Hi all,
I am quite new to programming at a device level, so please excuse my lack of knowledge on the subject…
I have the following high-level requirements which I’m trying to find an optimal solution for, however, I am a bit stumped as to how to go about it.
The high-level requirements are:
[*] Capture data from a NVIDIA Quadro SDI Graphics Capture Card
[*] Encode output to MPEG-2 with specific qualities (e.g. bitrate, aspect ratio, frame rate etc…)
(Assume this service is running on a Windows XP 64 bit server)
I thought the best way to do this was to:
[list=1]
[*] Use the NVIDIA Quadro SDI API to connect to the device and read the raw data
[*] Encode the raw data from the capture card to H.264 using CUDA Video Encode library (see cude encode)
[*] Encode the H.264 output to MPEG-2 output with desired qualities
However, I am sure there is a better way involving less steps to do this!
Is there a better way of doing this with less steps that can essentially get the output of the Capture Card directly into an MPEG-2 format?
Any help would be greatly appreciated.
Regards
sh
