080 // Max Width for resource allocation. Max resoultion change during reconfiguration can not go beyond MaxWidth, MaxHeight
inFile = input.mpg
// Driver COde Path property
preset = 5 // 0=NV_ENC_PRESET_DEFAULT, 1=NV_ENC_PRESET_LOW_LATENCY_DEFAULT, 2=NV_ENC_PRESET_HP, 3=NV_ENC_PRESET_HQ, 4=NV_ENC_PRESET_BD, 5=NV_ENC_PRESET_LOW_LATENCY_HQ, 6=NV_ENC_PRESET_LOW_LATENCY_HP
interfaceType = 2 // 0=DX9, 1=DX11, 2=CUDA, 3=DX10
syncMode = 0 // 0=AsyncMode, 1=SyncMode
// bitstream characteristics (Type I HRD)
maxbitrate = 2000000 // Peakbitrate, maximum bitrate (bits/sec), 0=use encoder defined default (level limit)
vbvBufferSize = 2000000 // vbvBufferSize, decoder buffer size (bits), 0=use encoder defined default (level limit)
vbvInitialDelay = 1000000 // vbvInitialDelay, initial decoder buffer fullness (bits), 0=use encoder defined default (50%)
// rate control
rcMode = 8 // 0=fixed QP, 1=VBR, 2=CBR, 4=VBR_MINQP, 8=CBR_TWOPASS
bitrate = 2000000 // average bit rate (bits/s) (ignored if RCMode != 1)
enableInitialRCQP = 1
initialQPI = 28 // If enableInitialRCQP set then It will be used as InitialQP value for I slices for RCMode !=0. constant QP value for I slices For RCMode =0.
initialQPP = 28 // If enableInitialRCQP set then It will be used as InitialQP value for P slices for RCMode !=0. constant QP value for P slices For RCMode =0.
initialQPB = 34 // If enableInitialRCQP set then It will be used as InitialQP value for B slices for RCMode !=0. constant QP value for B slices For RCMode =0.
frameRateNum = 16
frameRateDen = 0
// picture type decision
enablePtd = 1 // 1=picture type decision will be takane by Encoder driver. 0=picture type decision will be takane by application
Can anyone help me please?! I don’t want to convert mpeg to yuv and pass it then to nvEncoder I just want to pass the mpeg file directly to the nvEncoder to generate a h264 file.
Any help would be much appreciated!
Thanks in advance!
